Hello everyone:
This seems to be the day to start Speedwell logs.
I received my first 2 chapters about a week ago.  I don't think I will be buildings as fast as some others but I have started and we are off & running.
My only thought so far is when attaching the two curved pieces together make sure they are as exact as possible.  Mine were off a little, and then you have to sand them to get a good fit with the stem assembly.  And trust me - you don't want to sand any mating surfaces you don't have to...
20240403_135553.jpg.5f4e8985e3c88ea1338294b1f5a26ab2.jpg20240403_135540.jpg.7c653944a7f805387eee3006ef917de3.jpg
I think I finally got a decent fit.  It took a lot of extra time but worth it. Now a little extra sanding for the figurehead and the fancy piece on the top.  Then it will be time to get the plans out and lay the keel.
I also hope we can start a group build.  It might encourage a few others to join us.
All for now
Steve
Till next time.....     😎
Steve
Finished:              Artesania Latina Constellation;   Model Shipways USF Confederacy:  Medway Longboat 1742 - Syren Ship Model Company
Current Build:     Syren's Winchelsea
Hello everyone:
Just a quick update.  I got the stem tapered for the figurehead and also have the rabbet installed.
Moving on to assemble the front apron all the little wedges for that.
Little steps...
Steve
20240404_1248562.jpg.b3c04bb2e10c225b82c1886bd136023e.jpg      20240404_1249452.jpg.3c1f2fc1d5021bb571604274c65c5859.jpg20240408_092205.jpg.d58c35cdcfdf035c4d627fabb3b74117.jpg
Edited by CaptMorgan
Steve
Thanks Mike & Chuck -- and the likes.  I'm not in any hurry - I just have an abundance of spare time right now.  That will be probably be coming to a end when I head back north in about a month.
Steve
Someone was looking for places to get copies of the plans in another thread.  I got 3 done at the local UPS store while I waited.  Only $4 per sheet.  I took the plans to them on a USB.
Worked out pretty good...   thought I would let everyone know....
Steve
54 minutes ago, Trussben said:
You can also get large plans printed and shipped to you online, on paper or mylar if needed.
I like the idea of having one mylar set. Thanks Ben.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Fantastic.  Very few kits address this feature resulting in a lot of bowlegged figure heads.  Chuck hit a grand slam home run with this kit.
Allan
https://blueprintsprinting.com/account/
That's where I had mine done. Had them in my hands about a day and a half after ordering.
Jeff
In progress:
Medway Longboat 1742 - Syren Ship Model Company -1/2" scale
USS Constitution - Model Shipways - Scale 1:76
HMS Granado - CAF Model - 1:48
HMS Sphinx - Vanguard
I've been making a little progress and got the keel finished up.  Thought I would throw a few pictures of where we stand so far...
I have the build board all set to go.  I pretty much followed Mikes lead - can't go wrong doing that....
20240424_174203.jpg.176609200cc77259d32f88186bee8c4c.jpg20240424_174156.jpg.219527ded4febe2698ca3dd77bfb593c.jpg20240424_174048.jpg.daf114584b40895c45c6aefff07ee640.jpg20240424_174041.jpg.aeac0c4ec7af1fe88c981b11b136b982.jpg
Next up will be attaching the false keel - seems I forgot that till I seen the pictures...   After that I think I will put on some WOP that to protect what I have done so far.
Then fixing the plans to the build board.
So far --- so good...    Thanks for looking in.
Steve
Steve
Looks really nice Steve. I've put a coat of WOP on mine. I feel it helps keep it clean.
52 minutes ago, yvesvidal said:
I wonder if the Wipe on Poly will make the wood darker.... Sometimes, it does that on very light wood, such as maple.
It does add a little depth to the wood but not a lot. I do put light a coat on and wipe it off right away. That seem to help retain the natural color.
Rusty
  • 5 months later...
Well, it has been a long time since my last update but I have been making some good progress.   So I live in Florida and do the snowbird thing in the summer.  I took all of the frames up north with me so I could have something to do up there.
The only issue I found was I was missing an upper frame 9 and I had 3 uppers for frame 10.  I let Chuck know & he will take care of it.  I just need an upper for frame 9 but will wait till whenever I order Chapter 3 sometime in the future.  I wont be needing it for a while.
Everything fit together real good and there were no other problems that I have encountered.
20240901_124956.jpg.5b1b86542c06c6ad1a8310451e4fefdf.jpg20240901_125328.jpg.2cbc618e85b0f76da2759e5a23b697dd.jpg
I got the frames all assembled, sanded, and ready to install.
Below are a few pics to show where I am at this point.  I went ahead and put in the tree nails into all of the tall frames, short ones will come later.  I also put WOP on all of the fore and aft sides of the frames because they will be to close together to do later.
20241014_171937.jpg.f1124252a4d2f4fe242c729515fca2ee.jpg    20241014_171858.jpg.f545687c29ab9ada164aa8aca2d6c39f.jpg
20241014_171845.jpg.7cfa94fabf69508fef60c6a86ae62589.jpg     20241014_172047.jpg.3d79521115a683f1d5ae6db5f8d94131.jpg
By far the biggest challenge is to keep everything as square and spaced as possible. Just have to take your time & follow Chucks awesome instructions.  I think I'm off to a pretty good start.
Moving on --- one frame at a time....
Steve
Steve
Looks like you are off to a great start Steve.
Rusty
The sweep port and the gunport base have not been glued in yet so I can take them out to trim them before I glue them in. They were there to help with alignment.
From everything I have seen so far those upper frame joints will be hidden by planking so I decided to not trim those.  Hopefully I'm not wrong....
Steve
  • 4 months later...
Hello everyone. Its been a while since anyone has posted any Speedwell progress.   I have finished up Chapter 2 and everything seems to be progressing pretty good.  I had to do my fair share of de-construction of the frames a few times but it's all squared up pretty good now.
20250126_145648.jpg.a47ae2d72b2c10967e0f7a9f9672084e.jpg20250126_1454332.jpg.e9dff21c5fdac64a3e6b89670b8e3c76.jpg20250126_1455032.jpg.1dae5469f693a765db924e4566a96e48.jpg
I do have a question.  My plans show the top plank as 5/32 wide (above) and Chucks and Mikes (below) show it as 7/32.  Not sure which is correct.
Its going to be a while before I have to worry about that but it will make a difference when it comes time to cut the tops of the frames.
Pretty much on hold now until Chapter 3 parts become available again.  I missed the day that they were available on the website & they were gone before I could get one.
Hope everyone is moving along out there...
Steve
Steve
That is correct....
15 minutes ago, baribeaujm said:
The 7/32" template provided in Chapter 2 instructions is used once you add the 1/16" thick fairing cap. At least that is my understanding.
