2 hours ago, Landlubber Mike said:
Wow, that's super cool Kevin!
Thank you Mike
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Those illuminated panels will really pop when installed.   Just curious here.... should then be red?   Or did the subs have dual colors for night and day use?
I am pretty sure they did, but I read somewhere the choice of color in the German navy was blue not red.
Edited by lmagna
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
im not sure what colour they are, i don't even know what the panel is for, although i am presuming it is a control state board for the tubes, colours can be decided at anytime when i know for sure, its just a filter at the light source, at a quick quess i would say red/green and power status
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
good afternoon everyone
thank you for comments likes
submarines never had space under the torpedo tubes, there was a multitude of pipes, strainers, and valves, so although this is artistic licience, i closed the gap in a bit, no one is going to be able to follow a pipe
mig oil stain used under the tubes,
IMG_1684.thumb.JPG.216ececbf383e8a44aed5286b5d52e66.JPGIMG_1685.thumb.JPG.a421d48018fe249141b8bf976a59b01a.JPG
my loading torpedo get the chop after a aluminium paint job and a new set of props
IMG_1688.thumb.JPG.f473cce66398105d5048f37f31170ff4.JPGIMG_1690.thumb.JPG.aab7caf37593cc75251e6205e2356f21.JPGIMG_1691.thumb.JPG.6e9293fa5621048e93ded0c6471d3f18.JPGIMG_1692.thumb.JPG.9a2e6893161b08794cf251afe326608a.JPG
the bunk beds from the kit were discarded as the bunks would have been raised whilst loading the fish
IMG_1693.thumb.JPG.efcfd51cd8e530020ecc5810a5b9d74e.JPGIMG_1694.thumb.JPG.a855313a3e81d634d4fbff66fd9fa572.JPGIMG_1695.thumb.JPG.0870592d8c478144ad5be10b717b476b.JPGIMG_1699.thumb.JPG.135a614478b0c1fc995f35af5c69d534.JPGIMG_1700.thumb.JPG.2ae8fea3c24b91a0678b58344af6260b.JPGIMG_1701.thumb.JPG.0a1e63215538031bd443cd4879e3533d.JPGIMG_1702.thumb.JPG.ee6f6099f0d392757492d1b783748017.JPGIMG_1703.thumb.JPG.8bb64d822bed1d4acc14bc20452f8f27.JPGIMG_1704.thumb.JPG.9acbd183401bce8b366e23e3ed72d236.JPG
sorry about the poor photos, i need one hand to keep it all together
arrived today
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
thank you for comments and likes
the after bulk head went in after a primer and Lifecolour DKM50, picking out a few colours along the way
IMG_1713.thumb.JPG.5adbd493ceebf8bfcdb4454c0b8a78c5.JPGIMG_1714.thumb.JPG.cbdf8794183584d15efde3f967497113.JPG
next the torpedo stowage deck with just primer dkm 50 and Flory grime
the torpedo's i never went the full hog on them, going to be pretty well hidden, alclad aluminium and a bit of brass for the props, Tamiya dark grey for the bang bit of the torpedo, i then put a bit of brass around one of them to simulate be secured in the stowage
t
a
the bulheads are now fitted, just the deckhead left to go  in the next couple days
left to do
torpedo crane
torpedo tube rear doors
lighting
weathering, but not going heavy at all on the rust, she is a new boat going out on first patrole
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
 no lights
not much achieved today, but i did a quick temporary wire up of the 5 leds in the compartment, im happy now as it is how I wanted it to look
some lights
IMG_1729.thumb.JPG.a933a4df48c44f055b3ffa135c58a008.JPGIMG_1727.thumb.JPG.125560b44cef72a3fe07eaed65e8df42.JPGIMG_1728.thumb.JPG.a20625cb6ee6638ceeabd220941a4fa0.JPGIMG_1730.thumb.JPG.65fd69b6b91d20124c46f54230b940bd.JPGIMG_1731.thumb.JPG.346528c2181599de58a726a573f03997.JPG
i will change the lights to warm white and dim them later on in the build
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Cracking work there Kevin  - so much work going into her.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Kevin, I'd consider using a variable pot or rheostat for the LED's.   That way you can brighten or dim them depending on what you want at a given time.
good morning
yes the lighting wont work like it is, it was just setup for now to see if the effect i was after was going to work, i work put un any lighting until the outer hull is ready, mush later on
however i was quite happy with the results and it shows the areas i need to improve, loving this build,
another surprise is the interest others have shown
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
good morning everyone
the forward torpedo compartment is coming to an end, just a few things that are in paint, but i am unable to fit for now until i decide how to set the build up in its final setting
right for me its silly time
i want to do something with this build that  i have not seen before, or found on the net
as discussed she only has one engine in the kit, which is a port side inboard , which has some hull framework underneath it
there is no stbd engine or frame work under the diesel to support it either,
i want to build a stbd side engine from the port side, using it as a doner unit  the port one can be cloaked in covers whist welding work is carried out
reason for doing this
because i want to, as the kit does not represent the confined space they endured
how am i going to do this?
I dont know, but i mess it up im up a creek without a paddle
both engines are symmetrical  as in both sides have the controls inboard, which also means the blocks are different as well
i am going to start with the superstructure first whilst i get my head around the best way to do this
the boocks are the same but above that everything is 180 degs out
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
me again
well i managed to turn the hull supports form the port side to the stbd
removed some tabs and adjusted the bulkheads by cutting where the diesel support beams go, i don't suppose for a moment that  the further I go into this that it will be easier, but for me thats a great start
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
thank you for comments likes and messages
lol i now have realised the full amount of work involved in this idea i had
everything now has to be rotated 180 degrees, and the easy bit is done, most of it will have to be scratched
as i went along removing the ends of the block, i could have avoided taking the head off
IMG_1751.thumb.JPG.6892bf5ea7ddda8f541c106a7b7bff91.JPGIMG_1752.thumb.JPG.ab59a12d0e31f5a946da8592cf1cb9db.JPGIMG_1753.thumb.JPG.553ac463fdd2fa375ea1a9cc0810b8e3.JPGIMG_1754.thumb.JPG.1a0e52a9b724164126cce991c260cfe4.JPGIMG_1755.thumb.JPG.3789c1afe6cf34dc8288408d4d7be9f9.JPGIMG_1756.thumb.JPG.39c42e67f7134ad3799c610cbed3e7aa.JPGIMG_1757.thumb.JPG.33d274683193f5cf288f8404c1af5b7a.JPGIMG_1758.thumb.JPG.c8b93f56c28124a092d047d8c37a3c8a.JPGIMG_1759.thumb.JPG.91b8c0edff29e229d0f5c7c34b555729.JPGIMG_1760.thumb.JPG.fd0464483cfc7b416d9efdedf7fd8d00.JPGIMG_1761.thumb.JPG.45389bf2d2336ce7717af3c8b99555b0.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
good evening everyone
the engine conversion will take me quite a while so here is some more progress, should you be interested
the first of the outboard exhausts only requires the six pipes to be cut off, and turn the manifold upside down
IMG_1762.thumb.JPG.d7ec44358fc730fb22f56400dc1d3d2b.JPGIMG_1763.thumb.JPG.d7a5e3446d666d57069c2131c26a39d9.JPGIMG_1764.thumb.JPG.e83e86f3d97ac42631ab90324935827e.JPG
the rest of todays photos are trying to get some shape to the after end of the  stbd engine, No its not perfect by a very long way, i need to see what it looks like after a bit of filler, more shaping a coat of primer
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thanks for the details in the log.  Not that I plan on building this, but the work does spark ideas for future projects.
Robert Chenoweth
In the research department:
Nothing at this time.
lol you just never know when you might need to know how to swop a submarine diesel over
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Well, I was actually thinking about how used lights on the panel.  I do have a diesel tug that doesn't have an engine. I may have to create one.
Robert Chenoweth
what a brilliant idea off swopping the engines over, lol what have i done to myself, no regrets its just not turning out as expected, the space (well lack off) is being made worse by (a lack of space)
anyway i plod on in my own way of making something good into a mess
the engine still has another 80+ bits to be fitted, and each bit has to be altered, so its ongoing
meanwhile another moment of madness to replace the molded wire on the bulkhead
im using .4mm wire for this oh and by the way non of this will be seen either, i just want to try my skills out and avoid finishing the build by christmas this year
i will put in at least another 10 cable runs
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Great work there Kevin  as you say the  space is limited not making it an easy job.
OC.
Current builds
Completed works.
Nice build Kevin. I'm following with interest as I'm a couple of years into my build also, complete with RCSubs etch, Eduard Etch and lots of extras.
As you know this kit is woefully inaccurate. Its such a shame given the price Trumpeter charged for it.
Its basic shape for a Type VIIC is OK but the interior is terrible. And as U552 its totally wrong.
But it goes together very nicely out of the box, Trumpeters engineering is well done.
So the decision is for us modeller's, do we go for accuracy or out of the box? Out of the box with little accuracy it still looks impressive on the shelf as a lot of Internet builds have shown.
For example the Forward Torpedo room is too long and needs shortening, the actual Torpedos are too short and need lengthing.  As you have modified too, the Air bottles are in the incorrect place, the beautiful job you did of Fibre optics on the forward control box is a beautiful modelling job, I personally love it, but unfortunately that box doesnt even exist.
I really don't know what Trumpeter were thinking.
The list goes on, I've probably made 100 plus modifications just on the Forward Torpedo room and still haven't got it totally correct.
Mine will never be 100% accurate either as there is just too much to improve.
Here are a few old pics of mine, I have changed it a bit since.
Hope you enjoy the build its a lot of fun regardless.
cheers
cheers
Thankyou for that, and the photos,very nice indeed, its a real shame about the kit,  anyone i am aware of in buildkng this have criticised just how wrong it is,  however i dont have any decent accurate information to make mine any better than seeing what others have done
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Good evening everyone
i have done enough wiring for the hull i still have the bulkheads to do
i removed the wire clips holding the wire runs in place, and replaced them with tape
put a coat of primer over it all, including the bits i have done on the engine up to now
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
cheers
I hope you'll  consider doing a build log for this sub.   Maybe just a bringing us up to date initially.  Doesn't need a lot of explanation.
yes please
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
the torpedo lifting gear is better now having got rid of the kit bits, i left the chains long to help putting the deck head on
IMG_1804.thumb.JPG.43a7ded0979dc49815adc04d08f209d6.JPGIMG_1805.thumb.JPG.17c1be0919fafa58df5a8762607a1df6.JPGIMG_1807.thumb.JPG.a4f3a7d9a15cc8c5c3dc9cc8b943f30b.JPGIMG_1809.thumb.JPG.54a2201a067e3e400ed230bdceda9ab1.JPGIMG_1810.thumb.JPG.4d25852336750789b0100e4aa544c093.JPGIMG_1811.thumb.JPG.b8ea9bb0e5a1c6ec04534b010e11862c.JPGIMG_1813.thumb.JPG.19a463f82afdd9e8046c29d42c896fba.JPGIMG_1814.thumb.JPG.0cf9df6c06701954498a2c6f3e9ae566.JPG
lighting i need to put an inline dimmer and these new 3mm lights are getting quite warm
i think the chain looks out of scale
for now i will be leaving this compartment like this as i am still unsure of the diorama setting and possiblty rethink the lighting
IMG_1818.thumb.JPG.09a4c0662d708bd6e1c4e1042e9c4417.JPGIMG_1820.thumb.JPG.57a5178793572236211d774743f980a7.JPGIMG_1822.thumb.JPG.92058a1296808b87023e3b262887defb.JPGIMG_1823.thumb.JPG.437466cfade8d05e00908a95cf5ec6f4.JPGIMG_1825.thumb.JPG.f0d951c8479431f7a9439554329a2ca2.JPGIMG_1826.thumb.JPG.d9469132ede59cc4e38f80de09e66e68.JPGIMG_1827.thumb.JPG.ccef2e2d52c65173e2e43bce54b9be03.JPGIMG_1828.thumb.JPG.c85e3474d7f284fb7d52b636e4daccbf.JPGIMG_1829.thumb.JPG.e23dcffd564d82eefb43aedc086e4c95.JPGIMG_1831.thumb.JPG.55133fb590ca802ecbd2fdb6ef257439.JPG
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Was just thinking the other day that I would like to see a sub model with a full interior. This is a great representation, inaccuracies be damned. It has the feel of a real sub. I'm totally glad I didn't have to serve on one. The only one I've ever been on is the one ,the U-505 I think in Chicago about 50 years ago. Great model keep up the good work.
Bill, in Idaho
Completed Mamoli Halifax and Billings Viking ship in 2015
Next  Model Shipways Syren
2 hours ago, Lee J H said:
It's no exaggeration to say that it's a real submarine, not a model.
thank you, i would have been happier posting the photo with dimmed lighting
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
