Before fixing the dolphins I believe I must cover the hawse pipes with lead foil.
For this, I thought of using the commonest fishing sinkers, long enough and suitably machined on a lathe to obtain a kind of tube:
Reached the diameter must have stuck in power, tapping it with a hammer. the tube in hawses
Looks very nice, but you might wish to coat the lead with lacquer. This will prevent deterioration into lead salts from contact with air later on.
I started working on the transom, probably the less successful because of some asymmetry that I hope, completing the work, it is not too obvious.
Meanwhile, I trimmed the excesses of strakes:
I built the two stretchers of the transom:
And the crowning that supports these stretchers:
From this picture I get the impression that the courses tend to rise slightly to the left, although it seems not live; mah!
Beautifully done.  I love that stern.
After several attempts came bad, I managed to make a window more acceptable; I do not know if I can, but I want to try to fix the two hinges to be able to open; will be very difficult to fix the hinges to the threshold ......... In the photos the  window is stuck
Nice progress, and very fine looking glazing, how do you doing them?
Alex
Current build: HMS Sphynx, 20 gun ship launched in 1775 at Portsmouth, Hampshire.
On the drawing board: HMS Anson, 64 gun third rate ship of the line, launched in 1781 at Plymouth
Hello,
very good hand work, Giampiero! But I have meant te window glazing in your last picture. It looks very authentic!
Alex
Very beautiful, Giampiero.
That is very crisp and clean work, Giampiero! Looks amazing!
Alex
