Welcome to our new sponsor - Engine DIY. See banner ad on Home page. ×
First update in a while. Once my company lifted travel restrictions, I've gotten very busy at work, which I'm actually quite happy about, but it has kept me away from the bench more.
Finished the trunk cabin. It's a straightforward build, and the plans are good. The iron bars that make up the skylight framing were a bit tricky. I ended up using small gauge brass rod and they worked out great. It's just tricky getting them all the same length. I ended up sanding to final height with the sandpaper on a piece of glass.  I used boxwood for the skylight, as basswood would have certainly split drilling all the holes for the bars. The porthole rings/frames are not supplied so I fabricated them from appropriate sized styrene tubing. I still need to make the smokehead cover.
Joe Volz
Current build:
Model Shipways "Benjamin W. Latham"
Completed  builds on MSW:
Caldercraft HMS "Cruizer   Caldercraft HMBV "Granado"   Model Shipways "Prince De Neufchatel"
Nicely done!!
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    Hs129B-2 1/48  SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32   IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48  Eduard Sikorsky JRS-1 1/72
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
I love the little details that you are adding to your model. Those details are what make a good model a great model when they are done well. Nice work!
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Always love to see your posting Joe...learned so much from you. I love the additional of the dory. A simple craft but so beautifully constructed. You have to appreciate the 1/48th scale. Nicely done Joe.
Bob
Bit of an update.
The model is mounted on it's baseboard, which is made from rosewood, with two simple brass rods to hold it in place. Rare event for me to get this done so early, as I'm usually trying to carefully mount a fully rigged model! I also completed a number of deck fittings such as the main and fore hatches, the galley hatch, the wheel box, dory cradle, quarter bitts and a few other little things. It's fun to have to scratch build most all of this as MS only provides wood and plans.
Joe Volz
Current build:
Really nice work Joe!  I love the lettering - looks fantastic!  Did you find that you had to double up on the white lettering or was a single decal sufficient on the black hull?
I stopped working on my Charles Morgan because I haven't quite figured out how I was to do the lettering.  Dry transfers are going to be too difficult to pull off I think, and I didn't want to glue paper to the hull.  I've reached out to a couple of custom decal shops to no avail.  I might just try to use single letter decals like you did, and just take my time to get them into the right position.  I was worried about getting them spaced and lined correctly, but it looks like it can be done.  If I can't do it, maybe I'll send my hull to you to decal :)
Mike
Thanks Mike. The letters are quite opaque, even over the black with just one layer. Lining up a second on top would have been fun! It wasn't too difficult to get them lined up as you have multiple chances to "float" them into position, unlike dry transfers where you get one shot. They key was just water, no decal solution, so they don't start to soften. I came back with Micro Set afterward.
They are from Microscale.
Joe Volz
Current build:
Thanks Richard.
I've found dry transfers tough to apply directly on the model. You get one shot at getting alignment correct, whereas you can "float" a water slide decal around into final position. I used dry transfers (Woodland Scenics) on my Cruizer class Sophie build, but  did them on a separately applied name plate.
Joe Volz
Current build:
*MAJOR UPDATE*
I've gotten a lot done since the last update, but as usual have been remiss with the uploading. Some of the deck details such as windlass, fife rails and fore companionway finished awhile ago, and I've just gotten around to installing them. I've also built the box for the anchor chain, and installed the anchor cable which is made with Syren rope.
Masts were turned in an electric drill to taper and the details were added with brass and stripwood. The bands are actually painted paper, which was easier consdiering the taper in that area. The spreader lifts were made form boxwood, as they will take some strain during rigging and I was not going to trust basswood with that task.
The plans are just fantastic with regard to the mast fitting details, and there are still some things to add.
Joe Volz
Current build:
Really excellent work Joe!  So clean and precise, looks perfect.
Mike
Thanks Chuck.
MS gives you all those nice details on the plans, you just have to figure out yourself how to get there, which I enjoy. Ronnberg really knows the subject and produced some great plans. Although, the rigging sheet is VERY crowded, so that might be a bit fun... Chapelle's book is going to be  a huge help there.
Thanks to the "likes" as well.
Joe Volz
Current build:
Just happened onto your build log Joe and wanted to say what a beautiful build.  Hitting the like button was just not enough.   As a fan of these fishing schooners, it is nice seeing one of the best.
Allan
Now the topper would be if you are from Western PA and a Steeler fan!!!   Go Stillers......   (I had the good fortune to have grown up in Pittsburgh)
Allan
Allan
HA! Eastern part, and am a lukewarm Eagles fan at best. 🤷‍♂️
Joe Volz
Current build:
Eastern PA ain't too bad Joe.  Our oldest lives in Gilbertsville, not far from Valley Forge.   Beautiful countryside!
Anxious to see your rigging and sails.  There have been a lot of posts lately on making sails. Unfortunately, many insist on using cloth and sewing which is impossible to keep in scale, taking away from an otherwise nice build.
Allan
