I decided today  (well the admiral did)  to tidy out a cupboard  so I could better home my boat bits, very good job was done so it was  double rum and biscuits,    after doing this it inspired me to work out my next progress with the build.
It occured to me that the hatchway with steps (still needed steps)  anyway  its right next to where the capstan will be located (and as I dont want any accident claims from sailors falling down the hatch whilst doing capstan duties)    I have decided to lay a few planks fitted flush with the hatch frame,   have to make the ship as safe as possible the crew will have enough to contend with during battle.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
I believe they have a cover for the hatch when the capstan is in use anyway.   good thinking  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks mate,   yep thats what I thought   I  didn't want any sailors putting insurance claims in against the captain.
OC.
Current builds
Completed works.
Good day folks,   I found a bit of mojo so I decided to attack the boat yard,   I decided to work on the hatch that needs covering next to the capstan first,  my idea is to put two supports a mil (mm)  ot two below the hatch frame, then when these two supports are set I will lay some boards across the supports.
While this was setting I decided to do another temporary cover in the shape of a gratting, this will cover the second hatchway from the bow,   the idea here is during action the gun deck will need as much free space as possible, so the captain would order as many hatchways to be covered as possible, but to still keep some light and air getting to the lower deck, a gratting was used aswell as boards.
So I constructed a gratting and sanded it to fit, then droped this into place in the forward (second from bow) hatchway.
I also started work on one of the stair cases (very fiddly delicate work)
Here are a few pics folks.
Oh also  sincere thanks to all who take the time to view my work, comment  and hit the like button.:cheers:
OC.
Current builds
Completed works.
OC,
In battle, all the gratings would have been sent below.  As for the steps and capstan, the steps would only need to be covered when using the capstan.   i like the utility of what you're doing for that hatchway.
Edited by mtaylor
13 minutes ago, mtaylor said:
OC,
Thanks mark,   with the hatch nearest the capstan I decided to attach to side pieces to hold a few sections of planks,   but with the added grating   "shhhhh  dont tell anyone - I cheated,   as I dont have enough ladder making material to make three seperate ladders - so I threw a grating in there instead:("
OC.
Edited by Old Collingwood
Current builds
Completed works.
More progress today (I dont know whats a matter with me - Two days on the trot)     anyway  I finnished the first set of stairs  (my first attempt ever) , then I cut and fitted the boards to cover the hatch near the capstan.
Here's the pics folks  -
OC.
Current builds
Completed works.
More progress with the steps today,  as the weather has changed again  so some bench time was calling me,   I finnished  the steps by cutting the length to suit the deck height, then after a bit of sanding to get a tight but accurate fit, I applied a small amount of pva and set them in place, after a few hours I finnished with a coat of flat top coat to seal them in.
Just the one photo -
OC.
Current builds
Completed works.
Got myself some Gorilla PVA today, so im expecting even better levels of adhesion.
OC.
Current builds
Completed works.
OC.
That's what I use:
https://www.gorillatough.com/product/gorilla-wood-glue/
I haven't tried Titebond or some of the other glues people use here, but the Gorilla glue dries clear and has very good adhesive power.  It's all I've been using since starting the hobby.
8 hours ago, Landlubber Mike said:
That's what I use:
Thanks for the good word mike.:)
OC.
Current builds
Completed works.
A little more progress tonight,  firstly I discovered my own design fault with the extended forecastle deck,  the edge of this ends close to the second canon port opening,  and a ladder was supposed to be placed here,   but it would be in the way of the canon and  working crew,   I thought about building a small deck extention (lke on the Victory from her poop deck)    but that wont look right,  so I decided to create a small verticle ladder fitted against the forward bulkhead,  possibly with a rope secured into both decks by a ring attachment.
I aslo worked on and fitted the two knightheads, from a piece of 1.5 1mm that had to be reduced in thickness by 50% where it fits against the front curved bulwark.
Pictures tomorrow.;)
OC.
Current builds
Completed works.
Ah, finally caught up with you OC.  Very nice work, impressive.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Cheers,
Thank you so much for the kind words and looking in:)
OC.
Current builds
Completed works.
As promissed here are the photos from the front bulkhead ladder (I decided to paint it red ocre to match the bulkhead)  and also the knightheads  that have received a coat of black paint.
OC.
Current builds
Completed works.
21 hours ago, marktiedens said:
Nice clean work O.C.  I really like the colors you are using.
Thank you mark.:)
OC.
Current builds
Completed works.
Totally agree with Mark about the colours, looking great
Thnak you don,  very nice of you to say:)
OC.
Current builds
Completed works.
38 minutes ago, zappto said:
Very neat work you have done, i like your paint work, done very well!
Thank yo so much for saying that.:)
OC.
Current builds
Completed works.
Hi all,    today I got round to finishing of fitting the ladder on the poop deck, after fitting and gluing,   a liitle bit of  light sanding was done  then I  applied a coat of top coat.
Siincere thanks to all those who view/like and  comment on my build.:)
Here's a couple of current build pics.
OC.
Current builds
Completed works.
Looking really nice OC.
Cheers,
                       VOC Ship Surabaya
Cheers,
Thank you so much,  its getting there - bit by bit.:)
OC/
Current builds
Completed works.
really nice work OC, i have been fairly quiet on the forums, but still here watching the progress
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thank you kevin,  very kind words.:)
OC.
Current builds
Completed works.
3 hours ago, rafine said:
Coming along beautifully OC.
Bob
Thank you so much bob,   Im starting to add some of the small  attachments to the deck now.
OC.
Current builds
Completed works.
she's look'in super OC........ladder installs look great  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you sincerely mate:)   Im at the (get the fittings done  covered by the poop deck)  stage  these are two 9pdr canons (Im going with the cast carvings as 1/100 scale is too tiny to make them from wood)  they are getting the filling down process to clean them up including making the wheels slightly narrower,  they will just have the breaching rope attached and painted up accordingly.
Also to go in place will be the ships wheel and compass base also any fittings along the bulwark that would have been fitted under the poop deck area.
OC.
Current builds
Completed works.
