Messerschmitt bf 109G cockpit by cog - Eduard (brassin) - 1/48 - FINISHED
Since I have little time, I left my SMS Seydlitz in her mothballs and picked up this little build.
Resin partsbrass PEMetal PE
The only thing I can say: "it is small!!!" and it is almost finished before you start it ;)
Resin and PE ready for painting
Base coat "Black base" with chrome - both AK extreme metal colours - enamels
865764632_Untitled-1copy.thumb.jpg.915b41d3963ad5845c8542c3ee61f943.jpg1187685916_IMG_2677copy.thumb.jpg.cba7a44cec69c7c38c8e9cb641b90b3f.jpg1470040409_IMG_2674copy.thumb.jpg.896adae5cec47622a486459f4d9c096f.jpg734548540_IMG_2678copy.thumb.jpg.408510967fe05fc3fcd1a1677c53c513.jpg
Base colour is RLM 66 some details filled in with colours, and metal PE which has been prepainted - Vallejo acrylics - added a bit of wear and tear
856698579_IMG_2682copy.thumb.jpg.7ffe4540dee5323ff26b154330410b3c.jpg1577378302_IMG_2681copy.thumb.jpg.fb3a617ceb6c83cf6593e7ad76a0e2d2.jpg2070150697_IMG_2680copy.thumb.jpg.b19390f0470a11983970eb1bafa6178d.jpgfinished.thumb.jpg.1e9394d2bb01aa65ee1a3f2499498300.jpg
Getting the PE, resin, and plastic fitted took the better part of an eveing, painting took in all about 1.5 - 2 hours. Quite a fun model to build despite it's size, lot's of detail on the resin parts too
Cheers
Edited by cog
Carl
good to see your back at the table Carl..........look really good ;)   nice start!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Same from me carl,   that is some lovely detail work you have done  - lovely job.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Thanks OC. Need to get my bearings back on building to get that big German b....... out of it's mothballs. I think these small and quick builds might just do the trick.
Carl
It really is nice seeing you back my friend.
OC.
Current builds
Completed works.
Like the others I like seeing you back again Carl and being amazed by your work.
It astounds me to see how detailed and finely finished this tiny cockpit is.
To be honest I am a little jealous as well, your skills, like a number of others here, are way out of my league.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Wow! Nice work! Detail to the max! You need to tell me how you did all that detail - ever want to do a tutorial build?  😀 I guess references are half the battle? Is that all eduard detail stuff or do you use wire,solder etc to enhance?
You give me to much credit Lou, thank you
Hello Assat, thank you for your praise. It is all Eduard. They have "Brassin" kits which you can use to enhance your - mostly -  airplane kits, and these are full of detail. A combination of resin, plastic, and PE (both metal and brass).
Have a look at their BRASSIN kits
As for tutorials, I am still learning, but this bloke does make nice tutorials PLASMO
Carl
Carl , are you building this Bf109G on the installment plan, ala the Dagostini models? ^_^ My aircraft model instructions always seem to start with the cockpit and eventually progress through the rest of the build. So, you're awaiting a DB605?  It will be a good build when it appears, Carl.
Ken
Started: MS Bounty Longboat,
Sitting here eagerly awaiting to see more mate.🙂
OC.
Current builds
Completed works.
OC.
Just a cockpit build mate ... nothing more, nothing less
Carl
Cockpit is better than no cockpit  - imagine the pilot trying to fly without it🙃
OC.
Current builds
Completed works.
Carl, where's the fun in just a cockpit. Geewhiz, mate. We want to see more to that airplane. So, you are not expecting anymore parts to continue with this build. OK, I get it. I'm just a little too literal sometimes.
And there is no wayinell I'd ever say anyone is dumb, especially looking at the artistry displayed by the folks on this forum.
P.S. The DB605 is the Daimler Benz engine of the Me109G
Ken
9 minutes ago, RGL said:
It’s just that he likes to be in the drivers seat
No driving seat in a plane though.
OC.
Current builds
Completed works.
So just the cockpit is a flight simulator?  Works for me.  I did a number of manuals back in the day for real simulators that weren't much more than that.  But did some with full blown graphics and hydraulics to give a sense of movement.
perhaps you might find a 1:48 plane to put it into?  they are an interesting plane with many variants ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
......it's got camo /.........oooh-la-la!  :ph34r:
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
it will be Denis ... it just hasn't arrived yet. I want to build one with a detailup cockpit, engine, radio room (more like a box), and wheels. That should keep me busy a few days ... four seperate builds in one ... add a cloak of invisbility ... and the camo is complete too
By the way, presently working on a Spitfire IXc 1/48 engine ... should fit snuggly in OC's build ;)
Edited by cog
Carl
Sounds interesting, is it the Brassin  one?   I have heard good things about that.
OC.
Current builds
Completed works.
1 hour ago, cog said:
Yes it is. Very fiddly bits
Dont tell Greg about it  - he would have you  doing all sorts to it.🙃
OC.
Current builds
Completed works.
Hence I am :P
6 hours ago, RGL said:
I’ve just seen another shiny thing
  Your wedding ring :huh:
Carl
Thanks Kevin. There will be more logs on some other BRASSIN kits for the bf 109G-6. The engine with gunb assembly, and radio compartment  just haven't arrived yet <sigh>
Carl
Well done!
Building:
1:200 Russian Battleship Oryol (Orel card kit)
Completed:
1:60 Sailing Sampan Good Fortune (Amati plans)
1:200 French Ironclad Solferino (Orel card kit)
1:72 Colonial Schooner Hannah (Hahn plans)
1:72 Prince de Neufchatel (Chapelle plans)
