Check out our New MSW Sponsor - LUCZORAMA - in the Banner Ad Section ×
1 hour ago, king derelict said:
The wood plank lines on the motor boats are brilliant
Alan
Thank you Alan,   its just a buff  colour first then a couple  of  Dark Brown  washes  - it  adds the shadow detail and  ages the wood a bit.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Evening all,   some more  slow progress  - again making/painting/shading  more boats.
OC.
Current builds
Completed works.
that looks fantastic OC
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
On hold
MHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72
U552 German U Boat - Trumpeter -
1/48  Amerigo Vespucci     1/84 - Panart-
HMS Enterprise  -CAF -  1/48
Finished
Belle Poule 1834 by Kevin - OcCre - 1/90 - French frigate - started June 2024 - -
Hercules by Kevin - OcCre - 1/50 - Tugboat - Finished - May 2024
Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished
 Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished
Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Thank you so much  Kevin.
OC,
Current builds
Completed works.
Evening all,    more little boaties  completed  -  quite  therapeutic  doing these.
OC.
Current builds
Completed works.
Evening all,  - still more boat building -
OC.
Current builds
Completed works.
Evening all,   not much of an update  - more a repair,  basically  I was looking over the hull  thinking about starting the primer on it soon, when I noticed  some glue had gotten smeared along the front area of the hull   - how that happened I have no idea, but it had set  so I set about using some fine wet and dry  to remove it  -  slow work  but I managed  to remove it to about a 90%  acceptable  standard.
No pics of it as its nothing to really photograph.
OC.
Current builds
Completed works.
On 12/20/2021 at 3:16 PM, Old Collingwood said:
I have added a  few items in the pic  for scale  the coin in a Ten Pence Piece  and my glasses.
OC.,
A bit late but I just discovered your photos with the coins and your glasses for scale. Now I am more impressed than ever. Beautiful work sir!
2 hours ago, rvchima said:
OC.,
Thank you kindly Rod.
OC.
Current builds
Completed works.
Evening all,   only a small update   -  I have primed the Hull,   but firstly  I had to  strip and clean my airbrush  "Yep it was blocked again"   I used my  airbrush  cleaner and a tooth brush  and really got in the nozzle and gave it a right clean out  - suprising how small fragments of paint  (mainly vallejo Primer)  can clog it.
Anyway  its gone on quite well  no visible runs and a smooth coverage.
I could not take any pics as my phone was dead.
OC.
Current builds
Completed works.
24 minutes ago, RGL said:
I detest Vajello paint. Tamiya and Mr Hobby is just so much easier m, the Tamiya lacquer thinner with retarder is just the answer, it works with the AL latest too. I must clean my airbrushes at least 3 times a session now.
Greg I work in a small  lounge with the admiral  about Ten feet away from me   - she has weakened  lungs   - so anything   unless it has no  vapour or smell  is a  Serious No No,    I was  spraying   last night  into my make shift  cardboard box  pray booth  - and  I had to have the back door open   despite it being below freezing out side  - I could see the vapours   comong off my airbrush   and  rising  towards my light above my  table   - even though they are Acrylic  I could smell and tast the  vapours.
OC.
Current builds
Completed works.
15 hours ago, RGL said:
Fair enough!
But I respected and appreciated your viewpoint  and  how you do your painting  - some times wish I had a "Man Cave/shed"  type thing.
OC.
Current builds
Completed works.
OC.
I find the Vallejo black primer to be good at blocking the airbrush nozzle. I try to quickly get cleaner into the brush as soon as I've finished painting to dilute it and then really clean the nozzle. I'm going to try another primer next but I do like the coverage from the Vallejo.
Alan
OC.
It definitely helps. I spray in the garage. I just made a first attempt at hair spray paint shipping and the garage stinks of cheap hair spray. I'm glad I didn't try that in the house.
Alan
Alan
We are seriously limited in space here  just the one room down stairs and a  tiny narrow kitchen, and a  5 feet  by  10 feet back patio, not even a front garden,   its like a dolls house   lol.
OC.
Current builds
Completed works.
OC.
You are building great stuff regardless
Alan
Alan
Thank you kindly Alan.
OC.
Current builds
Completed works.
I use Vallejo’s thinner with their paints and primers.  I don’t use Vallejo on areas that will be taped as I find it can pull off.
When I first got my airbrush, I thought you could rinse acrylics thoroughly through the airbrush with just water and not have to do a more detailed cleaning.  With Vallejo, however, I find it leaves a residue which will gunk things up.  So, I clean out the nozzle, needle, etc. after every session.  It’s sorta soured me on Vallejo, but otherwise I like the color coverage, no fumes, and not having to mix in thinner in the cup.  To really clean it, you can shoot lacquer thinner after shooting Vallejo but I know you don’t want fumes.
Now I’m more a fan of Tamiya and Mr. Color, even with the pre-mixing and fumes.  I find the paint cleans out of the airbrush much more thoroughly than Vallejo.  But, certainly understand why you don’t want to go that route.
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    Hs129B-2 1/48  SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32   IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48  Eduard Sikorsky JRS-1 1/72
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Thanks Mike,    I think what good about the Vallejo Primer is the way it shrinks down  onto the surface,  I have been spraying it with vallejo  flow improver  (just a few drops into the cup)      what I will do  is  give it a good few days before I  mask up the hull   for my other paints.
OC.
Current builds
Completed works.
You probably already know this, but you can remove some of the tackiness of the tape by first putting it on your skin, then on the model.  That removes a little bit of the adhesive and may lead to less pulling of the paint.  I've done this with Tamiya tape and it still works fine.
Another thing that might help is to let the primer cure completely.  When priming, I let it sit for a good 24 hours.  Acrylics are tricky in that they dry quickly but have a long curing time.
To be honest, I haven't had much problem with Vallejo pulling off on plastic.  It's usually on PE that's the problem.
Mike
Thank you kindly  Mike,   I am  leaving the Primer for a good  3-4 days to fully harden  but will also try that trick with my tamiya tape.
OC.
Edited by Old Collingwood
Current builds
Completed works.
lots of useful tips here
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
On hold
Finished
Indeed there  is  Kevin   - thats what makes our  site so special.
OC.
Current builds
Completed works.
I’m a complete novice in airbrushing but through trial and error, so far, Ive settled on model air plus a few drops of flow improver. That seems to have largely stopped clogging mid-spray. I tried thinning model air but by the time I got it so it stopped clogging, the opacity was very poor and I ended up needing six or seven coats. Likewise tried adding a bit of retarder but don’t remember than making any difference. I also make up the mix in little bottles first and give it a good shake.
I’m not even sure what difference there is between cleaner and thinners, been using both but mostly thinners. I do a complete clean in between colours and at the end of every session.
I like acrylics, so easy to clean and remove if I make a mess, and virtually no smell or fumes. I have one of those airbrush cleaning jars, which helps.
Kevin
Current projects:
OC.
After i finish cleaning the airbrush I spray a small quantity of cleaner into a paper towel in a good light against a dark background and look at the spray pattern to make sure its symmetrical and strong. Then I can put the brush away knowing its good to go for the next session. If the pattern looks weak then I pull it apart again and poke the nozzle out again. It doesn't take much to obstruct the flow. I'm sure water would be just as good for the post clean check. its reduced the annoyance of loading the brush up and finding its not spraying well
Alan
Evening all,   a wee  bit of  progress  today,   I have left  the  Vallejo primer  for over Three days  so I thought it would  be ok to mask up  the boot line  ready  for airbrushing,   I measured  Two strips  about 1.8mm  wide  - roughly  8 feet  eqv,   a bit akward  to cut  as they needed to be longer than my ruler  - so I had to slide it along carefully  keeping it in place,   then I  placed them and burnished them down  using a cloth,    it has taken a bit of the  primer away  (more a rubbing smooth  than flaking)   so  top coats  should go  over the top ok.
OC.
Current builds
Completed works.
Hi all,     sorry  for my lack of updates  -  real life events  have  taken me away from playing on my Hood  - in the shape  of  decorating our  bathroom,   I have been  re painting  from the old tired  sand colour to a fresher  apple Green colour, that  has  required several  coats  over the top  (but I have picked up a useful  technique  -  dry each coat with a hairdryer)   this way  I can  tell if the layers have dried smooth or patchy  and gauge how many  coats are needed  (about Three is doing it).
I am nearly  finished but its kept me away from my build.
OC.
Current builds
Completed works.
