Post 24
Completing the first band.
My first action is to address the question of increasing sny.
I formed a plank in the normal way including the edge bend, and used this to shape a spiled version cut from 0.8mm fret.
0125
The two shapes.
The lower one is the spiled plank which has a less concave upper line reducing the upward curve on the next strake to be fitted.
I have now completed the first band.
0149
0150
0151
0152
0156
0170
0167
0165
0169
0175
At the stern either stealers or planks that broaden out from the mid ships point will be required.
 I may use a combination of both as I have broader strips of Pearwood. It is not a critical decision as I fancy coppering this hull, after completing two bare plank hulls.
It has been some 14 years since I last coppered a hull (Pegasus) and it will keep me busy and extend the build time.
B.E.
24/01/2025
The symmetry on that hull is a beautiful thing to look at. Nicely done!
Post 25
The Lower Band.
This is the remaining planking down to the keel.
I have mostly used ca for plank fixing but I use  Roket odourless from Deluxe Materials, a little more expensive than the basic sort but there is none of the breathing issues.
Used on a slightly dampened plank it is very effective.
0199
0179
0200
I first fitted planks in continuation of the upper band down to the termination of the Square tuck. This comprised two strakes.
0180
0196
The rabbet for the hull timbers at the stem, formed by the outer stem pattern, works very well on Harpy. A great asset for  bow planking, and providing a very neat finish.
I did use a micro chisel to pare down the first planking layer where required, to allow a better fit. It also helped to thin down slightly the Pear plank where it entered the rabbet.
0194
I now need to re-mark the planking runs for the final push.
B.E.
26/01/2025
Nice, methodical work. The results speak for themselves.
Not sure if it applies; I learned planking Cheerful and Winchelsea that I edge bent the bow edge of the plank down in order for the to lay up on center at the stem. It seemed counterintuitive but it worked. Maybe what you’re already doing…
Regards,
Glenn
Current Build: Medway Long Boat
Completed Builds: HMS Winchelsea HM Flirt (paused) HM Cutter CheerfulLady NelsonAmati HMS Vanguard,
HMS Pegasus, Fair American, HM Granado, HM Pickle, AVS, Pride of Baltimore, Bluenose, Royal Barge
Thanks Guys for the  interest and likes.
@ Glenn -  yes I use edge bending,  but when it becomes excessive it creates the less than appealing  exaggerated sny effect,.
Post 26
Completing the Pear planking.
004c
Each station has been re-marked on the hull, hopefully for the last time, but I don’t discount that a little tweaking may still be required.
I begin with the strake above the keel.
011c
This strake runs from 2mm at the bow, 4mm at Midships,  increasing to 5mm at the sternpost.
I am now working alternatively from keel up and wale down.
007c
It is easier to deal with the aftermost section of a strake as a separate plank.
0017
Three strakes to go.
It can be seen in this shot that the space at the stern is gradually equalising strake upon strake as I close the gap.
021
Two strakes to go.
026
One strake to go…
030
028
I did not find it necessary to use stealers at the stern, as I have a selection of planking strips of various widths.
In the absence of these, the kit Pear sheets that contain the laser cut parts, provide a good source of plank making material suitable for spiling wider sections at the stern.
The final strake which sits below the round of the hull lacks  uniformity which is why it is placed where it is.
Of necessity the planks are spiled, an exercise I quite enjoy; getting them to fit neatly into the given space I find quite relaxing.
The strakes are again divided into three planks per strake which makes things easier.
041
046
053
058
All done!
Overall, I’m fairly happy with the planking even in its unsanded state.
Moving on to cleaning up.
B.E.
30/01/2025
The symmetry of that planking in the one image taken at the stern looking back is fantastic. Compliments on a fine job there.
Hey B.E.
  Beautiful planking job.  I love Pear wood, so my first thought was that it'd be a shame to cover it with copper.  Then, I started thinking about how striking it would be with the copper and pear, and how complimentary those colors will be together.  As always, looking forward to seeing your work.
Thank you Mark, Bug, Cisco, and John for your appreciation.
@ - Cisco, I am an admirer of your AVS build, and those three months were well spent, and it shows. Your planking is simply beautiful, makes mine look very average.
Post 27
Final sanding was done using various grade papers, primarily 320 al.oxide. It didn’t take long to achieve a smooth and even surface.
070
072
073
077
087
I think she has scrubbed up quite well.
I now return to the Square tuck.
B.E.
31/01/2025
I think that is the understatement of the month there sir :) She looks fantastic!
Post 28
The Square Tuck
I had played around with framing the Square Tuck earlier in the build.
089
Neat as it is I was trying to avoid the exposed end grain planking of the kit arrangement and add a sort of faux framing to better represent a more authentic look.
This is what I have come up with.
090
I had made the ‘frames’ earlier.
092
The original laser cut boarding below the framing.
094
The boarding fitted between the frames consist of eight boards of decreasing length which would prove tricky to fit individually.
I opted to board over a template card pattern off-model and fit as a single unit.
 Still involved a careful trim and dry fit by degrees.
096
099
The boarding is then sanded flush with the frames.
0104
0109
B.E.
01/02/2025
I too will have a think about it.
Richard
Associated build, Chris Coyle's SBLim-2A build
Current builds: Harpy Vanguard 1:64, SBLim-2A, MiG 15 variant, WAK card
Completed builds:
AL's Endeavour,  Corel's BellonaAmati's Xebec,  Billing's Roar Ege, Panart's Armed Launch
Ships' Boats - Vanguard 1:64 and Master Korabel 1:72
 Alexander Arbuthnot,  Christiaan Brunings,  Pevenseall by World of Paperships, card
HMS Pegasus by Victory
Captain John Smith's Shallop by Pavel Nitikin
Rumpler "Taube" 1911 by HMV, card
Post 29
Preparing to Copper the Hull.
I have decided to copper the hull, the first since my Pegasus build, way back in 2011.
At this point in the build the kit instructions suggest moving onto progressing the fitting of the deck, and inner bulwarks before coppering the hull.
My inclination is to copper the hull before I do any more internal fitting which may be scuffed or damaged with the hull inverted.
Having dodged doing waterlines by leaving the hulls of Sphinx and Indefatigable varnished wood, I must attend to this first.
0114
Not one of my favourite jobs and it usually takes several goes to get a line I am happy with.
0122
0133
0134
0116
0142
0143
0148
I may still tweak the line at the bow a fraction, as I recall the words of Dr C.N. Longridge in relation to coppering Victory.
If you lay your copper strakes strictly up to the line you will be very disappointed when you have finished the coppering because it will appear to sag downwards at the bows and stern.
This is an optical illusion produced by the curving inwards of the ship’s body. To prevent this you must raise the line  at each end of the ship and then the top line of the copper will appear horizontal. Begin to raise the line at the level of the Foremast and Mizen which is roughly where the cant frames begin.
Victory of course has a much bluffer bow and the degree of tweaking will differ between ships, but something to bear in mind.
0149
This is a good point to get some paint down on the wale altho’ many touch-ins will be required before the model is complete.
I am using Vallejo Black/grey which I think gives a better scale tone.
I am using the Vanguard supplied plates rather than use copper tape.
0129
Three very thin sheets of plates are supplied marked with the nail patterns.
There is also a separate set for the rudder and stem face plating.
Unlike the Amati plates (smaller strip to right) I have used previously, these are not handed Port and Starboard with nail markings to represent an overlap, nor are the plates so obviously scored for removal.
The Vanguard Plates do come easily away with careful bending.
The plates are a close match to the Amati version and with regard to relative costs there is not a lot in it.
B.E.
02/02/2025
Good luck with this, it looks like a repetitive, tedious business but the results will certainly be worth it.
Thank you Mark, there are a lot of repetitive and tedious tasks in ship modelling, tying ratlines, rigging guns, fitting deadeyes, and indeed coppering. I don't mind, I'm in no hurry.
I want the build to last a while so I'm not tempted by the next offering to  beguile me from the fertile mind of Mr Watton.😉
Post 30
Coppering
Before I begin, I have given the hull an application of w-o-p which should provide a better contact with the glue.
0152
0157
0153
0154
Use of Poly surely brings out the planking, but as a purely varnished hull it wouldn’t do for me. I don’t like the striped effect of differently toned planks randomly applied, as can be seen here on the lower hull. Apart from aesthetics the effect is out of scale.
I used all the colour matched planks which fortunately covered above the waterline, but there were insufficient matching planks for a full bare hull.
With Harpy, only six Pearwood lengths were unusable for my purposes, but the odd few defects will always get through.
0203
I am not a fan of vertically grained or mottled strips, but they can be used beneath copper or a painted hull.
In larger projects such as Sphinx and Indefatigable where my intention from the outset was for varnished hulls, I replaced all the Pear strip with milled timber from Hobbymill E.U. an excellent supplier of quality timber.
With coppering preparation is everything to assist a smooth operation.
I have assembled my application kit.
0161
Acetone for cleaning off ca marks.
Isopropanol for cleaning plates.
Disposable vinyl gloves.
Pick-up tool and burnishing stick.
Tacky Wax for picking up plates.
Scalpel and  cutters.
I am now conducting tests on various cryanolates to see which suits me best. I would prefer not to have to use the standard ca with its undesirable issues for eyes and breathing, but early indications show that the odourless version I have is a little suspect.
I noticed that Knocklouder had mentioned in a post that he had used Deluxe Super’phatic glue (no fumes) with good result so I have ordered a bottle for test.
B.E.
03/02/2025
Great build and log with lots of useful tips and ideas
I'll be interested to see the results of your CA and Superphatic tests BE
David
David
Previous Builds
HM Cutter Hunter Mamoli 1:74
Baltic Ketch Scotland - Corel 1:64
HMS Fly - Swan Class ship sloop - Victory models 1:64
HMS Diana - Artois Class Heavy Frigate - Caldercraft - 1:64
HM Cutter Trial 1790 - Vanguard Models - 1:64
18th Century Merchantman Half Hull - NRG-1:48
HMS Speedy 1782 2023 Edition - Vanguard Models - 1:64
Current Build
HMS Harpy 1796 - Vanguard Models - 1:64
Post 31
Coppering cont’d
I did a test using different specs of Deluxe cyano.
Each sample plate was glued to a piece of pear to which w-o-p had been applied.
Roket Max – thick and non-runny. Slightly more tricky to apply to plates as it tended to drag, and resulted in excess squeezing out from beneath the plates when burnished down.
Roket Rapid – Medium viscosity, flowed well onto plate, little excess squeeze.
Both held well but will create undesirable fumes.
Roket Odourless - Flowed easily onto plate, bonding time 10-20 sec. Has the great advantage of no fumes. I had originally tested this with a long-opened container, so may have become less effective, new stock held fine.
Roket Super’Phatic – Has the colour and consistency of milk, did hold the plate but with longer grab, and is far more messy to apply.
Cleans up with water, and again no fumes.
I am relieved that Roket Odourless cyano did the job, and that is the one I have decided upon.
Approach
One sheet of plates (299) has been separated for use. The back of the plates have been cleaned with Isopropanol.
I will start with the standard naval procedure working from stern keel forward, and keel up, but from there any relationship to reality will end. There will be no overlap of plates which I will butt match albeit in a brick laid pattern.
0167
I am working both sides as I go along, better than the thought of having completed one side, to think I’ve got to do it all over again!
0166
I have started by running strips of copper tape along the keel bottom and the stern post. Atop this I will eventually look to add a wooden strip to represent the False keel.
0171
As each plate is applied I immediately burnish, and clean with a cotton bud dipped in Acetone. Dried on cyano can be a pain to remove later.
0172
It is a long and repetitive business, but once into a rhythm I find it quite relaxing.
B.E.
06/02/2025
Hello Maurice
Great work on the coppering and choice of CA. I have one question which is "What burnishing stick are you using?"
I have followed you lead with regards to the square tuck which looks great on your model.
Cheers
Glenn (UK)
Glenn (UK)
Is it better to glue to treated wood (wop, varnish, paint primer, ...) than bare wood? I am thinking of putting black primer on the hull before coppering.
Edited by wvdhee
Walter.
Current build: HMS Ariadne 1776
Finished build: HMS Flirt
Post 32
Coppering cont’d
As the copper plates follow the lines of the hull it becomes apparent that in some areas the plates won’t fit square to both edges of the adjacent plates.
I find using a needle file to impart a slight concave curve as necessary to get a reasonable fit works, together with a slight angle cut on the short edges.
0176
0182
The most time- consuming aspect is cutting the plates to match the curve of the water-line.
0190
0192
At this point after four days work I have used up the first of three sheets of plates, 299 plates applied.
0197
I can see that one or two plates will need re-fixing and a careful run of fingers over the hull gives a sharp reminder where corners stand proud.
I test the fit before applying the cyano. Here I'm using a small pick-up stick that doesn't obscure the plate edges.
0199
0200
Five days and a long session yesterday, but still a way to go.
B.E.
09/02/2025
