That is some really fine work there, Peter. What adhesive did you use to attach the photo-etched and cast parts? The transom looks so neatly done. The MKK worked well for the panes. I have some ready in my supplies for when I get to that point,it is good to see what it looks like when applied.
 John
Thanks John,
I pretty much use Gorilla PVA wood glue for everything (except rigging of course). It glues more than just wood, takes long enough to cure to move things around if necessary and any excess can easily be cleaned or peeled off while it's curing.
Up to this point in the model I only used superglue to help glue 2 parts because I needed the instant "hold".
Peter
Current Build:     USF Confederacy 1778 - Model Shipways - 1:64
Completed:         US Brig Syren - Model Shipways - 1:64
                        San Francisco Cross Section - Artesania Latina - 1:50
Future build:        HM Granado - Caldercraft - 1:64
                        LeRenard - Artesania Latina - 1:50
A little progress on the rudder. I remember I had a lot of problems with fitting the pintels and gudgeons on my Syren build so I plan to take it slow. I might try soldering the pins onto the pintels this time. Using CA glue on the pins isn't very strong and gets messy when things don't fit 100%.
Here are some photo's. All dry fitted up to this point.
Thanks for the likes everyone.
Here is the continuation of the rudder efforts. I did try soldering for a bit but this was a big fail. Too flimsy to hold the parts in place and I couldn't get the solder to adhere to both parts. So CA glue was used as the next best option. I'm pretty happy with the result. I managed to be able to take the rudder assembly on and off the stern post as intended.
Again, Thanks for the likes everyone.
I have added just 3 photo's this time with not a lot of progress. I decided to add the ropes to the stern port hinges, try to simulate the bolt heads to the pintels, gudgeons, keel plate and horse shoe plate with some CA (with mixed results).
I also added small pins to try to accentuate the stern port hinges a bit.
After I took these photo's the rudder has gone into "storage" until the end of the built. A pin came off one of the pintels when putting the assembly back into my working cradle. The rudder was slightly angled, didn't make the slot and jammed a bit.
So to avoid future mishaps, while using the cradle I won't have the rudder assembly fitted.
Here is an update on the progress with chapter 9, the planking of the Bulwarks. WelI..., maybe a bit more than just progress, I have basically finished them. I only still need to paint them red.
When starting to look ahead at the next step, the margin planks, I noticed that the curve of the most forward plank doesn't match my model, there is quite a gap. So I used Chuck's jig to laterally bend the hull planks to give the margin plank a bit of an extra bend. I added a photo. I'll find out tomorrow if it worked or not.
The last photo I just added to show my work setup (in it's un-edited messy state...);
Peter, that’s what my space looks like when it’s tidy! Your Confederacy is looking very nice! Great work. The futures so bright you gotta wear shades.
Current build: Model Shipways “Confederacy “
Completed builds:
Mamoli “Royal Louis“
Mantua “Royal Caroline”
Scratch 1/4 scale gondola “Philadelphia”
Scratch “Hannah” from Hahn plans.
Thanks again for the likes and comments. Time for a progress update with a few photo's.
I added some red to the bulwarks (makes a big difference to the appearance of the model, almost feels like I'm getting somewhere...., for a little while.), added the margin planks and the waterways.
The extra bend to the margin planks made the fit a lot better.
Next was the checkerboard floor panel. I have been concerned for a while about getting the strips accurately cut with a scalpel only and have been playing with the idea of getting a cheap or secondhand 4" table saw. In the end I didn't trust the cheap Chinese options, couldn't find a secondhand one and end up just going for it with the scalpel....lol. I shouldn't have stressed as the result in my humble opinion is quite acceptable.
Here are some photo's (in random order).
Keeping the log going with a few more photo's. This time with the work done on some of the gun deck hatches and gratings. The bricked platform was a challenge, not sure if I nailed it (actually I'm pretty sure I didn't nail it...lol) but I'm sort of satisfied with the outcome and happy to move on.
Very nice work! As for the brick work, which looks fine, once the stove and drip pan covers 60 % of it and you are looking down through beams and planking, anything you think “is not nailed” will disappear.
I wish the progress on my Confederacy build was behind yours. Your log might have given me the discipline to slow down. You are making a beautiful ship model.
Completed builds:
16 hours ago, Ekis said:
A particularly neat and precise shipyard: bravo! 👋
Thanks Ekis.👍
Very true. I did actually have a look at the stove coverage and the location in relation to it's surroundings and gave it my own thumbs up. I'm sure the brickwork on the actual ship didn't look 'new' as well after a few years worth of cooking (just aiming to be authentic here.....cough, cough)...lol
I can't believe how fast you are going. I'm already past the one year mark and expect to tack on at least another 2 before I finish. Yours looks almost finished after only 8 months. And the speed hasn't diminished the quality at all. It's a beautiful ship...
  • 3 months later...
Hi WalrusGuy,
All is well, thanks for asking. I lost my Mojo for a while and noticed I started to make silly mistakes. So I took a bit of a break and covered the model up for a few months. When I got going again with building the 12 pounder cannons, I didn't take a lot of photo's, so this log entry is a bit of a jump from where the model was at with my previous entry. I'll try to create more regular entries again.
Another small log entry. I am undecided if I will add the gun tackles or leave them off. While mulling this over I decided to spent some time on the deck fittings. I needed a break from the cannon build anyway because it was quite a marathon effort.
The rudder trunk are capstan are finished and I made a start on the ship's stove. The photoetched and brass bits on the left are all blackened which I prefer to painting. I has a better "metal" look in my opinion. And the painting option is still there if the surface gets scratched or damaged.
Thanks for the likes!!
Well the ship's stove is finished so I have attached a few photo's to show what it looks like. A fiddly but fun little project.
Thanks Vladimir and thanks for the likes as well.
I ended up deciding to add the gun tackles as well. So the break in working on the guns and doing some deck fittings must have helped...lol.
I have started working from the aft and doing them in sets of 4 or 5 so I can continue building up the gun deck following the instructions.
As this point 4 sets of guns are done and I have added the aft bulkhead.
Here are a few photo's.
Excellent model Peter. She is an absolute beauty! Doing a few tackles as you go sure helps with the sanity end of it.
Completed builds:
Thanks Bossman, Chuck and PRS and also thanks again for all the likes.
Well, the speaking tube with tube bases, mizzen mast coat, ship's wheel ropes, hanging and lodging knees and second bulkhead are in. Before I can continue I need to get the next 4 sets of gun tackles done (sigh) so it's a good opportunity now for some photo's.
Here she goes...
