Porsche GT-1 Evo by CDW - FINISHED - Revell - 1:24 Scale - PLASTIC
Now we are getting a little closer to the cars I always liked! At least it has the name Le Mans on the box!:D
Edited by lmagna
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
oooooooooooo.....nice start! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Your engines really are superb mate  - just like the real things.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
That's right rub it in!
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Nothing to be sorry about. I don't live in KC or even know someone who does. Just giving you a bad time about rooting for the home team.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Sorry guys  - im lost with this subject.😳
OC.
Current builds
Completed works.
1 hour ago, CDW said:
Such a pleasure seeing a legend in our own time, Tom Brady, win his 7th super bowl at age 43. Just amazing.
Well he has matched his career winning percentage in superbowls, 7 of 10.... I figured today was going to go his way....
Quote:
The chassis is mostly finished now. Must add the instrument panel, gear shifter and linkage, and the steering wheel. Body has been sanded, prepped, and shot with Tamiya liquid white primer before the final white gloss coat. Test fitting before doing the final body paint and decal work. Everything has fit well with this kit. Too bad it's no longer in production, it's quite a good value for the quality of it.
By the way, I have included a photo of the Tamiya white primer. I much prefer this over the rattle cans, where I can spray it through my airbrush giving superior control and paint economy. It is a lacquer based primer, not water based.
IMG_1694.thumb.jpg.64af047c5f0ced30fb0e587d6f985522.jpgIMG_1695.thumb.jpg.314e649479a236773dca2d6162b3947b.jpgIMG_1696.thumb.jpg.5ad602c0bb3bd0a087b09276505d1c5e.jpgIMG_1697.thumb.jpg.46defd1a4d9fbc840859411ef7918926.jpgIMG_1698.thumb.jpg.7a11badf14276d6419245af549661890.jpgIMG_1699.thumb.jpg.cbbb1a6e582f92b1fe4e2ddc97ecf4a6.jpg
This kit was copyrighted in 1999, so I am guessing the kit is at least 20 years old. It's becoming a recurring theme when I'm working with these older kits, the decals are questionable at best. These are no different. While they look decent when you look at the whole decal sheet, you find they are less than optimal when you begin to place them on the model, particularly if they are placed in an area with compound curves. Fortunately, the decal on the hood is the worst of the complex areas to be done. We will have to see how well the decals respond to setting solutions and solvent to help them settle into place over the curves. I'm keeping my fingers crossed (again).
The two photos were taken about an hour apart. A third and fourth application of decal solvent will be necessary before it's all said and done.
IMG_1704.thumb.jpg.b05bcd0a548e8bf077bb127e0a11e18f.jpgIMG_1705.thumb.jpg.e48cc4900fbcd5e7f179e75d0159f4da.jpg
After a couple of hours passed from the previous photos, we can see the decals are finally behaving better, conforming to the curves. The decal on the side of the car is laying on pretty much a flat surface, so that's not a problem. I believe the remainder of the decals will be equally easy to apply without too much problem. Sometimes, it takes overnight for the decal solvent solution to really do it's thing. (Solvaset in this instance)
IMG_1706.thumb.jpg.38b72d3cecc0986b716edb2993aacb1c.jpgIMG_1707.thumb.jpg.9b70379de5ef9ccbf91481a430891e34.jpgIMG_1708.thumb.jpg.db249c0df44c93c99e567cf61738cde0.jpg
Looking good my friend,  how you got those  body decals to play ball is  amazing.
OC.
Current builds
Completed works.
4 hours ago, CDW said:
Got lucky this time OC. My rabbit's foot keychain must be the trick. 🙂
Well, whatever your doing brother, keep strokin' that fur..... {chuckle}
Quote:
After drying overnight, the decals were ready to seal. 2K clear coat seals the decals and adds some over all pizzaz.
Going to let the clear coat cure out all day and over night before handling it too much. Tomorrow will attach the glass and other details before mating the body to the chassis. There are a couple of places to mask off and paint semi gloss black on the body.
IMG_1718.thumb.jpg.c5da42a7aeab463479f8e5862e7f039a.jpgIMG_1719.thumb.jpg.9020cc350eb1410234b037bf0067d0f1.jpg
really looking superb..........glad you got the decals to behave :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
