Battle of Waterloo Attack on La Haye Sainte Farm by Old Collingwood - 1/56 (28mm)
Photos like these show the relationship of the terrain with the structures and vegetation. Maps included in the various histories are good, but being able to see the entire picture really helps to understand a battle. I've been fortunate to be able to walk a number of ACW battles, such as Gettysburg, Antietam and Richmond/Petersburg. These gave me a much better appreciation of events like Pickett's Charge, the Sunken Road and the Crater. Thanks for showing these, OC.
Ken
Started: MS Bounty Longboat,
Link to comment
Share on other sites
Your most welcome  Ken.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Evening all,   some more progress  -  I finished  painting and weathering  the  cobbled patio, and  glued it in place,  I have also  done a wee bit more weathering to the  farmhouse,  I will  blend  things  in even more so  as  I progress  with  the  ground works.
OC.
Current builds
Completed works.
Link to comment
Morning all,  I have done a  chack  of things  still  to  do   -
I still have the -
Wall to build that goes in front of the patio I just put down.
Extension to the wood store - side - front and roof, and raised up floor.
Work on building a graduated slope where the kitchen garden is - using layers of typing paper.
Fitting my Grass mat over this area.
Make and fit the hedge that goes from the stables to my extreme Right, level with the stables.
Purchase some more French 54th and 55th Line reg troops - paint weather - top coat then place these in the orchard.
Put some odds and ends like loose hats - muskets - backpacks etc scattered around.
Cut the French Cuirassiers off their bases and place the other side of the orchard hedge.
Place my pile of French casualties at the entrance to the Barn.
Finish off making my other single British Cavalry needs painting etc - then place him the other side of the garden hedge.
Place the Lunebourg division remnants in the garden along with a few 5th line KGL wounded.
Then make the trees and fit them in the courtyard.
Any any other bits of touching up where needed.
So yep quite a bit to do yet.
OC.
Current builds
Completed works.
Link to comment
Busy busy OC!
Cheers,
James.
Current Builds
Microaces Scrappee Liaison Radio Controlled
Occre Polaris 1/50
Hong Kong Models 1/32 B25 J Mitchell
Completed
Airfix Westland Sea King HU.5 1/48
Airfix Supermarine Spitfire Mk.IXc 1/24
Airfix Avro Lancaster B.III (SPECIAL) 'THE DAMBUSTERS' 1/72
Airfix Titanic 1/400
Airfix King Tiger 1/35
In the hangar, dockyard or factory
Airfix Fairey Gannet AS.1/AS.4 1/48, Airfix North American P-51D, Mustang 1/48, Airfix Supermarine Spitfire FR Mk.XIV 1/48, Airfix MGB 1/32, ICM Gloster Gladiator 1/32, 5 Airfix Tanks, Airfix Blackburn Buccaneer S.2 C/D 1/48, Artesania Latina Zuiderzee Botter 1912 1/50, Airfix WWII British Army 30-cwt 4x2 GS Truck 1/35
Link to comment
I have  been busy again today  -  I  have knocked up  the  extension to the  log store  and  scribed the  tiles  (was tricky  with the  angles)   it looks  White  (it will  be  later)   but  its  just the same  light  pine  look  wood  I have been using  for the porch  - patio  etc  -   its  just dry fitted  in the  pic.
OC.
Current builds
Completed works.
Link to comment
I ran across this article last night.  This seems like good place to drop a link....
https://www.washingtonpost.com/history/2024/04/28/soldier-bones-waterloo-fertilizer-sugar/
Link to comment
Wowzer.
OC.
Current builds
Completed works.
Link to comment
Evening all,     bit more  of an update   -   no pics  as  phone batt  dead again,  any way  I have  been  cleaning up  the  extension  to the  wood  store  sanding it  level  with  the  existing part,  I  have also  created a  false floor  to  bring it up  level  with the  raised  ground  (for when I start  my ground works)   I have also  put a coat of PVA  over it  to lock the  wood fibres  in ready for painting.
OC.
Current builds
Completed works.
Link to comment
Evening  all,    the missing pics  from yesterday,   also  I have  started  on the  wall  using Two  thicknesses  of  wood  joined  together, it will  create  a  left angle  wall  stepped  down  on the  long run  -  with  bricks scribed into  it.
OC.
Current builds
Completed works.
Link to comment
Evening all,    more  work  on my  build -  I have been detailing  my  wall  measuring the  brick  spacing  then  engraving  the  mortar   gaps.
Its  hard  to get across  the  tiny  size of  the  wall  pieces  about 12mm   tall  and  4mm  wide  and  not very  long  was  a  real test  on my  engraving skills.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Link to comment
Good day all,  the  wall  is  completed  and dry fitted  with  me little man  just for  scale,   the  bottom  strip  will  not be seen  when I make up  the  layers  for  the  grass  and  cobbles.
OC.
Current builds
Completed works.
Link to comment
  • The title was changed to Battle of Waterloo Attack on La Haye Sainte Farm by Old Collingwood - 1/56 (28mm)
33 minutes ago, king derelict said:
Just keeps getting better and better OC
Alan
Thank you  kindly  Alan.
OC.
Current builds
Completed works.
Link to comment
11 minutes ago, CDW said:
That's a real work of art, OC.
Thank you  so much Craig.
OC.
Current builds
Completed works.
Link to comment
Understanding the history of a battle is as much as understanding what they did as where they did it.... What is easier to understand than the where... A line on a map cannot bring full understanding....
You sir are creating a picture where understanding is plainly evident....
Modeling the where in addition to the what is a class of modeling above the usual...
Your in the groove Brother... A masterpiece in the offing...
Quote:
Link to comment
Thank you  so  much   for  saying that   -  so  makes   all  the diffrence  to  know  my build  is  achieving what  I hope.
OC.
Current builds
Completed works.
Link to comment
Morning all,   so   working forward  -  I have  glued down the  raised  floor  for  the  wood store  (no real  excitement  as it will  be mostly  covered),  but  the next  move  is  to  work  on the  brick  wall, I am  making this a  Belgium Grey  wall  (as  it  was  going from local history and  pics  of the period)    I have  done a  basic  primer  and  stone  Grey  coat,  next   I will  make a few  different  shades  of  Grey  -  Light  -  Dark  -  Sandy   in  a  few  pools  in my  wet pallet  (flower pot  drip  plate)   then randomly  paint  the  bricks  the different  colours,   after  leaving to  dry  I will  then  add my  dry brushing  dust  -  leave  to  dry   then  after  add a few  dark  washes.
OC.
Current builds
Completed works.
Link to comment
Evening all,    working on my wall  -   random  brick colours  done  then a  dusty  dry  brush,  this  will  be  followed up  tomorrow  with a  wash or  Two  to darken  it all  - kind of looks  like a wall.
OC.
Current builds
Completed works.
Link to comment
OC.
Kind of looks like a wall????    Humpf... that is a wall.
Link to comment
Thank you kindly Mark.
OC.
Current builds
Completed works.
Link to comment
Looks like a lot of block walls around here. Keep up the good work, mate. 😄
Ken
Link to comment
Thank Ken.
OC.
Current builds
Completed works.
Link to comment
Afternoon  all,   right  - washes added  to the  wall, then  glued  down, also  I added  wee bit more  washes  to  the  general areas  to dirty it up a  little, the  log store  still needs  its  extension  placing.
OC.
Current builds
Completed works.
Link to comment
39 minutes ago, king derelict said:
Looking very nice OC. The mucky whitewashed walls are excellent
Alan
OC.
Current builds
Completed works.
Link to comment
Morning all,    I have  decided  to  attempt   my  scenery  profiling   using  sheets  of  typing paper  (as  I have these  to  hand)   has  any body  tried   this  formula   for  model  scenery   as  I can not find  any links  on the  net,   its  sounds   straight  forward  in my head  -  just a case  of  having enough  paper  for  the  height  I want  - then just  sloping  the  A4 sheets  in the directions  I want  using PVA   to  keep them in place  and  build  it up  as  I go,  don't foregut  on top  of this  I have my  grass  sheet  that will  be  glued   over the  top  of the  contours.
OC.
Current builds
Completed works.
Link to comment
Should work brother, but it's going to be heavy... I would recommend poster board for the contours, it's thicker and much lighter, and you can put holes in it under the uppermost layers to keep the weight down, then use your typing weight sheets with waters down PVA to give the final layer before doing the grass sheet....
One thing it does do is give you a good surface to mount figures and trees and the like to....
Quote:
Link to comment
Thank you  for that  brother,  trouble  is  I am trying to   do everything  scenery wise  from  stuff we have in the  house, the only thing  I want  to  pay out for  is  more  figures   when I can.
OC.
Current builds
Completed works.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
