My New project is the St Caterina.  It is a Mediterranean fishing vessel.  Plans from Ancre.  I started it since October and is well advance so far.
  1. I decided this time to go after a old fashion diorama
  2. New tech to aging wood (At least for me)
  3. New tech for nails  (Also at least for me)
Please don't hesitate to make comments
Aging
Once the planking is done I proceeded applying danish oil......
Then with a drill wire brush I went to mark the wood as it was a real weathering or attrition.....
Then..... with cement grout (not that liquid) I proceeded to “paint” the hull. Wait until it is almost dry. Make sure that the grout is going to all the scratches you made with the wire brush
The with a cloth or kitchen towel take the grout surplus.... The result should be lake this...
The nailing has been done with sewing pins.
To the main hull, I cut them. Flat them with a sander belt and blue them. Also I decided to tape the hull in order to protect it. As a drill bit I used one of those pins, it worked really well, and the hole was perfect to ensure the pins.
MORE THAN 1000 PINS WERE NEEDED!!
2B741A3F-602F-42D2-BCC5-9526127ECB10.thumb.jpeg.5bc7af9be11ac4affd8141f6c70386d7.jpegBB2E796B-C9FD-4052-8B80-F06E70EDCDC5.thumb.jpeg.c51d23abfb6579cdc61f6f00e18b9313.jpeg572D0D2B-5C26-48A9-8E25-85A0E78586FE.thumb.jpeg.458a028abce64996f24f60d21aa0aa5e.jpegE7803B62-B16F-438E-8E45-899B880205AE.thumb.jpeg.c61dc583dcb46b1c65b3944d86a66910.jpeg043F1B99-A50A-4A89-B6FE-0AE442B4C514.thumb.jpeg.eca05e1f988b2d2bae55b1804b8d7279.jpeg
Today I’ll show you the process I used to build the benches.
First, I cut the templates
D3A25F6D-B793-4CD3-863A-4259AE756A7B.thumb.jpeg.4db619698f994f1b131b42773e75cdf8.jpegF32E39D1-C8C2-4524-9E2A-A891B7BD3751.thumb.jpeg.08b474f956219fb8102651c75e0ab7c0.jpeg
With the belt sander and router, I finished all of them but the middle one, which has this middle circle, where the mast will located
Edited by Hellmuht Schrader
For this particular bench, in order to make sure the half circle will be perfect,  I used doble side tape,  I taped a piece of wood (with the same thickness) beside it.....
I drilled the hole.....
7796C564-111A-4F69-ACF4-5ADF91097003.thumb.jpeg.6759bc028e0b2ad4f55b3fd38e1afbd3.jpeg20D82E3C-36C0-4E10-BC92-88BEA762CCD7.thumb.jpeg.e9ca932a476c0418ba903801fa9733d3.jpeg
Now is time for the top of the gunwale.......at this time you have to realize that the plans are a “little different” to reality...... then make your hull been your reference,  You will realize also that the two sides are not completely identical so..... try your best for make those differences “unnoticeable”
09D76C54-2B5A-442E-BDC9-C62FC2B41242.thumb.jpeg.e76341d6f97335aade98ff0b9b7485ba.jpegAF3DFE7C-A1AE-4A60-9B43-7D25B8AAA84E.thumb.jpeg.30e2cc82ef2c24b5d3a90e6db05f024d.jpeg
Of course... we have to aged them.....For this I took a note about where the oars should work, the ropes will work and I put a little more attention to those sites.....
Also I needed to fabricate some cleats.....
F4037B1A-8F83-4459-AD01-C62C37F94DC1.thumb.jpeg.9c820a9d6c5b28ea19b4173511f5830b.jpegD899E430-5800-432E-8FF1-644472DF24C4.thumb.jpeg.44dc0ba66223a4cf310649257bb62cef.jpeg59C5CFB0-76FD-47AB-8896-7526A0484D35.thumb.jpeg.6f72d9f6f056da8c732320972f30437f.jpeg7CBAC248-4DB0-43D2-8D24-8106AE2674AB.thumb.jpeg.1d21bdb8f181e687cbe25de4a8983a1e.jpeg6B71327C-7825-430F-9706-5D1510D102C8.thumb.jpeg.6778355a278c2aae138d943a57493cf7.jpeg19442555-9513-42E7-8811-89BD27B62723.thumb.jpeg.5a125abfc2cc22d205dc10808c57a378.jpeg0B5D3FC1-2415-4ED4-9F45-978DFD949256.thumb.jpeg.f7808c62f5cddbb5fd1161fd44fad922.jpeg
Then.....
In the meantime I have been working in some fitting for my diorama......
Buckets
I take 20 wedges with 15 degrees angle
To the lathe....
The scale and form....
Internal hole also with the lathe....
Brass reinforcements....
And this is the scale...
You're doing a fantastic job on this beautiful model! I'm hope to be able to eventually begin to build a model from scratch and this model is one that I have been thinking about. Do you think this would be a good model for a first time scratch build?
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Hi bob
I don’t know if you got my message.  Yes I would say that the armed longboat and the St Caterina are the “right” way to start.  The armed longboat has a lot of videos, tutorials in YouTube.  Most in Spanish but graphically well explained
regards
