15 hours ago, catopower said:
Question: What blocks are you using?
Some leftovers from a previous project, probably Sherbourne, which I finished over twenty years ago. That's the only time I can recall replacing the blocks in a kit. I got them from Lloyd Warner. At the time, that was the only source I could find for 2 mm blocks.
1 hour ago, Christiaan Hendrickszoon said:
so i'm going to use your report as a reference
Just don't reference my work too closely. This is my first card sailing ship, and there's a number of things I would do differently if I were to build this kit again. Good luck on your project!
13 hours ago, Christiaan Hendrickszoon said:
 It will be my first paper model, so im curious to see if i can build an acceptable version of it.
Christiaan,
you can look at the test building here:
You can also watch a tutorial on FB. It shows the construction of another model, but it contains a lot of advice related to the construction of a sailboat hull from cardboard. Although you won't find basic advice there (how to cut cardboard with scissors or a scalpel), you will certainly see how to "use" paper, how to shape, how to retouch, etc. (Axel Thorsen 1810 - step by step)
Greetings
Tomek
Edited by 0Seahorse
Greetings
Tomek
Wydawnictwo "Seahorse"
"Seahorse" on YouTube
"Seahorse" on Facebook
I got around to turning and staining the masts -- all two of them. A dowel for the jackstaff is included in the spar set, but the finished staff would be so thin that I'm planning to just replace it with painted styrene rod.
Very nice.
Masting and rigging is underway. Glued boltrope to foresail and laced it to foremast before gluing foremast into hull. I had a lot of trouble doing the sail hems neatly, which is why it has kind of a curled bacon look to it. 😬  I plan to do Phoenix bare-poled.
 Congratulations on completing the model, Chris. She should take centerstage for display. Speaking of display, is she going into a case?
Wonderful looking model! It would be hard to believe that it is made out of card if I hadn't seen otherwise.
  - Eric
Probably not. Quality-wise, she didn't quite make it into "must be cased" territory (and that's a comment on my workmanship and satisfaction with the end result, not a comment on Tomek's design). Plus, because she is so darned tall, she would need a custom case ($$ cha-ching $$).
Congratulations Chris! :champagne-2:
Back to 1/33 aircraft territory, or is Phoenix getting dusted off?
Andrew
Completed (Kits):-
Fine work Chris.  Beautiful result!
Steve
Steve
San Diego Ship Modelers Guild
