Hello Peter,
the stowed boats and the sprit topsail on the jib boom are looking great.
You did a good Job on tidying up the decks and loose lines, etc. All Looks neat and crisp now, very nice apeal...
Nils
Current builds
-Lightship Elbe 1
Completed
Hi B.E.
Yes, your solution looks good – in every way.
And all the best wishes for you and all in this forum.
Thank you Nils.
But those pictures only show half the truth. The other half looks like this…
(No wonder the bosun is quite beside himself shouting for right seamen to clean up that mess.)
Merry Christmas and a happy new year!
Peter
Now the first of the staysails, the fore topmast staysail was made. For the dimensions I used the data in Lees. The result was checked on Pegasus and in comparison to the proportions on HMS Pandora according to the book of the ‘Anatomy of the ship’ series. Both showed that the sail was too large. I corrected it according the proportions of Pandora’s sail. Then its size was reduced by about 40% (the sides were reduced by 20%) because the intention was again to show it furled.
The sail was bent to the preventer stag and the necessary lines attached.
Furling was quite tricky and after several tries the result seems acceptable for me, but I hope neither the bosun nor captain jack will have a closer look at that sail before it will be fully set the next time.
The sail maker is putting in the last stitches. The four different sizes in the drawing are: First full size according Lees, full size according Pandora’s proportions, reduced first size, reduced smaller size – final version.
The sail is being bent to the preventer stag
The sail seems rather small but proved to be still quite large to be stowed...
Stowed sail
This is not a full harbour stow ready for an admirals inspection. The sail is supposed to be ready to be used on short notice.
That staysail really adds a new dimension -- it's more than just a furled sail, it has the look of weight (if that makes sense).
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
That is seriously nice work on your sails. Great photos too. It inspires me to try the furled sails but a while to go before I get to exercise that decision. The sailor figures make it alive. I have a shouting bosun from Amati. I might try to paint him...
Edited by aliluke
Cheers
Alistair
Current Build -
Hi Martin
Well, sails shouldn’t be too heavy but here I understand weight in a sense of substance and not just a whitish ornament somewhere on a yard. At least that’s what I want to create. Of course if I wanted real substance I would have to mount full sails – maybe I’ll try that with my next project.
Hi Alistair
But be warned: The more realistic you paint him, the louder he shouts! A real bosun could be quite deafening, I read somewhere.
Cheers
Peter
Hi Peter,
Just catching up with your build, beautiful detail and rigging work all throughout Sir, and your furled sails really enhance Pegasus very nicely :)
Best regards,
Aldo
Currently Building:
HMS Pegasus (Victory Models)-Mothballed to give priority to Triton
HMS Triton (first attempt at scratchbuilding)
Past build:
HM Brig Badger (Caldercraft), HM Brig Cruizer, HM Schooner Ballahoo
Hi Aldo
Long time no see. It’s nice to have you back. Thank you for the comment.
Cheers
Peter
During the collection of facts about the jib sail I found that the traveller needs a hook for the sail. I amended one made of an eye pin.
The sail was made in a similar way like the topmast staysail. It was bent to the jib stay and furled. Despite the by 40% reduced surface the furled sail still made quite a large packet. But the sail is quite large and I hope the proportions are correct.
During the photo session I found that I forgot the sprit topsail yard lifts and installed them. Now just a few braces remain to be installed and the cleaning up of the forecastle cannot longer be postponed.
By the way - during all that work on those sails I had to tighten several already installed lines and was glad that most of that installation was provisional only.
The new hook on the traveller is not yet painted
Jib is finished
The jib is set
Detail with the traveller
The furled jib (and the missing sprit topsail yard lifts)
The lifts are installed
Peter,
Jib traveller Arrangement an the furled stay sails look very nice sails, just about ready for command..... "Attention for Setting sprit sails..."
Nils
Current builds
-Lightship Elbe 1
Completed
That's an interesting detail with the hook on the traveller.  The picture of it in use with the sail makes it understandable, though.  Fascinating to see it all come together.
Cheers,
Martin
Hi Martin
I am astonished myself how some details suddenly can make sense (and therefore have to be added subsequently - much more tediously of course than it would be if you did it right the first time – but who said ship modeling is pure fun?).
(Nevertheless – it is!)
Hi B.E.
As always your generous comments are highly appreciated.
Yes, I even have my own way to make coils with the loose ends of the running rigging. Standard procedure for most modelers seems to be to cut the line near the belaying point and make separate coils to hang them over the belaying pin or knighthead. When I started ship modeling I was not aware of that technique and drudgingly made the coils out of the real end of the line by winding it around the belaying pin and the end of a needle file 3to 5 times. The coils were then fixed with diluted white glue which can be dissolved again with water in an emergency.
Every now and then, when I have to reset a line which I thought was definitely fixed and trimmed, I was glad about the excess length. Without it I would have to completely remount the complete line. Therefore I stick to this technique, cumbersome as it is.
Take care and enjoy a very happy new year, all of you
:champagne-2:
Peter
Hi Frank
Thank you. Of course my Pegasus looks much too clean, but those flying beasts never catch that much barnacles and fouling matter as your ships do. ;)
Cheers
Peter
After cleaning up the forecastle the remaining braces and the missing lines on the gaff and boom of the mizzen were installed. After belaying all those lines – rigging was finished!
There remains still a lot to do: More gun port lids are already installed but there are still two remaining to be made. Also the rails of the main and foretop are not yet there. The safety/emergency steering chains of the rudder must be fixed and the anchors are not yet stowed. Also the hammock netting is still partly missing. And finally the slightly reworked lantern still waits to be mounted.
All the lines on the forecastle are belayed
The remaining braces and other lines on the quarterdeck are in place
The quarterdeck is cleaned up, but the rudder safety chain is not yet finished and the lantern is still missing
The colour scheme on the foremost gun port lid follows the colour on the fuselage
The rail of the mizzen top is in place
The anchors are still missing but she already looks quite good
Bravo, Peter, that's a huge accomplishment!  :cheers:
But I didn't know that a ship had a "fuselage" -- maybe the winged horse transforms the hull?
Cheers,
Martin
Hi Martin
Uups! Either it’s ‘déformation professionnelle’ or you are right.
Cheers
Peter
Edited by flyer
Great looking Swan Class Peter,
Trust the end of this building yourney is already in sight, in all a wonderful building documentation and Inspiration for others
Nils
Current builds
-Lightship Elbe 1
Completed
Hi B.E. and Nils
Thank you. :blush: :blush: :blush:
Yes the end is near(!) but fortunately the next project is already waiting on the shelf. I did think of the Titanic as a change from all that knotting and splicing but after a comment of the admiralty about how plain such a steamer looks without any rigging (I took this as a hidden compliment for my rigging skills) I switched back to my idea of an improved Pickle.
Cheers
Peter
The rudder chains are in place. I used a simple arrangement which is depicted in W. Zu Mondfelds book as fitting for the period.
The lantern was fixed with 2 additional diagonal struts in a way which I found in a book about HMS Pandora.
I was thinking to rework the rather slim posts for the swivel guns into an octagonal shape but decided against it (out of sheer laziness). Instead I strengthened the tops with iron bands made of cartridge paper.
Rudder chains in place
Lantern added
The tops of the swivel gun posts are strengthened with ‘iron’ bands
beautiful Detail Peter,
very nice quarter aft shot, all fits great into your Color scheme
Nils
Current builds
-Lightship Elbe 1
Completed
Lovely, simply lovely, Peter.  Wonderful details, and tidy craftsmanship.
I'm curious about the rudder chain configuration -- who is Herr Zu Mondfelds, and what's his book?
Cheers,
Martin
Hi Nils
Thank you. I have to do my very best in order not to lapse too much behind the standard you are setting. :)
Hi Martin
Thank you.
Wolfram zu Mondfeld is THE German authority on ship modeling.
His book Historische Schiffsmodelle is one of my main reverences. There exists also an English version Historic Ship Models. It is still available in bookshops.
Cheers
Peter
Thank you Timmo
I look forward to see your fantastic Granado setting some sails!
