HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
The notches were cut with a chisel and xacto.
Here's a sample. Oh and yes of course it is!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Very clean and precise chiseling, Rusty.  Looks great.
Yes very clean cut. You must have good eye site and steady hands, unlike me.  :D
Ron
Current Build: H.M.S. Triton Cross Section 1:48
Why is it that I always find out the best way to do something is after I have already done it the wrong way? - Me
Very nice Rusty. I do remember your log. I got a few questions, just three,,,
.- TREENAILS: For the treenailing did you use the Byrne Drawplate or you sand a piece of boxwood?
Link to the Byrnes Drawplate. http://www.byrnesmodelmachines.com/drawplate1.html?id_mm=0219MM352526
.- CAULKING: How you did it? Did you use black ink with white glue or paper? The result is very clean and neat!
.- FINISHING: Did you paint the frames before plank them interior and exteriorly? What paint, oil did you use?
Thanks very much!
Glad to see there is so many builders back to the cross setion...Let´s see how many come back to the complete model. I miss a lot Randy, Wang, bubblehead,John and much more...
Happy day!
Daniel.
Rusty your doing an excellent job.If mine turns out half as good i'll be happy.    Larry
With Age Comes Wisdom,I'm Still Waiting!
Current Builds:Syren.Triton Cross section.
Completed Builds: Virginia by AL
                           King of the Mississippi by AL
                           Constellation by AL
Thanks Mark, Bob, Ron and Larry.
Daniel, whatever wood I’m using to make my treenails out of
I cut to 1/32”x1/32” and then run it through the Byrnes draw plate down to the
size I want. I went down to # 26 for these treenails.
The Caulking is blackconstruction paper edge glued to each plank prior to placing the on the frames.
I want to try the method of leaving a gap and using colored fill to make the
caulk sometime.
The frames have two very light coats of wipe on poly applied
prior to attaching them to the keel. When I sanded to fair the frames it
removed the poly from the surfaces where planking would be placed and allowed
for good adhesion.
Ben, I had the pleasure of meeting Jeff once at a show and
he’s every bit as nice as you would think he is.
You're so close you could just drive over and pick you wood out! B)
Rusty
Nothing much to show other than just working my way across the lower gun deck. I temporarily  glued the plans on because I didn't trust myself to transfer the measurements. Seems to make straighter lines for me at least. :huh:
Rusty
Question Rusty
Are the beams glued up in place and are cutting notch on the section?
Or are using just marking then remove beams then cut notch?
Great looking job  neat and clean
Triton Cross Section 1:32
SEE YA LATER
im-outta-here-bye-bye-smiley-emoticon.gi
Hi Pete,
I glue them in place and then cut the notches. It will be harder to do it this way
but for me I feel I can get a better fit in the end.
Rusty
Hi All, I've beeen working my way across the deck here.
Slow going but it's coming out ok.
Here is one of the knees before I put it in.
I hope to finish the deck by the weekend and maybe lay some planks too! :)
Rusty
Beautiful knees, :D  legs arn't bad either.Rusty you are an artist in wood.   Larry
                           Constellation by AL
Thanks everyone, The first knee took about 1 hour. I've cut in half so far.
6 more to go so maybe by the last one I can get it down to 15 minutes. :D
Rusty
Nice, have you considered whether you are planking the entire deck or just a section of it??
Joss
Beautyful and precise work, looks really nice, Rusty
Regards Christian
Thanks Christian,
Hi Joss, I will be using holly to plank half of the lower deck.
Rusty
Well the lower deck framing has been completed and sanded.
Ieven had time to add the waterways. They were cut from cherry as will the bulwark planks.
Next up will be planking half of the deck with holly and then tree nailing it.
Rusty
Rusty,
very nice joints. It's looking really good.
You are building a lot of section models. The dark site of ship modelling is beautyful, isn't it? ;)
Regards Christian
Hi Christian, Yes the dark side is wondefull!
Ben, That's for adding the main topsail bitts later on.
At least that's what I hope the plans say. ;)
Rusty
Just checked the plans and that is correct. Looks great.
Later 42rocker
Current Build -- Finishing a 1:1 House that I've been building for a while
Current Build -- Triton Cross Section
Rusty,
Looks great!!!!!!
Rusty,
that is looking good. The mortices into the knees for the carlings are neat, I found them a little awkward to get right.
Regards,
Grant.
