Hi Mates,
 Minor update. Started locating all of the bow area pin locations.
 Now starting with securing most of the shrouds, a few will wait until I get to the foremast. These lines connect to the foresails as well as to the lower forestay rope.
 Need to be sure that no tension bends occur later.
1.thumb.jpg.cfa5ad1eb29cf3829cba0ebe85d989d6.jpg2.thumb.jpg.77f87c2856c9c368511d65ca0f0f5c43.jpg3.thumb.jpg.9beb04acc3c3658c854084d178292e88.jpg
Also started doing rope wraps for the pins. One at a time will take way too long – need to get some kind of mass assembly of sorts. I’ll search out of logs for ideas in the rigging section.
Need to determine visual spool lengths as some shrouds connect to furled sails, others not. Also need to do some coiled wraps on the deck. For that purpose, I’ve ordered double sided clear tape as one of the members suggested in his log.
4.thumb.jpg.f282faebc6cc273f5fe8e57801bfae23.jpg5.thumb.jpg.2be6d288ac710bb6d5343b397c81c31a.jpg
Rotating the boat back and forth on that small table of mine – the side of the gallery hit the recess of the inside the deep double-glazed window frame – Grrrr fix came out OK.
Moved the small table a bit away from the window ledge.
a1.thumb.jpg.63c993719c21a063b651547b02854e47.jpga2.thumb.jpg.ad540ccace9051a7ae6ac5b703eaf7f8.jpga3.thumb.jpg.ed93a7b9c1f80b7c98893b08bd5ca9ed.jpga4.thumb.jpg.59c738faa76c9195335b24cf535578b5.jpg
As always, thanks for your comments and likes.
Regards,
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
I'm gonna try that idea with the rope belayment........running the thread through the hole before the pin is inserted.   thought about doing it to the Thermopylae when I get to the rigging part.......haven't seen it done too much here.   takes a lot of the fight out of it  ;)
nice job on the repair and trim work  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Such a great build, I really like how you have painted the carvings they look fantastic. Super work on the fix, very annoying but happens to all of us;)
Denis,
Yes it’s a good technique. It also adds temporary tension to a line with just the pin holding in place allowing for later re-adjusting the lines as needed.
Then cutting the extra and adding the coiled rope covers seems to work very well.
Also for making coiled ropes:
Using painter’s trim tape coil the rope.
Add a film of CA Gel
This will “lock” the spooled coil. And the gel will not bleed through to what will serve as the topside of the coil.
I then used small beads of Gorilla wood glue to secure the coil in place on the deck.
Had I thought of this much earlier I would have tried to coil all of the canon ropes. Though those ropes are super small almost like thick thread. Hmmm
1.thumb.jpg.58c3f0bbc64bda981509802ec59a52cb.jpg2.thumb.jpg.b7bc260646477cb7b345f946adc5ef09.jpg3.thumb.jpg.f52d4257a24ec02bc36403e984b3d868.jpg4.thumb.jpg.0333f26a9d4afd462958c4c6d2dc8726.jpg5.thumb.jpg.56342c7642100f9486e8aec11851eb7a.jpg
Almost fished with this section - Last night started the three foremast sails- now that's a mess to figure out.
PS: Peter, I'm so happy that you know very little about Viking ships - what a personal relief (:-)))
Don Thanks !
Edited by md1400cs
Under the table:
Completed:
Vasa-Corel -
Patrick -  as always thanks much appreciated.
Mates thanks for the likes (;-)
Under the table:
Completed:
Vasa-Corel -
Hi Mates,
 Thanks for your very kind thoughts and likes.
 Section work in progress update:
 Moving to the foremast area. This area having so many more shrouds and ropes in areas that are harder to access behind the ratlines has resulted in needing a few more stress “time outs” :)
 Also working from three diff. plan sheets that show specific (and diff.) pin and rope attaching locations has increased the workload. Not a complaint = just an observation.
Also when I first installed the rails and drilled the pin holes on the upper railings (using Corel instructions way back when) that kit not having running rigging did NOT include the extra needed pinholes. Now needed to drill more rail holes behind ratlines. Will need the same fix when I reach the mainmast.
But it will all sort itself out :) Here are a few in-progress updated views.
None of the lines have been fixed or adjusted – just sorting out where they "should" go.
Regards,
1.thumb.jpg.b7646d0d61989bcef153fe22ecada17d.jpg2.thumb.jpg.195d9d4b53b43bb24ab248a8fb215e99.jpg3.thumb.jpg.10d85e88530e35d04d6a258b56b83132.jpg4.thumb.jpg.20daa2ad6505550976850beb6732a03f.jpg
Edited by md1400cs
Under the table:
Completed:
Vasa-Corel -
just take your time and be careful Michael.....unfortunate that you didn't see this earlier.   model building at it's finest!   we do and we cope........I'm sure you'll persevere.   do they sell long shank drill bits?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Denis,
Not sure about that. I am allowing for further reach by not inserting the drill bit too deeply into the Dremel. Also the size of the drill precluded wobbling. I do insert a pointer first - so that in-any-case- drill bit won't wander off and really cause extra grief.
Drilled six or so extra holes so far with perfect luck :D Thanks for the advice !
Regards,
Edited by md1400cs
Under the table:
Completed:
Vasa-Corel -
Still following your build and can still not believe you are building the same kit as I am building. This looks like a scale 1:50 instead of the 1:75 of Corel
I am saving some pictures for when I am at that stage. At this moment my build is on hold due to renovation of our house.
Jan V.
current build: Vasa-1628 Corel / Battle Station Mantua/Panart,
previous: Statenjacht / Cross section HMS Victory / diorama shipyard
Martyn – much appreciated thanks so much,
JanV: Thanks for still following along. Appreciate the compliment as well. Yes, you have been very busy with your house – well worth closing the shipyard for a while.
Update NO – but a badly avoided major issue. I share the fix in case others may end up with this problem….and could prevent the possibility beforehand.
Was finishing up the bowsprit area rigging details and sort of noticed over the last couple of weeks or so that the bowsprit platform was well “not looking right” wiggling a bit as well – then decided to pay it some real attention.
Curses here was the problem! (with the entire section on the verge of collapsing as well). Those of you kind enough to follow and also read along might remember that I had mentioned snapping the flagstaff mast twice. Well that problem was not limited to just that tiny mast.
The brass wire certainly saved the entire section from collapsing.
So the fix:
Disconnected those six futtock shrouds as well as that block
Slivered in lots of glue into the open gashes,
Used forward pressure with other hand to close the wound, re-adjusted the platform - then impaled a drill bit through both masts.
Kept adding drill bit depth into the masts by re-adjusting the bit bite on the Dremel – to the point where the drill bit was almost totally inserted.
Drill bit stayed there – then used locking tweezers to secure the mess and let the glue cure.
5a08c73974227_2copy.thumb.jpg.aa50ba3ea0ec55466a4acd6d661999c6.jpg5a08c73e7a6db_3copy.thumb.jpg.02f3a6f4103483c4183d584294f9028c.jpg4.thumb.jpg.6ec2d33e75e036a72db5f896c99eb3eb.jpg
Added bits of wood to add substantive filler within the gaps – also hoping to add rigidity.
Then went to another area of the house carrying an empty glass that needed filling (it was Sat night J) and let this wound close up overnight.
Today: snapped off the end of the drill bit, Dremeled the left over shard.
Decided to add a camouflage to the scars, it got really fixed but post-surgery was ugly (:-) and there were unacceptable visible gaps. The slivers of wood do hide the fix, even though not correct.
7.thumb.jpg.7aa1b1530a8917ca9cb55db4eb46dabe.jpg8.thumb.jpg.3de4a5a3c0009f7d18e501a3b7abe774.jpg9.thumb.jpg.a662ea7d4065c5d1fff1e64d4f29802d.jpg     A
Under the table:
Completed:
Vasa-Corel -
Hola Michael:
I see you are progressing well, despite the mistakes that always appear and those that you have been able to correct properly. Everything is part of the fun and also serves to exercise the mind and creativity.
I see in several of your photos (2017-11.1) that you place the rigging provisionally, leaving them loose and without fastening it to the pin-rails. I think this lends itself to confusion and complicates its placement. What I do is place each rigging on its corresponding pin, although provisionally, inserting each one into the corresponding hole and holding it with the pin (as you have done). This allows to verify the position of the rigging and check if they have enough space between them or do not cross each other or avoid other complications.
By the way, to make new holes, I use the drills of the dremel but using a manual drill.
Muchos saludos, Karl
Karl : thanks for your post. This, my first effort at rigging a “complicated” ship, is still a learning experience as I move along, and fairly confusing at best. Yes your suggestion will also be incorporated. Thanks for your thoughts.
That area will be much more involved than the just (finally) completed bow section. All those ropes were easy to place, and pin-holes were not hiding (;-).
Yes, I did some preliminary rope installations at the foremast section and, as I had mentioned - not enough pin-holes. I will add pins to tighten up the lines and also need to avoid crossing things up. Also Karl I am using the rigging sheets that you sent me (Billings), along with the Vasa museum profile sheet - almost ignoring the Corel sheets. In any case - when the Vasa II book is published whatever I do will be wrong - Not an issue for me any more. Just want to make sure that all lines don't cross each other up. Also with furled sails I need to be cautious how I locate certain lines (inside or outside other sail lines)
B,E. As always thanks for your continued visits – Your suggestion is very plausible. Much appreciated – I had not thought of that – thanks for your kind words as well.
So I have completed the bow section. I promise that these photos will be the last from there !!
As always mates thanks so much for your advice, and likes.
Cheers,
1.thumb.jpg.e4c9eb8a53fdcd4bb7dc0dca4315905b.jpg2.thumb.jpg.6f476b01117503e44a1be984d522ab4c.jpg3.thumb.jpg.c3766dbf28d14d2f40492cb93e765562.jpg4.thumb.jpg.1935a805168dce2110e5e28a6fb3e7ed.jpg5.thumb.jpg.e1f118011e9a18ae77434d99cdc7eefb.jpg
Under the table:
Completed:
Vasa-Corel -
nice fix!   are you going to fix the crow's nest basket too?   she's look'in awesome Michael  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I'm running out of ways to say how awesome she is looking! Also, I don't think there can ever be too many pictures of an area so no worries there. :P  As always great job! Your willingness to go slow and check, double check, undo, redo, scrap and rebuild it again has paid off in dividends. Regardless of historical accuracy when (if) Vasa II ever graces us with it's presence, you have made a truly impressive model. :D
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
Hi Mates,
 Dave: so kind thanks !
 Denis: Yes that basket needs some help – it’s on my list of fixes – happily that list is getting very short.
 EJ: Thanks so much. One of the great advantages of MSW is learning from other builders. My skills since I joined could only have gotten better by also emulating other builder’s log ideas/techniques for this current effort as well as sage advice from member posts. I’m happy that my work on the sails might prove helpful to you as well.
 Frank: as always (;-)
 Went to see how the ship case wooden base is coming along –so far very happy with the look. It should be ready sometime next week. Then need to figure out how to “set” the ship.
 Just barely starting the foremast rigging with pins.
 Thanks for the likes as well – so appreciated.
Cheers,
Under the table:
Completed:
Vasa-Corel -
Hi Michael--I just caught up with your log.  Your craftsmanship is dazzling!  I've bookmarked it and any time I feel tempted to take a short cut I'm going to look at your build and remind myself of the standards I should be shooting for.  Thanks!
Tom
Current: Sergal Sovereign of the Seas
Previous builds:  AL Swift, AL King of the Mississippi, Mamoli Roter Lowe, Amati Chinese Junk, Caesar, Mamoli USS Constitution, Mantua HMS Victory, Panart San Felipe, Mantua Sergal Soleil Royal
Tom: Thanks for your super nice post. Happy to have you on board as well
Regards,
Under the table:
Completed:
Vasa-Corel -
really nice Michael  :)    I was looking at the gammoning as I came in here.......couldn't how symmetrical the windings looked.  bound in much the same way,  the assembly takes on a realistic appearance.  your ropes and their termination have a nice quality to them  ;)    wonderful...really shows the time your putting into them.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Denis: Thanks I was thinking of posting the technique that seems to work just fine.
It took about 10 or so of these to get what I was hoping for - looking  as they do now. (bow area was a learning area)
These last three are what I like much better. Thanks so much for your nice compliment - always appreciated.
Will, in-fact, post the sequence next week - simple enough ----- Heading out of town for the long weekend. B)
Cheers
Under the table:
Completed:
Vasa-Corel -
Michael, just spent a lovely 30 minutes catching up on your build, your attention ti detail is outstanding
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Looking forward to seeing your rope coil technique, they look so good
nice picture of your deck layout.......super job!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Mates,
Kevin, Don, Denis -  super nice thanks
Here is my technique for making the pin rope coils. Each one takes me about 15 or so minutes. Photos go through each step and are in order.
As always thanks so much for the likes and posts.
Regards,
1.thumb.jpg.a585799d2b1244f32cab3667d06dae4d.jpg2.thumb.jpg.de16a8cf43f117327f2dbb2dff737265.jpg3.thumb.jpg.583bdcdfde7b3e28f2b739d03af7eb8a.jpg4.thumb.jpg.984f0e353c5a320ec3d7c3ed5129c456.jpg5.thumb.jpg.2d970433537c9a851fd701d619f66a0f.jpg6.thumb.jpg.e6563d76ebb5596fe53966efffd1a14f.jpg7.thumb.jpg.878cb9aab78cc8181dcc0556bd2365c6.jpg8.thumb.jpg.4f86ddec72ba86b38c7e6496cf0a5148.jpg9.thumb.jpg.4d781c8ea6efbc4aa528ec05fd967a1c.jpg10.thumb.jpg.5a12b27bd202b42ca0a1b71c713982ca.jpg11.thumb.jpg.b2ee848bb5805c341779e5889c2b72f0.jpg
Under the table:
Completed:
Vasa-Corel -
Great rope coil tutorial!
-E.J.
