Hawker Hurricane Mk. I by ccoyle - FINISHED - Halinski - 1/33 - CARD
Well, here's a quick update. First, I got the tail wheel on.
Then it was on to the exhaust stubs. These proved to be an unmitigated disaster. The parts were flimsy, difficult to shape properly, and had no internal support structure. Assembly did not go well. 😑 So, instead of mucking around with them anymore I simply ordered a set of 1/32 scale 3D-printed exhausts from Squadron. "What a fascinating modern age we live in!"
When you have to shoot, shoot. Don't talk.
- Tuco
Current builds: Brigantine Phoenix, Hawker Hurricane
Link to comment
Share on other sites
Would you prefer building another double row radial engine? 🤪😆
Looks great sitting in its own feet!
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
Link to comment
Depending on which kit(s) I decide to build down the road, there are some 3D-printed options for those, too. 😏
Of course, fitting a 1/32 scale engine into a tight 1/33 scale cowling could prove problematic.
- Tuco
Link to comment
Carburetor and radiator intakes. Both of these were far more aggravating to build than their final appearance suggests. 😑
- Tuco
Link to comment
Their final appearance suggests that they were put together by the people on the factory floor who'd spent all day doing it and knew exactly what they were doing... I can't pick up any sign of a struggle... really beautiful work!
As an aside, my nan was one of those people on the factory floors... she was building Lancaster bombers, though.
Link to comment
The resin exhaust stubs arrived today. It turns out that Squadron.com is down the road a bit from me in Ellijay, Georgia, where my Granny Coyle's family was originally from -- small world. I gave the exhausts a bath in soap and water, just in case there was any residual releasing agent, then painted them a suitably dingy shade of brown. After that dried, I tried my hand at grunging them up a bit. The forward stack should be the least corroded, for obvious reasons. Here's how the first set turned out (right), compared to the still un-grunged second set (left). As per usual, the cellphone cam image washes things out a bit. I don't want to over-do the effect. BTW, there is a negligible difference in size between the 1/33 scale paper parts and their 1/32 scale replacements. I will need to do some cutting into the fuselage to fit the new stacks -- shouldn't be too arduous (fingers crossed).
- Tuco
Link to comment
Next up: canopy. Bleah!! Canopies are one of my weaknesses. Nevertheless, I'm happy with how this one is going -- so far. I have glued on the frames for the sliding portion, tacked them down with low-tack tape (have never tried this before), and will let the glue cure for 24 hours before messing any further with this part. I intend to try something else different as well: I'm going to display the model with the canopy closed. Because of this, I will not be adding the internal printed frames. I never manage to get the inner and outer frames to match up well anyways. As you can see, the inside of the outer frames are painted interior green. As long as no one looks to closely, it's hard to tell that the interior frames are only paint. The proof of the pudding will be getting the molded canopy and frames cut out without having the frames peel up -- but that's a task for tomorrow.
- Tuco
Link to comment
Okay, the canopy is all done and mounted. Here's a couple of in-progress shots.
I got the canopy freed from its mold without too much difficulty. I did, though, in my efforts to clean the thing up accidentally scuff the interior glazing with my emery board. Oops! I also mounted and painted the interior grab handles, as well as the frame for the armored glass. I didn't actually add the armored glass, because a. it is a pain, and b. you can't really see it inside the closed cockpit. Apart from the scuffing, this is actually one of the better canopies I have done.
image.jpeg.6626bbd4138ddadf6da66acb8ef5a664.jpegimage.jpeg.58aafaa5cdab34851570f8e2afe1a0b7.jpeg
While bits of the cockpit were drying here and there, I finished up the propeller hub and blades. To try and make a cleaner, neater hub, I did a little sanding and filling of the basic assembly.
I then sprayed the hub with satin-finish spray paint. Unfortunately, it's the kind that takes a looooong time to dry, so I will probably have to wait until tomorrow for the final assembly. The black of the hub and blades is now quite different shades, so I may end up painting the blades a darker black as well.
And that's all for now!
- Tuco
Link to comment
I agree  with the  others  -  sutch a  lovely build  -  and  the  canopy  is  superb.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
That canopy is brilliant
Cheers,
James.
Current Builds
Microaces Scrappee Liaison Radio Controlled
Occre Polaris 1/50
Hong Kong Models 1/32 B25 J Mitchell
Completed
Airfix Westland Sea King HU.5 1/48
Airfix Supermarine Spitfire Mk.IXc 1/24
Airfix Avro Lancaster B.III (SPECIAL) 'THE DAMBUSTERS' 1/72
Airfix Titanic 1/400
Airfix King Tiger 1/35
In the hangar, dockyard or factory
Airfix Fairey Gannet AS.1/AS.4 1/48, Airfix North American P-51D, Mustang 1/48, Airfix Supermarine Spitfire FR Mk.XIV 1/48, Airfix MGB 1/32, ICM Gloster Gladiator 1/32, 5 Airfix Tanks, Airfix Blackburn Buccaneer S.2 C/D 1/48, Artesania Latina Zuiderzee Botter 1912 1/50, Airfix WWII British Army 30-cwt 4x2 GS Truck 1/35
Link to comment
Chris, your canopy turned out well. 👍
Ken
Started: MS Bounty Longboat,
Link to comment
Canopy turned out excellent. About the spinner and the blades, I should not feel compelled to paint them with the exact same color. They were painted with different paints (propeller blades have usually a special paint) and wear under different conditions.
Cheers,
Dan
Edited by Danstream
Current build : Mayflower - AL 1:64
Completed non-ship builds : Spitfire MK I - 1:48Arado 196B - 1:32, Sea Fury - 1:48F-15C Eagle - 1:48Hawker Tempest Mk.V - 1:48F104S Starfighter - 1:48
Link to comment
Oh, I don't! I just don't think there should be a glaring contrast. Which, BTW, there won't be, cuz I painted the blades already. 😉
- Tuco
Link to comment
Aaaand . . . done. I will post the Big Reveal tomorrow. Time for bed now!
And one more shot of the one-time adversaries together.
G'nite!
- Tuco
Link to comment
 It's hard to equal the detail you produce with paper models, Chris. Congratulations, I can certainly see the allure.
Link to comment
I think  Chris  is a magician.
OC.
Current builds
Completed works.
Link to comment
The Big Reveal!
This kit proved to be much more challenging than I anticipated, but I am mostly happy with the result. The propeller hub ended up being a little troublesome -- the first painting effort produced a cracked finish, so several additional rounds of filling and sanding were needed. It wound up being pretty smooth, though, and easily wins the "Best Paper Hub I Have Ever Done" award. Enjoy the pictures!
I really like the angle on this next shot because you can easily see the Typhoon's lines in the ol' Hurricane.
This last one is the new wallpaper on my phone.
Cheers!
- Tuco
Link to comment
That's amazing. Honestly I wouldn't believe it was paper if I hadn't followed the build. Well done Chris a fantastic model 👍🏻
Cheers,
James.
Current Builds
Occre Polaris 1/50
Completed
Link to comment
Superbly done Chris.
OC.
Current builds
Completed works.
Link to comment
Nice job Chris!
Are you sure you want to park it next to your Bf109? You might wake up one morning to find one or the other inexplicably turned into confetti!
Andy
USF Confederacy
Link to comment
Well done my friend....
And for the most part without filler... Which in my book is a step above what some of the supposed paper modeling "Greats" do... (some of them can't build without using filler everywhere)
Your skills surpass those by far IMHO....
Quote:
Link to comment
Ha! Maybe I should have painted a tiny Bf-109 in the rear-view mirror.
- Tuco
Link to comment
  • The title was changed to Hawker Hurricane Mk. I by ccoyle - FINISHED - Halinski - 1/33 - CARD
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
