HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
Thank you for all the "likes".
And thank you, Bob, for your nice comment! At least finally the deck starts to fill up. It makes quite a difference in perception if there is something mounted on the deck  :)
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
A little update: during the last few weeks ship modeling time was very scarce. Between traveling (image 1  -  :) ) and multiple home projects I was able to finish all my belaying pins (image 2), and as a “reward” for having this highly repetitive work finally behind me I built the capstan.
My first attempt using mainly the parts provided in my Syren kit ended up about 1mm smaller in diameter than what was shown in Chuck’s plans (image 3). So I considered this a “prototype” and built a second one out of pear wood. Image 4, 5, and 6 show the building process. The drum head was constructed in the same way as described in the Syren instruction book. Of course, not having photo etched parts makes some things a bit more challenging (metal ring, image 4). The capstan foot I built in a slightly different way (image 6), using 2 slotted disks instead of individual tiny chocks. This also helped considerably with the chock alignment ;) . The finished result is shown in images 7 and 8.
Thomas
Image 1
Image 2 - All belaying pins are finished
Image 3 - First capstan attempt
Image 4 - 2nd capstan attempt: making of the drum head
Image 5 - Making of the capstan foot
Image 6 - Capstan foot continued
Image 7 - Finished capstan
Image 8 - Capstan mounted on Syren deck
Beautiful work on the capstan Thomas. Earlier today I replied to your post on my log by asking when you would be working on Syren again. I guess that I've gotten the answer. :)  :)
Bob
Thomas,
boy, following you is tricky business :-)
In image 3 B, what did you use to hold the capstan on the lathe?  It kind of looks like a Dremel bit holder.
Thanks Richard
Edited by rtropp
Richard
Member: The Nautical Research Guild
Augie, Bob, Mike, and Richard, thank you so much for your kind comments! And thank you for all the "likes"!
- Augie, I guess the capstan may look familiar to you. I kind of borrowed the looks of the Confederacy capstan  ;)
- Bob, I am glad that you now and again remind me to publish something. Time flies so fast that I am always completely surprised when I notice that my last published contribution lies already several weeks back!
- Mike, I can return the compliment: I absolutely enjoy watching your progress with your Mayflower model!
- Richard, yes, you are right. What I show in image 3b is a Dremel bit holder. It works fine on the lathe for small parts. I also tried it with a turn table and my mill. Here the cutter unscrewed the bit holder and I ended up with yet another "prototype" :D.
Thomas
Edited by Gahm
I finished the companionway (although the stairs are still missing :)).
Image 1 describes the different building steps, image 2 the finished result, and images 3 – 5 show the companionway mounted on my Syren model.
Thomas
Image 1: Building steps
Image 2: Finished companionway
Image 3: Companionway on Syren
Image 4: Companionway on Syren
Image 5: Syren with companionway
I agree with the others - the detailing is awesome!
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Thomas
Beautiful crastsmenship. It's great to have your examples as I work through my build.
I had a thought, really a question. It seems curious that there would be cannon balls at the entry to the companion way. Wouldn't that have been a hazard?
Richard
Richard
Thank you all so much for your feedback and nice comments! They are always very much appreciated! And thank you for all the "likes"!
Richard, the same thought crossed my mind when I mounted the companionway. But then Chuck shows cannon balls in front of the companionway entrance, and he did all the research  :). Also I guess the guys, who operated these ships, normally were pretty young and agile, and they probably preferred to have a few more cannon balls handy in a battle over the potential risk of these cannon balls presenting a hazard. At least that will be my explanation for keeping the cannon balls because I like the looks of them  ;).
Thomas
Excellent work ...its looking great  :)   With regard to the cannon balls,  that detail was taken from two contemporary models (english)  of the same time period.  They were both cruiser class brigs.   On one of them,  the shot racks were wrapped completely around all four sides of the coaming.  I thought that was a bit too much so I used the example where they were just on the sides.  Its hard to see in the photo but this is the version where they are shown on all four sides.
I guess that not having a cannon ball when you need it is more dangerous than tripping over one on the way to your hammock:-)
Richard
Edited by rtropp
Richard
All this talk about balls.... guess I won't go there, this pleasant website could go south in a hurry!  :rolleyes:
Looking good, I'm following along and using your ideas!
Robert
Bye Y'all ! - Robert
Current Build and First Wood Kit:
  Brig Syren MS Kit 1:64
Past Builds, all Plastic 30-40 years ago:
  Revell 1:96 Constitution and United States
  Tamiya 1:350 CVN-65 Enterprise
  Countless other sailing ships and modern warships
Just came across your Syren Thomas, and you're doing a marvelous job on every aspect of her. I especially like your work on the stern galleries, and I'll always take pause to admire attention to detail like you've shown. Thanks for posting this.
Cheers
GEORGE
Robert, Jason, Gerty, George, thank you for stopping by and for your kind comments! It is always highly motivating to get feedback like this!  :)
Thomas
I finally started with the “mass fabrication” of my carronade carriages. The prototype was already published a few months ago. The trick now is to find a process to build 16 identical carriages based on this prototype. Image 1 shows the wooden parts provided in the Syren kit cleaned up, painted and with ring bolts mounted. For ring bolts I use the Dafi photo etched versions. Image 2 shows the different metal fittings for the 2 carriage parts. They consist of the photo etched hardware provided with the Syren kit, holes drilled with a pin vise and #80 drill, polished and blackened, as well as 0.4 diameter nails from Scale Hardware, some custom parts such as the carriage bolt (made from a small brass nail) and the breech rope rings. The 3 mm hooks are from the same Dafi photo etch plate as the ring bolts.
Images 3 and 4 show the fabrication process of the wheels. 32 brass strips were roughly cut to the correct length (image 3a) and mounted on a piece of (pear) wood with 2 precisely parallel horizontal planes (image 3b). The whole assembly was then fixed in a Sherline vise on a tilting angle table (image 3c). This arrangement allowed milling all wheel carriage sides at the same time in an identical fashion (images 4d, e, f). After some clean up, fine shape adjustments, and blackening (image 5a) the wheels were assembled (image 5b). For bolts I used the 0.4 and 0.7 nails from Scale Hardware, and the roles were cut to the correct length from a brass tube with the right dimensions.
The first carronade “production” type is shown in images 5c and d. It obviously will take some time to have all carriages finished (36 parts per carriage – not counting the hooks), but this is now just a matter of patience and getting the job done  :).
Thomas
Image 1
Image 2
Image 3
Image 4
Image 5
Those are some fine looking sleds Thomas!
Cheers
GEORGE
Just stunning attention to detail, Thomas !!
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
