HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
Looks like you have the fit nice and tight. I am nearly up to this stage and will be doing a bit of practice before the final cuts with the chisel.
Nice work.
Rusty Yours is great,It makes me try that much harder. Larry
With Age Comes Wisdom,I'm Still Waiting!
Current Builds:Syren.Triton Cross section.
Completed Builds: Virginia by AL
                           King of the Mississippi by AL
                           Constellation by AL
Thank you all for the kind words.
Here I’ve started adding the planking up to the point under the main deck beam location.
At this point I'll move on to planking half of the deck with Holly.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Here is the first row of holly set in place.
I pre-notched the plankes for the main gun deck supports.
Rusty
Nice - holly is really nice for deck planking. Plus this is 'easy' planking so it should go nicely. Are you planning on caulking? though there are a multiplicity of methods of doing that..
Joss
Hi Joss, I will be using the black paper for the caulking just like I did the hull.
Some time I want to try the black wood filler but for now I'll stick to paper.
Rusty
Hi All,
Sorry all but the camera decided to hack up the hair ball. I was taking pictures
thinking all was good. I pulled the memory card to download the pictures and
nada, zip, zero nothing. Put the card back in, took some more pictures. Nope.
I replaced the card and still nothing. You would think that a $100 camera would
last longer then 6 years of being covered in dust in a work shop and repeatedly
knocked on the floor. :blink:
So anyway, I stole the Admirals camera to take some pictures to bring us up to
date. The decking was completed and I used Holly treenails with the black
construction paper for the caulking. For the support beams I used some Swiss
Pear and using a xacto and files. I then went on to framing in the gun deck with
the boxwood which the main beams are almost done and then I’ll start on the
carlings ledges and knees.
That's were I'm at right now!
Rusty
That decking look superp.
How do you keep the black construction paper getting fuzzy's all over the place when sanding or do you sand. I tried it with my keel and like to never got it cleaned up.
Very impressed,
Support beams look great also  :10_1_10:
Triton Cross Section 1:32
SEE YA LATER
im-outta-here-bye-bye-smiley-emoticon.gi
Very impressed with your build Rusty.  Particularly the floor beam posts.  Nice hand work.  The holly and the black construction paper look great!
Edited by bbrockel
"I've told you a million times, don't exaggerate   ;) "
 Current builds:
  H.M.S. TRITON Cross Section by Bbrockel - Scratch Build - Scale 1:48
  US Brig Syren by Bbrockel - Model Shipways -Scale 1:64
Beautiful work, Rusty.
Hi Pete and Ben. There’s nothing special I do. I just make sure that the paper is completely
glued on both sides. I only leave about 1/32” excess on the topside and none on the bottom.
Once dry I sand with 150 then 220 then 400 grit sand paper. I sometimes I will scrap it too
with a single edged razor blade. I’ve only tried this on hardwoods like holly, boxwood and
par marfin. I hope this helps.
Hi Bob, Thanks’ and the chisel’s I use are the small and mini palm chisels from U.J. Ramelson.
Thanks Russ. Doing them really makes me want to get a lathe!
Thanks Paddy. I wish I hadn’t lost the pictures though.
Thanks Bob. I was pleased with the contrast with the planking, paper and treenails.
Hi Daniel. I just use a strip of wood cut to the desired width and lay it on the beam and mark
each plank prior to drilling.
Thanks Mark. Much appreciated.
Rusty
What can I say that hasn't been said? Really sharp   Larry
                           Constellation by AL
Rusty,
just been catching up with everyones progress. The build is looking really good, congratulations. Nice work with the deck beam pillars, little details like that really lift the quality of a model. You have a lathe?
Regards,
Grant.
Thanks Joss, Larry, Runner63 and Grant.
No lathe yet Grant. Hopefully some day I’ll get one.
Well all of the gun deck beams are in place. And some light sanding
has been done. Next I’ll be working on all of those knees. Then I’ll have
to do all of the carlings and ledges.
That’ll keep me busy for a while! :)
Rusty
Beautiful work Rusty....the contrast between your framing, decking and deck beam woods just highlights your very nice joints and craftmanship of this build. Thanks so much for sharing  :dancetl6:
SEE YA LATER
Thanks Pete. I'm glad it's coming out nicely.
Here are the first of the knees in place.  Still need to be sanded.
Next it's on to the 10 hanging knees and all of those little notches to cut. :angry:
Rusty
Thanks, Paddy Daniel and Bob.
All of the hanging knee blanks are rough cut out with the one in the
foreground cut and ready to be installed.
Here are a couple of close ups to show the various angles etc that have
to be cut into them to fit around the other knees and hull planking.
After they are all done it will be time to add all the carlings and cut those pesky notches. :o
Rusty
