Sometimes the simplest of jigs provide the best solution.  Very creative and the excellent result speaks for itself.
cheers
Pat
That is some superb and incredible small-scale joinery Richard.
cheers
Pat
Edited by BANYAN
cheers
Pat
Probably an excessive investment in time given what a minor component this chair is of the overall model....But I've found it an interesting challenge to see what I can achieve with a hard, fine grained wood and a Unimat lathe/milling machine..
This project has been going on for so long now that I tend to see it as a series of sub projects and get my satisfaction from each of them rather than targeting overall completion...
Hopefully, Ill get there one day, but then Ill have to find a rather large area of the house to keep the model!!
Seating for the seat (?) installed on the quarterdeck. I've taken a piece out the planking between the morticed longitudinals to allow the seat to be lashed down the to the deck as shown in the trireme seat drawing. This differs from the drawing of the quarterdeck (extract shown below with the photo of my model) which would not have allowed for the seat to be lashed down in this way.
Trierarchs-seat-seating.jpg.b06703323bc8fcb0bc112a93bc73ebfa.jpg.20ae89873b32ef5724270098de2befe0.jpg
Edited by Richard Braithwaite
A view of the seat frame located on the quarterdeck compared with a picture of the full size Olympias. I have built my model as closely as possible to Coates design drawings (the drawings sheets contradict one another in some cases - as you would expect from what was essentially a prototype for a reconstruction of a warship which hasn't been built in living memory...). These include:
1.Differences in framing of the stern.
2. Removal of the footrest from the Trierarch's chair.
3. Differences in the leather upholstering of the Trierarch's chair.
4. Removal of the handhold post at the head of the ladders from the quarterdeck to the gangway.
5. Additional bracketry alongside the steering oar slots.
I am sure some of these changes were incorporated at build and others were introduced as sea trials progressed. Not unlike my own experience of  designing  and building modern ships!
Now the main structure of the ship is nearing completion, will the next stage see the start of the masts and rigging, because I am highly intrigued how this will be brought to life matching the mind blowing quality of the ship so far.
Will get round to the rigging in the end... Don't think I will make sails though. My main interest is in the oar system...
Insallation of the ladders on the model.
The left hand image shows the aft end of the gangway and part of the helmsman's platform with the aft canopy sections removed. the brass lined holes in the deck are to locate the pins on the base of the ladders. The brass lined hole for locating the aftermost stanchion of the aftermost canopy sections can also be seen in the deck beams just outboard of the gangway as can the bolted lodging knees that are part of the system that enables the unbolting and removal of the entire deck assembly.
The right hand image shows the ladders (and the aft canopy sections) installed.
1930111187_Quarterdeckladdersinstalled.thumb.jpg.19d25269a950bf3b89a25f06245818d1.jpg
Finally a view of the ladders, quarterdeck (with Trierarch's chair!)  and helmsman's platform looking aft from canopy level. The slots in the quarterdeck (with the turned rollers) are form the steering oars to pass through which are fitted with athwartships  tillers controlled by the helmsman standing on the platform in front of the Trierarch.
An Athenian Marine...
I've been looking for a scale wooden artists manikin to demonstrate ergonomics of rowing equipment geometry etc. but they are all on much too large a scale for my model. So I decided to have a go myself at a 1:24 version.
For the dimensions I found a good source of ergonomic data for US Marines (https://apps.dtic.mil/sti/pdfs/ADA581918.pdf). I took the data for the 50th percentile marine and scaled it according to the mean height of a classical Greek male (approx. 5 ' 7" as identified from  Archaeological studies of skeletal remains  ref  S. C. Bisel, J. L. Angel, "Health and Nutrition in Mycenean Greece: A Study in Human Skeletal Remains," in N. Wilkie, W.D.E. Coulson (eds.) Contributions to Aegean Archaeology: Studies in honor of William A. MacDonald (Minneapolis 1985)).
Given both US  Marines and Athenian oarsmen are likely to be of a similar muscular build, I thought this approach would give a reasonable approximation. I know that trials on the full size of Olympias had some difficulties fitting 20th century oarsmen in some of the rowing positions...
Anyway the resulting model is shown below:image.thumb.jpeg.4a276ecd4e957c9746291419ef80b470.jpeg
I've used two sort of joints to give the required mobility:
1. ball ended pins to simulate the ball and socket joints of the shoulder and hip (and the rotational joints of the neck and heels)
2. simple one degree of freedom pin joints for the knees and elbows.
This works for an oarsman at around midstroke as shown below:
And finally standing on the helmsman's platform of the model to give an indication of scale:
I'm planning to make 3 of these manikins so I can check the arrangement of the rowing equipment (seats, stretchers etc,) on the model for each triad of oarsmen.
The manikin is a brilliant idea.  Many of use "fixed" figures for scale but have one articulate for rowing is a better plan.
Looks a little "robotic" though. Hopefully can use them for illustrating how the three tiers work together through the rowing stroke.
I don't think I will be making 170 of them though...
Agree with Mark, the idea and construction of that mannequin is a very clever idea.  Robotic or not, it is a great way to visualise the ergonomics and rowing techniques.
cheers
Pat
I've seen quite a few model galleys with working oars, but very few of them have an action which ties in with what is observable from the Olympias sea trials video (link on the first page of this thread). From the accuracy of your build so far, I'm hoping yours will be more like the real thing.
Steven
Removed the canopy sections so I can start to install the oar seats etc for the lower level (Thalmian). Probably should have done this earlier in the build, but the ability to dismantle my model helps me get away with it!
First photo shows the longitudinal stringer that supports the inner end of the Thalmian beams installation using a jig to ensue the correct vertical location. The next photo shows a couple of Thalmian beams in place with a plywood jig to fix the 3 degree rake. The deck beams, walkway, inner stringer etc. all comes away as a boltable assembly, which means I can only fix the inner ends of these beams. The outer end is left resting on the Thalmian stringer. I'm hoping that once I have installed the seats and stringers (which connect the beams longitudinally) this cantilevered arrangement should be stable enough...(Extract of John Coates Midship Section Drawing © Estate of John F. Coates, reproduced with permission.)
Inclusion of drawing extract with permission from estate
First Thalmian (lowest level of three) Rowing position in place (minus the leather foot and heel straps. The small dowel in the stretcher is used to locate the footrest and allow some adjustment for the rowers leg length. These foot rests are pretty much hidden underneath the seats once they are all installed.
(Drawing shown is an extract from John Coats Plan No 9 titled "Trieres Foot Stretcher" © Estate of John F. Coates, reproduced with permission)
Drawing extract permission
A little animated gif of my the manikin at this thalmian position. His rowing technique leaves something to be desired (!) but he does illustrate one of the difficulties of the design. The limited space between the deck beams meant that these rowers tended to his their heads at each end of the stroke. It was a particular problem at the finish and could be dangerous if anyone caught a crab… They mitigated it on trials by putting the smallest rowers in these positions (I based my Manikin on a 50% 600BC Athenian build…) and fitting a restraining rope to the oar so that it wouldn’t break their necks if they caught a crab. Not ideal, and the power delivered from this level suffered accordingly. One of the issues to address in any Mk II design…
Just noticed that his foot rest had dropped and disengaged from the locating dowel. Should have lashed it tighter... oops!...
I think my manikin achieves about 720mm of the full 800mm design stroke. I have modified his joint already to make him a little more flexible but he still had problems pulling the oar right into his torso at the finish of the stroke (as you can see from the GIF above). However, I don't think they often achieved the full 800 mm stroke on trials for the reasons given above...
1 hour ago, Ian_Grant said:
Richard, this is groundbreaking modelling!  Poor guy hits the back of his head with every stroke...No wonder they had towels wrapped around the beams in Olympias.
I assume by "Mark II design" you refer to another actual ship, and not another model from you? 😀
I suppose its a good thing that his head is made of wood...
Its taking me long enough to build this one so I don't think Ill be making another one soon. I have been developing a computer simulation, however, which I'm hoping might be useful in supporting some design work to assess the extent to which performance could be improved by optimizing the layout.
