I won’t spend much time going over the kit in general because James H did a very thorough job of that in his excellent review here. As James said, the box is packed with high quality material, a clear, full-color instruction booklet and 7 sheets of detailed plans. I’ve read lots of great things about Chris Watton’s kit designs here and from what I've experienced so far, the praise is well-deserved. A word of caution for those of you with limited work space...this is a BIG kit! I knew the specs going in but didn't fully appreciate the sheer size of this thing until I started dry-fitting the frames. I'm drooling over the possibilities in terms of adding detail to this build but you need to have plenty of space if you decide to give this one a go.
I have fairly ambitious plans for this kit. I'll be displaying the Fifie as a waterline build in the act of hauling nets. I haven't quite figured out how I'll be pulling this off but I love the look of these boats in the water and really want to display it that way. I'd also like to add some crew if I can get my hands on some halfway decent 1:32 figures to rework into Scottish fishermen. With that said, here we go...
A nice big box full of high quality stuff!
The die-cuts here are very clean and precise...not at all like my previous build.
Kudos to Chris Watton's clever engineering which makes assembling the frames problem-free and extremely sturdy.
Even I can't screw this up!
Stern assembly.
The bulkheads fit perfectly without modification.
Making quick work of the frames thanks to excellent fit/finish.
Each part adds stability and guarantees correct alignment.
This tray is intended to house the rudder servo if you plan to do an RC build but needs to be installed regardless.
And just like that, if you're not going to be chopping the hull off at the waterline (probably a wise choice!), the sub-deck can be installed. I, however, will need to do some additional planning to add support and stability for the surgery to come. Stay tuned...
It's great to see a build log of this model, PJG, and a waterline diorama to boot! I look forward to following along with your progress.
By the way, Sea Watch Books has an excellent book on creating waterline dioramas: Waterline Dioramas - A Modlebuilder's Artform by Justin Camarata. I have it and it's excellent.
https://www.seawatchbooks.com/ItemDisplay.php?sku=107002
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Definitely watching this!
I love the Fifie and enjoyed building Chris' recent 1:64 sail version, so this is right up my Straße
Ongoing:
Mountfleet models produced a crew for my St Nectan @1/32, as part  of the kit,  im sure they would help you out
http://www.mountfleetmodels.co.uk/index.html
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
So I've added additional support across all the open bulkheads above the waterline in hopes of keeping the hull from deforming when I remove the lower portion. With the sub-deck glued down and the planking in place I can't see any reason why the overall structure won't hold up to the cutting process. Once the cut is made and everything looks solid/stable, I'll need to remove some of the cross supports to allow detailing in the area below the open hatches where the nets are stored. That's a way down the road so for now I'll stick to the tasks at hand.
The added cross section supports along with sub-deck structure and planking should be sufficient to keep the hull secure later on (fingers crossed).
It took pretty much every kind of clamp/clip I have to secure the sub-deck firmly in place.
The sub-deck is down and along with the additional cross supports appear to result in a pretty solid hull. I've added a 1/32 Spitfire pilot who may well be converted into a Scottish fisherman to give a sense of overall scale.
That's all for now...thanks for stopping by.
Excellent choice of model and building the motored version will be a refreshing change from the many sailed implementations on this forum.
For the figures, you have plenty of choices with the world of 1/35th figures, which is pretty much limitless. Sometimes, having the figures a tiny bit smaller than the scale of the boat helps, as figures tend in general to be slightly oversized.
I, like many others, am looking forward to seeing your diorama.
Yves
Because I don't own or have access to a decent bandsaw, I had to figure out a plan to cut my hull at the waterline with a hand saw. My original plan was to plank first and cut when the whole thing was more stable but the more I thought about it, the more it made sense to get this major hurdle out of the way before I wasted time on a step that might get damaged in the cutting process. I built a cradle from scrap dimensional lumber with the top edge serving as the waterline guide. The keel of the boat runs up-hill from the stern about an inch over its length so I added support where needed to maintain this angle. I almost missed this very important detail but thought the frame looked odd sitting flat in the cradle so back to the plans I went (thankfully).
Bow elevated and secured to get the correct waterline position.
Slowly but surely I cut my way from the stern to bow using the top rails of the cradle to guide the blade. This was probably the most potentially-disastrous step in the entire build so I took my time and made frequent inspections of the cut along the way to confirm accuracy.
Success!
Hopefully this will be the last time I use a hand saw building a model ship!
The first plank the instructions suggest installing is the top-most that runs along the tops of the bulkhead frames. I opted to start with the second plank. I did this because the top plank is only glued at the bow and stern post to allow the tabs above the deck to be removed later. The second plank from the top can be glued at half its width to the bulkheads which creates a much more secure foundation to work from. It's also worth noting that while the instructions seem to indicate running full lengths of strip the entire length of the hull, the strips are actually too short to do that so you need 2 pieces per run. I cut my strips just past halfway (overlapping back and forth) to make the connection in the more forgiving midships area where the bending is less intense. Another surprise (that shouldn't have been a surprise) was that weight needs to added to the deck while the first few planks are installed to keep the frame from lifting in the middle. The rake (correct term?) of the rail is fairly pronounced at the bow so the tendency is for the planks to want to straighten out, thus causing the middle to lift. Once both planks were secured and dry, the frame seems to have settled back to the correct position.
I may need to do a little additional fairing here and there along the way but for the most part I don't expect problems as the planking makes its way to the waterline.
Thanks Yves...I have some 1/35 figures kicking around from some old plastic Tamiya armor kits and you're absolutely right about the nearly undetectable size difference from 1/35 to 1/32. I'll definitely look in to what's available and see if I can find something appropriate.
That's a bold move, cutting your ship!
Nice job with it though.
I just thought about it, with the bottom part you can create another model showing of the details inside the hull.
This way you have two models from one!
Respectfully
I wasn't expecting the planking of my waterline hull to take this long but it turns out I created several unforeseen challenges by cutting the bulkheads before the planks were installed rather than after. If anyone opts to build this boat at the waterline, I would recommend planking the bulkheads below the waterline first and cutting after. As they say, hindsight is 20/20. I won't go into the tedious details of how I went about keeping my waterline level against the natural tendency of the planks fighting to straighten out but I will say it was a true test of my patience. A simple solution would have been to start at the waterline with level planks and "cheat" them gradually into the correct position at the rail with fillers where needed but I thought it was worth taking the time and effort to do it right. Now that it's finally done I'm glad I did.
Given that I intend to paint my hull I'm not so sure it's worth wasting all that lovely walnut strip on a second layer.
View from the stern. With a good finish sanding I think one layer of planks will be fine.
View from the bow.
Given that my boat will be displayed in the act of fishing, I left a quarter inch of hull below the water line to account for variations in the surface of the water. Speaking of fishing, I found this interesting/educational link that has been extremely helpful in describing to me exactly how this kind of drift-net fishing was actually done and how the nets were rigged. For instance, this style of herring fishing was done primarily after dark (according to this source) so perhaps some kind of light source needs to shown in my build. Regardless, it's an interesting read.
https://electricscotland.com/lossiemouth/boats/fisher07.pdf
Thanks for the positive feedback guys...I'll be posting build updates shortly. Being back to work in-person has put a major dent in my free time!
Timberheads and bulwark planking
I did things a little differently than the instructions suggested for the timberheads and planking along the bulwark. I wanted my timberheads to appear as if they were coming through the deck rather than sitting on top so an alternate approach was necessary. The instructions call for installing the entire deck to the bulwarks first, followed by placing the timberheads on top. I suppose it would be possible to cut and refine the bottom of each timberhead to sit perfectly flush on the deck but I wasn’t confident I could pull that off 92 times! Even if I did manage to do that, I still don’t think the look would have been what I was after. Instead, I used walnut strip to create a band along the bulwark from which the timberheads would appear to emerge. It would also allow the deck planking to terminate to a clean edge which made more sense to me than running planks to the bulwark. Ultimately, I think this technique worked out to be an improvement over the timberheads-on-top method and I’m satisfied with the results.
Speaking of authenticity, it’s worth noting that the layout of the timberheads as indicated in the instructions doesn’t accurately depict how they’d line up on the real boat. I’m sure most here already knows this, but they should be square to their partner across the deck given that each pair of timberheads is actually the protruding top of a single frame. This occurred to me after the fact and I ultimately decided it wasn’t worth the considerable time and effort it would have required to remove all 92 timberheads (and the inserts between them) and source the material to make new ones. Unlike the instruction booklet, the plans do show the timberheads in correct alignment. If you do opt to make this adjustment, the material provided in the kit for this step will need to be replaced with larger stock. It will take as much as twice the material to accommodate the extreme angles necessary approaching the bow and stern.
Because my timberheads were not going to be sitting on top of the deck, I didn't have to be overly precise with the bottom cuts.
 Filling the spaces with walnut strip. I deliberately left these slightly "loose" to make it apparent that this part of the deck went around the timberheads and not under.
Timberheads complete!
Planking the deck
As for deck planking, the kit supplies darkly colored 1mm square strips of wood that can be placed between each 1x3.5mm plank to simulate caulking. This is a nice feature but I felt the lines it created were far too heavy for my eye and there is some grain visible. Rather than the strips, I used thread to create spaces that looked more “in scale” to me. I installed my planks in long, single strips rather than edge-butting shorter ones. I’ll add those detail lines later.
Before the deck planking can be completed, the central superstructure needs to be partially constructed and dry-fitted to the hull to ensure that deck planks are terminating at the correct lengths. Building the superstructure is a simple process using the perfectly die-cut parts provided in the kit.
The decking on either side of the hold is treated differently than the rest. This is the area where the nets are set and retrieved and a secondary “slotted” deck rests on top. There are 4 scuttle hatches (2 per side) in this area that are referred to in the manual as “fish pond hatches”. Given their locations, I think it’s safe to assume that fish are loaded through these hatches leaving the central hold open to receive the incoming nets (up to 3 miles worth!). This area of the deck can also be divided into sections with “pond boards”. There are a lot of details about this area in terms of functionality I’d love to know that the documentation in the kit doesn’t provide. For instance: was the “fish pond” area of the hold actually filled with water (such as on modern crab boats)? If anyone knows, please share.
Oddly enough, the photos of the finished boat on the box and in the advertising I've seen don't include the border detail around the hatches and skylight. In the instruction booklet, however, they are included. The plans also indicate the presence of these trim boards so I opted to include them.
Adding the central superstructure (temporarily) to ensure that my planking was terminating correctly.
Adding the "fish pond" sub-deck that will be covered with a slotted secondary deck. There are only 1 mm gaps between the boards of the secondary deck so the sub-deck will be mostly unseen.  I drilled out 2 of the 4 fish pond hatches as these will be open in the final display.
With the fish pond sub-deck in place, the rest of the forward deck can be completed.
The completed forward deck (minus butt-joints and weathering). I'm satisfied with the overall look the thread "caulking" created.
The rest of the deck planks in place.
I decided early on I would be adding detail to the central superstructure/wheelhouse area so this is the beginning of that. Given how numerous these boats were up and down the Scottish coast, I don't think it's too far a stretch to assume each captain/crew equipped and finished their boats to suit their individual tastes. I'll do the same!
Such beautiful work!
Are you using epoxy to replicate the water?
Ongoing:
Fabulous work. Following & Learning!
Tom (MadDog) McQuiggan.
Member of Nautical Research Guild
Current Build : VAPORETTO MOTOBATTELLO VENEZIANO           Finished Build : AIRFIX 1930 BENTLEY
And Later On : PANART VICTORY BOW SECTION                           Finished Build : BILLING BOATS, ST ROCH
And Later On : EBBRO CITROEN DS21
HOBBIES : Amateur Radio : Motorcycling : Model Making : Painting/Sketching : FlightSims : Photography : Slave to none!
She's looking outstanding, PJG! You're making me think that this model may need to be added to my tick list.
I like way you simulated the deck caulking. It looks great. What size and type of thread did you use?
Bob Garcia
Current Builds:
Thanks Bob...I wish I could give you specifics on the thread but unfortunately I don't have them. I can say, however, that it was nothing fancy...just the common stuff (cotton I'm guessing) you'd find in a sewing kit.
It looks fairly thick...
Bob Garcia
Current Builds:
Looking great. The deck, the hatches, etc.  all look superb...Moab
Completed Builds:
Virginia Armed Sloop...Model Shipways
Ranger...Corel
Louise Steam Launch...Constructo
Hansa Kogge...Dusek
Yankee Hero...BlueJacket
Spray...BlueJacket
26’ Long Boat...Model Shipways
Under Construction:
Emma C. Berry...Model Shipways
A little more progress to report on the "fish pond" area of the deck and the interior of the hold. Thanks to the helpful links Blue Ensign included in his Zulu (Vanguard) build
I'm able to make some educated guesses as to what the hold of my fifie might look like. Most of this area will be cluttered with fish and nets but I'd like to make my interior details as plausible as possible without the benefit of actual plans.
So the first step was to build out the secondary decking on either side of the hold.
Sub frames installed.
Secondary decking complete.
On to the hold interior details...
Laying out the floor of the hold.
Lots of small drainage holes drilled...
I added black paint under these boards to help create the illusion of the bilge underneath.
With the fish hold bulkheads installed I tested the fit of the floor before tackling the rest of the details. There's still a lot of work to do in this area but the basics are in place.
