Hi Mike. That colour is going to look sweet with the mahogany when you get the Typhoon finished - used a similar colour below the waterline when I did my Miss Severn, thought it risky at the time but really liked the contrast in finished product.
Tim Moore
Perfect is the enemy of good
In progress
DH.9a Ninak, 1/32, Wingnut Wings
Docked for Repairs
IJN Pre-Dreadnought Battleship Mikasa, 1:200, Hobby Boss
On Deck
The Blue Sky Company, 1:48, Sierra West Models
Completed
Triumph 3HW, 1/9, Italeri; Fiat 806 Grand Prix 1:12, Italeri; Fifie 1:32, Amati Victory Model; HMS Bounty 1:48, Artesania Latina; Endeavour 1:60; Corel; Miss Severn 1:8, Legend Model Boats; Calypso, Billing Boats; Carmen Fishing Trawler, A.L. ; Dallas Revenue Cutter, A.L., Bluenose, A.L.
WOW Tim, she is beautiful and that shade of green below the boot topping at the water line really sets it off. I was on the fence about using the same shade of green that I used on the seats for the bottom of the Typhoon and maybe going with a different color altogether, but after seeing your Miss Severn, I'm going to use the same shade of green.
OK, after studying the issue of the rudder access door being under the stern section of the boat and attached with screws and with the possibility of water being able to get in through it, I have found a probable solution. If I remove three supports in the stern section behind the rear cockpit, I can mount the rudder servo and be able to access the rudder from the top and eliminate the access door from the bottom of the boat. The modification will be where the blue tape is located. I will have to make the access door for the top of the stern, but shouldn't be a big deal (famous last words) hahahahaha.
Edited by mtdoramike
Hatch on top totally makes sense to me. A hatch on the bottom of the hull? Wow, never heard of a deal like that before now, and I would do just like you, search for a more viable alternative.
She's looking great!
Can't remember where, but I once followed a complete build of this boat and that's what convinced me to buy one for myself. It is a stunning, beautiful boat when it's finished. The build I followed was a static model and not for R/C.
I would like to build one with an engine bay and a mock-up of the engine. Static scale.
CD, It may have been this build thread from a Radio Control forum. The OP and builder Legendary Pat Trittle did a splendid job on one of the first production Typhoons. https://www.rcgroups.com/forums/showthread.php?291645-Dumas-Typhoon-Kit-Review. If you can't tell, Pat is kind of a hero of mine and I only wish I were as good a modeler as Pat Trittle, maybe one day.
OK, I bit the bullet and started the modifications to the stern by removing two of the rear frames. The critical part of this is, how many bulk heads need to be removed because you have to be able to mount the rudder and still have room for the drive shaft and prop. Ideally, it would be nice to have at least a 1/2" between the rudder and the prop.
I'm replacing the two pieces (K7 & K6), which goes on the bottom of the stern and K6 is supposed to be removeable to allow access to the rudder arm, but since I'm making a new access panel on the top, this is no longer needed. So I'm replaces these two pieces with a solid piece of plywood. My main issue was to make sure I was going to have enough clearance between the prop and the rudder since I was moving the rudder forward about 1/2".
There should be enough room for the motor and the prop. I ordered a Graupner 600 motor for her. It looks like it is going pretty well right now, but one thing I have learned in my old age is, ( for every positive action, there is always a negative reaction and I'm sure there will be one here, but it hasn't shown itself yet.
I started the first layer of planking with the balsa strips. I did what I usually do to most kits and that is to take scrap pieces of wood and beef up the frames, which are 1/8" plywood in order to make them 1/4" which gives me a wider surface to lay the planking as well as more of a gluing surface.
I have the first layer of planking done on the hull with just a bit of cleaning up to do on her. Dumas provides a couple of templates to use to cut the bow and stern blocks from some hard wood or at the very least hard balsa for the nose and rear of the boat. Once glue dries, you have to sand down the blocks to form the contour of the hull.
Happy New Year to you and family as well, yep I have been cat scratch busy the last week or so, but I try to spend at least an hour a day on which ever build I'm doing at the time. Now sometimes I will spend the whole hour just looking at the build and trying to decide if I want to build a certain area like suggested by the instructions or do I want to modify or change it LOL.
I have the top cockpit skins glued in place. There was a fair bit of trimming needed to be done in order to get the cockpit skins to lay between or inside of the spruce side rails. Also, when it came to making the rear hatch for the rudder access top, the hatch sides have to be angled slightly to match the side spruce rails. In order to match angle, I attached to spruce side strips to the thin plywood before forming it to match the contour of the top.
Although I'm building this kit (Typhoon) I do not like this boat. I don't like the shape of it at all. I can't stand a boat where you can't tell whether it's going or coming. If I were building this boat for me to keep or strictly for myself, I would have made some major structural changes like bobbing off the back and squaring it off. Now don't get me wrong, the quality is right up there with the Dumas Chris Crafts, but for personal taste, this boat just doesn't do it for me.
Out of all the models I have built over the years, this is one of the few that I can say I dislike, but even though I'm not fond of it, I will build it as close to the original as possible with the exception of the rudder access modification.
4 hours ago, CDW said:
The boat is unique. It reminds me of a big, fancy, motorized canoe. It's so unusual, I like it.
Speaking of unique and canoes, a friend of mine had a Gheenoe, which was nothing more than a canoe with the stern chopped off. I always wanted one because they were so unique. Well, after my friend got his Gheenoe, he took me out fishing and as soon as we left the dock, I started getting wet from the water splashing as the nose of the Gheenoe hit the waves. I was sitting in the front. By the end of the fishing trip, I was soaked and quickly realized that even though something is unique and looks interesting, doesn't mean that its a good thing. I never owned a Gheenoe and lost all interest in them after that outing.
I know my work area is a bit messy, and I try not to clean it until after I finish a build because usually when I do clean up my work table BEFORE I finish what ever it is I'm building, I end up throwing away something that I find that I need it. For instance: I cleaned up my table a bit a few weeks ago after my wife complained that it was quite messy, well wouldn't you know that I threw away one of the formers that Dumas supplied to make the built up stem and stern post. 😪 But no big deal, I will either make a new former or better yet, I was thinking of cutting out the stern and stem posts from some scrap black walnut that I have laying around, which will eliminate the need for the build up of strips of wood.
