I'll look into it
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Not my original intention... :P
And I firmly believe that when it comes to these sorts of things, I usually only get lucky once... So mass production is out of the question... ;)
Although I did PM Robbyn something that might pass for instructions, I may have her scared off making her own as I haven't heard back as yet...
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
Nice Andy...
If you find some way to attach a hook to one end you can strop blocks as well...
As I'm no engineer I have to ask if there is a specific reason why you spaced the crank axle and the tube with the rope with a gear?
Edited by Seasick
Nice Andy...
Because both ends of the rope should turn in the same direction (and in the same rotation speed).
Not usiong a gear and attatchinhg the crank on the 'rope-holding tube' itself will cause the rope to twist.
Jan
Andy how much of the shroud is served - is it just down to the catharpins
All the best
Kevin
KEEP IT REAL!
On the build table
Bounty - Artesania Latina - 1:48 by Kevin - started August 2025 - - Kit build logs for subjects built from 1751 - 1800 - Model Ship World™
My other builds:
Not scared away Andy, I am heading back to Nebraska for the Memorial weekend So on Saturday I will be at model train store. Taking my list with me. Thank you so much for the help!
Robbyn
If you risk nothing, you risk everything!
Current builds
Syren (Model Shipways) version 2.0
AL San Francisco II
Mordaunt (Euro Model)
Completed Builds
18th Century Longboat designed by Chuck Passaro
In the closet
Battle Station
Al Charles Morgan (1980s version)
Jan
No, I mean the gear between the handle and the rope-tube
Eric, the spacing was needed because of the size of the gears. they where the only ones the hobby shop had on hand, so to avoid rapping my knuckles on the spindle I needed to add a bit of spacing. Larger gears would eliminate the need for the idler gear.
Kevin, according to TFFM 4: The middle quarter of a pair of shrouds is to be served. (for example, my mizzen shrouds are approximately 15 cm, x2 means 30cm total length, so a quarter of that is 7.5 cm). Also on the fore and main masts, the leading shroud is supposed to be served its entire length, but whether I do that or not is still up for debate.
Robbyn... ok... I wasn't sure, have a nice trip and good luck at the hobby shop. ;)
Patrick, thank you very much for the compliment, let me know if you want my more complete instructions :)
Anyway.. I hoped to have more done today, but a phone call first thing this morning (not work BTW) had me dashing up north... seems our lake rose 2 feet overnight and a few things where in great peril of drifting away, namely the dock boards, and needed to be rescued.
We got off pretty lucky... a few people at the south end of the lake are going to have problems.. they left their boats on mooring lines a bit too short... and as the water rose... well... the lines got tight and well... they're now the proud owners of outboard submarines.... :rolleyes:
Andy
USF Confederacy
.......you mean like the guy in California,  who burried caddys nose first in the sand?
hee....hee..........and he called it art ;)
Edited by popeye the sailor
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
And me Andy, that's one super set-up, PLEEEEEEESE
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Ok... back to the task at hand.. or rather.... what I intended to do yesterday...
I had started work on the mizzen shrouds and I got about this far. Things were going well, but I had to pause for a moment. I'm wondering if the deadeye lanyards are a bit too long. I'm not adverse to redoing the shroud if the expert opinions deem it so (it is only one pair so far). I've only secured the forward lanyard with a single half hitch so undoing it won't be much of a challenge, and neither will be remaking the shroud again...
Let me know what you all think..
Andy
USF Confederacy
Hi Andy,
Just spent some time reading your log and I have to say what wonderful work you have done on this model.As for the lanyards,possibly,a little shorter,but not much.
Kind Regards Nigel
Currently working on Royal Caroline
Hi Andy,
I don't know who it was saying but the length of the lanyard is 2 1/2 times the deadeye…..
I think It's now to long .
But you are doing a much better job then I do!
Edited by Sjors
yes......2 1/2 times the size of the dead eye is the basic rule....that's what I read in the days of the old site.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Yup... Seems the consensus agrees with me..... In another manner of speaking....I'm not crazy :P
Thanks for the input, and Sjors, thanks for that quantifiable answer... ;)
Andy
USF Confederacy
lovely work,
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thanks David :)
I've just finished serving a replacement shroud, and I'm waiting for the acrylic to dry. That stuff is great to use on rigging.... I highly recommend it for anyone. Not only good for dealing with fuzzies, it has provided extra reinforcement for my knots and servings, and when I pulled the shrouds off, all the loops at the top have held their shapes... (But nothing is too stiff or brittle either!)
Andy
USF Confederacy
Whoops... Just missed you Kevin... Thanks ;)
Andy
lol must be all the weight i have lost
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
I like how smooth your ties are, very nice.
No doubt somewhere in the 39 or so pages you've probably said, but what acrylic? I started rigging, hated the fuzzy green junk thread from AL and ordered morope so I'm sort of on hold now. I tied a few shroud lines and used CA but it makes everything very stiff so a better replacement would be nice when the good stuff arrives.
