Hi Nils
Yes, I hope so. At the moment I lean towards a slightly altered Pickle.
To correct that ugly stern and the placing of the masts (in my opinion the foremast should move a bit forward) I think of using plans of a similar schooner from NMM.
Hi Martin and Timmo
thanks
Cheers
Peter
The fore topsail is one of the largest sails. It was therefore again reduced in size by 40%. Then it was bent to the yard and the yard brought to the foremast in a similar way as the main topsail yard. A buntline was again installed in addition to the rigging according to the kit’s plans. I was running out of space on the bitts as more and more rigging lines were belayed on it and I decided to finish all the running rigging of the foremast before coiling up the lines.
Fore topsail ready to be bent it to its yard
Detail of the fore topsail
Ready to furl
Parrels and ties installed
Running rigging finished (for now, braces will follow later)
The fore topgallant sail was reduced in size by 30%. This is the same amount as on the main topgallant sail. On future projects I will probably reduce all furled sails by 40% but here I will stick to the slightly larger variant to keep the proportions.
The sail maker is already working on the fore topgallant sail
Hi Peter -- great action shots, as always.  Congratulations on getting your running rigging done.  Smooth sailmaking from now on!
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
I just love the way you have handled the furled sails, I am at that stage on my Bounty build and rest assured I will be using your inspiration and techniques...thanks
HMAV Bounty 'Billings' completed
HMS Cheerful - Syren-Chuck' completed :)
Steam Pinnace 199 'Billings bashed' - completed
HMS Ledbury F30 --White Ensign -completed 😎
HMS Vanguard 'Victory models'-- completed :)
Bismarck Amati 1/200 --complete  👍
HMS WARRIOR Billings just started
Looks very good Peter,
I may look up your rigging pics for cross reference now and then
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Martin
Unfortunately only the running rigging for that sail is done. On the other hand there are only 3 more yards remaining to finish and of those, the spritsail yard, will carry no sail – only the upper sprit topsail will be there in furled condition.
And then only two jibs will remain and the finishing of the deck equipment with spare spars and boats and the gun port lids, the lantern, the hammock nets, all the braces on the lower yards and a few odds and ends – yes, I’m nearly there. But seriously, I can begin to think about the next build as it should start in less than a year. :)
Hi Ian
Thank you for the compliment. I’m glad, if I can be of any help.
Hi Nils
Sure. But of course there are still mistakes and shortcuts in my rigging. If in doubt, feel free to ask.
Cheers
Peter
Ok, it's done for only the first one.  But now you can get the rhythm going, since you've figured out the biggest problems, or at least the first set of big problems.
Cheers,
Martin
Just thought I'd let you know that using your furling method, I actually got a almost presentable furled sail.  Still more practice to go; and I think I used too much Tacky Glue.  The sail is stiffer than when I started.  But I am encouraged.
Many thanks to your site for all the help.
Cheers.
Ken
Washington 1776 Galley
Completed Builds:
Pilot Boat Mary  (from Completed Gallery) (from MSW Build)
Hello Peter.
Wonderful model. A true inspiration.
I bought this model half built some time ago and I'm now at the rigging stage. I have a question about the Futtock Staves. Did you tie them to every shroud or just to a few? I'm worried I'll end up with a big lump of knots with all the rope meeting there.
Cheers
Mr. Pucko
Building:
Nuestra Senora del Pilar - Occre
Titanic - Amati
HMS Victory cross-section - AL
Fram - Occre
Hi Martin
Hi Ken
Thank you for the compliments – using me as a reference is a big one.
The visit I paid to your Fair American was well worth it. That’s a lovely vessel and a fine build. I found that ‘Amati cloth’ you used for sails very interesting. It seems thin and light which is perfect. But on the other hand the texture of the fabric is still too visible for that scale. That means the search for the perfect cloth continues.
But anyhow – ‘…almost presentable sail…’ might be a tiny little bit of slight underestimation of your own work.
Hi Pucko
Thank you for the visit and the compliments.
Sorry for the long time it took to answer but I was abroad again.
No, just to about every second shroud to avoid the problem you mention.
Cheers
Peter
The sail was attached to the yard and that to the mast similar to the main topgallant sail. No special problems there.
Only that I found somewhere halfway through this work that I did overlook the bowlines which the plans show attached to the bare yard but of course should have been bent to the sails before furling them. Well, you live and learn (and use bad language).
It is another fine detail of the kit to include them in the plans and I will find a way to include them in my build.
I’m now finishing all the lines and ropes which are belayed along the centre line (centerline for those who don’t have the happiness to count themselves as one of Her Majesties subjects) and continue then outwards and forward finishing the rigging.
post-504-0-62588300-1412254295_thumb.jpg      post-504-0-14738600-1412254298_thumb.jpg
Edited by flyer
Hi Peter,
Lovely work on the sails mate, I don't have any sails on my Aggie and it's too late but you make want to put them on my next build.
Thanks for showing your method.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Hello Peter,
your rigging Looks very well, and I again took a dive into your log......
I have two questions,
a) noticed that you install a jib stay attached to a traveller (neighther shown nor mentioned  in Amati drawing). Is the seperate jib stay always used in combination with the jib sail, instead of attaching the jib to the fore topgallant stay ?
I can imagine that Setting the jib (Access to...) is easier when it is hauled out on the jib boom per outhauler lineand over sheave roll in sprit-boom tip. Also the common sail lateral Point can be set a Little Foreward or aft to trim the ship on course by opperating the traveller
B) as the seperate jib stay (when the traveller is hauled out) would require some additional length compared to inhauled Position, you probably have arranged for a sheave roll in the upper foremast, for allowing the appropriate jib stay tension as well as an block supported  tackle down on deck ?
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Hi Mobbsie
Thank you (and all of you) for the appreciation of my sail work. That really helps through the tedious part of sailmaking.
Take care
Peter
Hallo Nils
Yes, according to James Lees, it seems the jib was, after its introduction around 1705, either set flying or after about 1719 on the jibstay. The stays lower end was being seized to a thimble on the traveler while its upper end rove through a block stropped to the topmast cap on the starboard side. It was then led down to the stool abaft the fore channels where on small ships it was hitched around a deadeye. Its size was about 0.5 of the fore topmast stay.
What you say about shifting the traveler to change the position of the center of the force on that sail to balance the ship is excellent – I never thought about that possibility. You think like a structural engineer. On the ‘upper’ end of the jibstay (which is hitched around that deadeye) you could have some excess length to adjust to the shifting of the traveler. On larger ships, by the way, that end of the jibstay was secured by means of a fall which made adjustments even easyer.
Very interesting questions!
Take care
Peter
Peter,
thank you so much for your explaining comments relating to the jib and its rigging.
Unfortunately I am not Holding the volume IV of David Antscherl`s Rigging the Swan Class, which probably may have given the one or other answer as well, but with your Kind comments I see I`m not laying wrong there.
The Position and size of all of the stay sails and spanker is also a bit of tummy Feeling, but I trust I`m not too wrong with it. I wish Amati would have provided an extra sheet for all sail rigging.
The reason for doing (preparing for) spanker and staysail rigging as next sequence is for better Access to rigging-  and belaying Points before the Yards and squaresails are rigged on.
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Mike
Thank you for the compliments and I’m really looking forward to a build with the quality of yours showing sails!
Take care
Peter
Hi Nils
There is a lot of information about the size of the stay sails in the mentioned James Lees’ The masting and rigging of English ships of war.
I noticed that it is still available on Amazon for 75$ in used condition. I bought my copy in the museum shop of the USS Constitution and don’t remember what I actually paid but the price printed in the book is 40£. If you could squeeze it into your budget I would highly recommend buying the book.
The size of your sails accomplished with the help of your tummy however looks right to me although I didn’t check all the measurements.
While strolling through the wharf I managed to take some pictures of the jibstay…
lower end of the jibstay on the traveller
'upper' end of the jibstay hitched around the lower deadeye of the starboard topmast backstay
Take care
Peter
While I was trying to install all the rigging which is belayed somewhere on the centerline simultaneously I realized that also the spare spars and the boats must be set on their place at the same time...
Lashing the spare spars
Working on lashing the spare spars while tripping over all the loose ends. It’s high time the bosun has that deck tidied a bit...
Hi Peter,
I very much like your pic illustrations and thank you for your comments along with These. I`ll be on watchout for the James lees book
Nils
Current builds
-Lightship Elbe 1
Completed
Peter,
As usual nice update. As Nils mentioned great pic. compositions...
Michael
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Peter,
your Suggestion to look out for that book....., I found a second Hand one from a dutch antiquariate (already ordered) at a good reasonable Price, am curious to hold it in Hands and to study it in a couple of days.
Many thanks for your tip
Nils
Current builds
-Lightship Elbe 1
Completed
Have you cut your reduced version of the spanker sail yet?  I'm interested in its shape and any other tips you might have.
Thanks.
Ken
Completed Builds:
Well, I took some time to respond to the last posts and the wharf was rather quiet as well.
The reason is that I experienced a radical change in my life: After my last flight (to Singapore) I’m now a retired skipper with a lot more time for shipbuilding. That change was celebrated with a two-week-stay on the beaches of Florida. There weren’t many ship models to see – the Mel-Fisher-Museum in Key West shows a lot of very interesting artefacts but only one, rather simple, ship model – but the sea was lovely and most of the mojitos as well – again cheers to Sir Francis Drake! :cheers:
After 34 years of fortunately accident- free flying I’ll be earthbound again (but plan to remain a flyer in that forum) and will happily enjoy my freedom of any fleet chief pilots or board members  (and plan to find out if there will be more time for shipbuilding or if it’s true that retired gentlemen have no time at all...).
Last flight into Singapore...
Back to serious business...
The spritsail yard (no sail) is being hanged onto the bowsprit. I try to finish the last of the rigging in a working order that enables me good access to the actual belaying points without blocking the way to future ones – and sometimes nearly am successful.
Spritsail yard being attached
Hi Nils
Glad to be able to help a bit.
Actually I am really curious about how your superb build will look after  you assimilated all that information … ;):)
Cheers
Peter
Hi Michael
Just lucky shots, I think…
Thanks anyway.
Peter
