Thank you for all the nice comments  guys.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Evening all,     thank you for all the wishes,   I decided  to do  abit more  as sitting around  watching rubbish tv  was driving me up the wall,    so   - I decided to carry on with the scenery/hedges/orchard grass  areas,  first  I  hacked the hedge  then added a few different  sprinkles, then I cut the remaining grass  strip, then  started to blend the are in  with different  grass  sprinkles.
Getting there  I think.
OC.
Current builds
Completed works.
No worries on the models, OC, but some worries about you.  I hope you can stay on top of this along with the docs.
The hedgerow area is looking good and well used.   BTW, you're not having an allergic reaction to the grass, etc. on the model are you?
The hedgerow area is looking good and well used.   BTW, you're not having an allergic reaction to the grass, etc. are you?
Thank you kindly  Mark,   think you hit the nail on the head  - I do suffer from Hay Fever😁
OC.
Current builds
Completed works.
OC.
Try an antihistomine then.  But then, I don't know what your hedgerows are made of.  If real plants, it's possible.
hope you are feeling better this evening
the diorama is looking fantastic
Sorry  Mark  my sense of humour.
OC.
Current builds
Completed works.
Thank you  Kevin,    I'm on anti biotics  they will do there job, on other  vitamins also,   its  already  better than it was.
OC.
Current builds
Completed works.
The grass area looks great, unkempt, slightly muddy, and generally trodden down!! The hedge is just about right, a hint of Beechers Brook jump at Aintree after 30 odd horses have jumped it. Fab scenic work!😉
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Thank you so much Edward.
OC.
Current builds
Completed works.
Later  to day will be playing with some plastic trees  trying to make them look  lifelike,   will  try a few ideas  form some  vids  I  watched, these ones are quite  bland looking  - they diidn't  look to bad while they were still wrapped  inside an envelope  but when I took them out  "dear o dear".
Anyone have any ideas  to stop that horrible indigestion  that anti biotics can cause  - taking them with  milk and food  as the admiral  advised, but the  gas is horrible.
OC.
Current builds
Completed works.
23 minutes ago, Roger Pellett said:
For chronic heartburn sufferers like me the “acid blocking” pills have been revolutionary.  Here in the USA these pills go by the names Prilosec, Nexium, etc.  Originally requiring a Doctor’s prescription they are now available here in the US without one.  Check with your chemist.
Roger
Thank you  Roger, its weird  my anti biotics  say not to take any  acid blockers  for less that Two hours  after taking them.
OC.
Current builds
Completed works.
Like Jack says, OC. The antibiotics do a number on us as they fight the "bug".  The antacids can cancel out the antibiotics when taken too soon. I have this on solid medical authority, my Admiral the Registered Nurse.
Your fields and hedges are really coming along nicely. Looks a lot like the pasture across the road from me.
For your trees, you might try a spray can of inexpensive hair spray on the bare stems. Do the spraying outside; it can be smelly.  Have a couple of small boxes of your leaf materials to hand. Pick up a pinch of one color and sprinkle it onto the stem. Start dark and work out with lighter colors.
Ken
Started: MS Bounty Longboat,
9 hours ago, Baker said:
Great work, and get well soon 👍
Thank you kindly Patrick.
OC.
Current builds
Completed works.
5 hours ago, Jack12477 said:
OC,  try taking a Probiotic. The antibiotics kill the good bacteria in your gut. You need to replace them.
Thank you  Jack.
OC.
Current builds
Completed works.
Thank you  so much  Ken,       I have a bunch  of those  pre cast plastic trees   they do look  a bit  naff  but  I should be able  to work on them,
OC.
Current builds
Completed works.
AMEN!
My Admiral the nurse seconds this treatment...
Very nice landscaping brother... Keep going....
This is the ticket to outstanding trees, the only thing I could add is paint your tree trunks and lower branches first... then when you apply the hairspray, use a cloth to wrap the painted parts and only spray the upper branch ball...
It goes quick, lightly spray, and bounce around in the dark leaves, let dry, when dry, lightly spray and lightly bounce around in the lighter leaves...
You will be amazed at the results, best part about it, you can still shape the branches afterwards if you need to with a pair of needlenose... Old model railroaders technique... (and you can do almost any type or size tree with it)
Quote:
Evening all,   change of plan  - instead of doing the trees, I decided to  paint the next batch of 2nd KGL  that had been primed  -  so  my normal work flow is to put the first skin layer on the faces and hands  - so Two thin layers of  light pink.
OC.
Current builds
Completed works.
Next stage will be the Earth washes  then a slight Red/Pink on the cheeks  followed by a slightly lighter shade for the nose and chins.
OC.
Edited by Old Collingwood
Current builds
Completed works.
1 hour ago, king derelict said:
It still amazes me how much detail you can bring to those tiny faces. Its excellent painting. The hedges and the field look really good now; that a bedraggled country hedge now
Get well quickly
Alan
Thank you so much Alan.
OC.
Current builds
Completed works.
glad to see your getting better OC.......I take probiotics when I have to take antibiotics........last time had me runn'in to the lavi on a regular basis ;)   good it hasn't stopped you either...nice work on the current regiment.  use the time to think about the trees........like what Miagi {spelling.....whatever}........think tree  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you kindly Denis,     got a good routine I take my Two antibiotics  with milk with my meal  and  leave it at that, as the indigestion at night was horrible,   its A lot better than it was a week a go.
OC.
Current builds
Completed works.
2 hours ago, GrandpaPhil said:
Incredible work on the diorama!  Those hedges and field look amazing!  Very nicely done on the figures!
Antibiotics aren’t any fun!  I hope you get to feeling better!
Thank you kindly Phil.
OC.
Current builds
Completed works.
Evening all,   more work  this evening  - starting to give the guys some details  -
OC.
Current builds
Completed works.
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
