Andy,
I just wish that my house would have a larger entrance hall with straight walls
Nils
Current builds
-Lightship Elbe 1
Completed
3 hours ago, FlyingFish said:
Congratulations on finishing - it looks very good, and as others have said, it tells a story. I like that. Very good photos too.
Thank you very much Andy,
as usual I make the final photos by using my wifes adjustable ironing board and a fluffy black blanket hanging from a preliminary support. I have 4 LED spots that are turned towards the model for a good lighting. Some pics with flash, some without
Nils
Current builds
-Lightship Elbe 1
Completed
Many thanks Rick,
I`m pleased you like it...
Nils
Current builds
-Lightship Elbe 1
Completed
2 minutes ago, Blue Ensign said:
Wonderful build Nils, I love your choice of subjects and artistry in creating them.
You have a most interesting collection of ship models worthy of a more public display.
Regards,
B.E.
Thank  you very much B.E.
your words are much appreciated. I have often thought about displaying somewhere outhouse, it would give me more freeroom in my hobby office, but there is always the question of where it would be possible in more public way, the insurances and the safe protection and transport of the glass cases.
Nils
Current builds
-Lightship Elbe 1
Completed
Nils, the figure of a girl in a light blouse and the sailors in heavy waterproof raincoats are somewhat discordant. Some of them are clearly not dressed for the weather. This is of course a joke. ;)
Please accept my congratulations on completing a wonderful and heartfelt work. This sincerity is your trademark as a master. Bravo! 👍 :)
thank you very much Valeriy,
for your kind words, am pleased you like the work.
As far as Elsa ( aka Lana Turner) as the only passenger is concerned, according to Andrew Geer`s Sea Chase novelle, the crew perceived her and her more or less "nightclub" clothing as a foreign (but sexy) untouchable body on board from the start onwards.
I was looking to use for a 1:87 figure for example of the blond Marylin Monroe instead, but unfortunately did`nt find any in that scale.
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Hi Yves,
many thanks for your kind words, much appreciated,
I`ll have pull the handbrake on modeling in the moment, due to lack of space for displaying. I have`nt made any decisions for future builds yet, allthough there are many project ideas spooking around in my mind. I have to build the two glass cases next for my "Zeesboot", my wifes favorate one, and for the just finished "Ergenstrasse".
The glass case of the "5 Elbe" pilotschooner fits as well for the "Zeesboot" perfectly, as this was intended, but that ca`nt be swapped every now and then, and the problem in cleaning a dusted ship, ca`nt be ignored eighther.
Nils
"Zeesboot" on top, underneath "5 Elbe" pilotschooner and "Ergenstrasse" in front
Current builds
-Lightship Elbe 1
Completed
Many thanks Phil,
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you both Richard and Kees,
Richard,
yes, I would add some weathering like rust etc, but unfortunately I have no expereience with that
Kees,
I`m 76 years, and the hobby with it`s modeling tasks still keeps me going quite well.....
Nils
Current builds
-Lightship Elbe 1
Completed
The model is finished, but not yet the glass-casing for it.
I ordered the glass panes at my local glassers yesterday, and am meantime working on the baseplate and the frame parts (double slot) wooden liners ......
I have used this method to date on all my casings
Nils
the baseplate with edge-profiles and bottom liners
the look from beneath
the bottom liner profiles with reinforcement angles and brass sleeves to fit the 6 adjusting brass pins (here without stain treatment)
the model will stand on its own standplate in the casing. This allows to remove it at any time, whereby the upper bonnet can be lifted off the
6 pins
The case corners, hopefully precise cut panes of 4mm thick glass will fit exactly into the slots The wooden slots have slightly surplus of appr 1 mm in length in order to compensate possible wood shrinkage
Current builds
-Lightship Elbe 1
Completed
Hi Roel,
many thanks for your comment. The "Heavy weight punch" is a print on canvas, I like Geoff Hunt`s maritime paintings very much. Its because I`m short with display space that there are models in front of that wonderful picture.
Nils
Current builds
-Lightship Elbe 1
Completed
Today I finished the glass case, and my wife was so kind to clean the glass in- and outside, as well as to help  carry and  swap some of the other cases to a new display place in my hobby office.
This closes the project
Here some final pics of the casing and its build..... This was my 11th  case I built this way and I`m pleased that to date there was no broken glass. I`m not so happy of the steadily increasing prices for glass, so I`m surprised of the glasser`s offers every time.
I would like to thank all that were interested in the build log, with many likes, wows, appreciations, comments and suggestions allong the ride.
Nils
the glass-panes are held with helping aids, such as the "third hand" clamped to the cupboard above, short fixing- and distance pieces, and preliminary self adhesive tape
the angles are well keep the panes in place
after the top panel is complete stained and framed, the 4 vertical profiles are stained an cut to length
now comes the final assembly.....
here again the clamped on "third hand"
the right angle corner
mounting the top panel ( lid) to the rest
metal corners fixed with stainless steel blackend philips flat cross-head screws (M1,7 x 6mm )
the glass bonnet set down on the base with the 6 interacting positioning pins, also the are 6 self adhesive felt patches  under the baseplate to enable a smooth contact.
Current builds
-Lightship Elbe 1
Completed
Thank you very much John,
I am pleased with the result, but had some trouble with the nameplates attached to the ships own stand plate on both sides. These are of printed paper ( black lettering on yellowish colored background ) glued small plates and fixed to the nameplate`s brackets. After glueing  the paper on, all was OK, but then after varnishing them with polyurethane "protection" they looked all wet and soaked through, and even with a hot air dryer I could´nt get them to look as before. Will have replace the printed paper nameplates in the next days, and leave away the varnish. I should have used photo paper for printing.
Nils
Current builds
-Lightship Elbe 1
Completed
She looks wonderful in her case Nils. Must watch the film again.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
many thanks Keith,
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you very much Michel,
Nils
Current builds
-Lightship Elbe 1
Completed
I`m pleased you like this model
Nils
Current builds
-Lightship Elbe 1
Completed
Many thanks Rick, your comment is much appreciated.
I am in the moment thinking about a new project and am gathering information about it
Nils
Current builds
-Lightship Elbe 1
Completed
Nice job on the display case, Nils.  The metal corner pieces are an elegant touch.  Now your beautiful model has a safe, clean home.  Congratulations on another great project.
Gary
Completed Scratch Builds
