Hello modeling friends.
The model is planed according to the plan drawings of Gerard Delacroix, Le Fleuron 1729.
Scale: 1/60, Wood: Elsbeere (Sorbus torminalis).
I will build the model as "La Charpente", as shown in picture 0.01.
i.e. only the carpentry / joinnery,
without interior fittings and carving of the exterior.
Karl
(Google Translator)
52 Frames provisionally aligned on the keel, not yet straightened.
I will build the remaining frames including the transom separately
and only then place them on the keel.
After all this fixed on the keel, I will first straighten ans sand the inside.
Karl
(Google Translator)
Edited by Jeronimo
Stern part of the 64-gun ship mounted.
I spare myself great explanations, most of the model building colleagues
have more knowledge of the matter anway than I do,
and the photos areclarify themselves.
Karl
(Google Translator)
Randsom wood, transom and frames 62 to 53 mounted.
Frames lined on the inside.
Schlempholz with its step fitted provisionally.
The images / drawings show the 74 GunShip by Jean Boudriot, Volume 1, as an example.
(Google Translator)
Randsomholz, Heckbalken sowie Spanten 62 bis 53 montiert.
Spanten innenseitig gestrakt.
Schlempholz mit seinen Stufen provisorisch eingepasst.
Die Bilder / Zeichnungen zeigen das 74 Kanonenschiff von Jean Boudriot, Volume 1, als Beispiel.
Karl
Hello.
I have found some problems and errors in the construction of the model.
It does not affect the whole structure, but it bothers me a lot and is annoying.
I took a creative break and I decided to make a completely new start.
This time in 1/48 scale.
Ich habe einige Probleme und Fehler bei dem Bau des Modells gefunden.
Es betrifft nicht die ganze Struktur, aber es stört mich schon gewaltig und ist ärgerlich.
Ich machte eine schöpferische Pause und entschied mich dann für einen kompletten Neuanfang.
Diesmal im Maßstab 1/48.
Karl
Good grief! What a decision to make, to start over.
But excellent start on the 1:48 🙂
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
On 1/3/2023 at 7:11 PM, Hubac's Historian said:
Darf ich fragen - was waren die Hauptprobleme, die Sie dazu veranlasst haben, neu anzufangen?
Hallo,
einige Unregelmäßigkeiten bei dem Bau der Spanten, (mein Fehler) und zu spät bemerkt,
der doch etwas kleine Maßstab 1/60,
haben mich veranlasst den Bau im Maßstab 1/48 zu machen.
Karl
(Entschuldigung für die Erklärung in Deutsch)
On 1/3/2023 at 7:20 PM, rcmdrvr said:
Was für ein Schock, durch so viele Fotos von großartiger Arbeit zu scrollen und dann festzustellen, dass Sie von vorne anfangen. Darf ich fragen, wie Sie jede Rippe formen. Bandsäge? Trommelschleifer?
Hallo.
Die einzelnen Teile der Spanten mit der Dekupiersäge ausgeschnitten,
Zusammenbau und mit Rundschleifer in die endgültige Form geschliffen.
Karl
21 hours ago, Thomas Rauzy said:
Hallo Karl?
Tolle Arbeit.
Ich frage mich allerdings, ob Sie verstanden haben, wie Rahmen gebaut wurden. G. Delacroix ist nicht explizit darüber, aber die Rahmen wurden paarweise zusammengesetzt, wobei sich überlappende Teile gegenseitig verstärkten. Schauen Sie sich das Bild an. Es stammt aus der Abhandlung von Duhamel du Monceau und damit zu einem späteren Zeitpunkt als Le Fleurons Konstruktion. Damals und entgegen den Plänen von G. Delacroix wurde der höchste Teil der Rahmen, der auf Französisch "allonge de revers" genannt wird (ich kann keine Übersetzung auf Englisch finden, möglicherweise Rahmenoberseite mit umgekehrter Krümmung), nicht verdoppelt. Ich füge ein weiteres Bild als Beispiel hinzu.
Grüße
Thomas
Hello Thomas,
where is the problem?
Karl
