Hello Gil,
I just wanted to take this opportunity to wish you and your family a very Happy and Health New Year, and to thank you for all that you have done to make life easier for the many ship modellers attempting to build the HMS Victory kit, myself included.  I hope to enjoy your work for many years to come.
Sincerely,
Jerry.
Happy New Year Jerry.  I'm facing the same delemma that you did, the Victory is almost finished, and what then?  However, I'm having too much fun building the small boats to quit now.  From one old geezer to another, all the best.  Gil
http://modelshipworld.com/index.php?/topic/485-hmsHMS Victory by Gil Middleton - JoTika - 1:72
I plan to have one boat (the launch) on the upper deck skids, and one on the starboard davits. On the model, the davits are 3.9" apart, equivalent to approximately 23.4 feet.  However, the small cutter or Jolly boat in the kit measures only the equivalent of 18 feet.  Hence, I decided to build a 25 foot cutter as shown in McKay's drawings in McGowan's book, HMS Victory, Her Construction, Career and Restoration.
Since there are no parts for that size cutter in the kit, I decided to modify the pinnace (28 ') into a cutter (25').
Starting planking using the pinnace keel and forward bulkheads.
post-68-0-26598300-1420318439_thumb.jpgpost-68-0-69589000-1420318463_thumb.jpgpost-68-0-94024300-1420318483_thumb.jpgpost-68-0-07285000-1420318502_thumb.jpgpost-68-0-63143200-1420318524_thumb.jpg
A new larger transome was fashioned for the cutter.  The pinnace transome circled at left.
The portion of the pinnace keel to be removed is highlighted.
Thanks David.  I was rather pleased with the hull shape.  The uncertainty was that the pinnace would produce a boat with a narrow beam and too little freeboard. However, with a few shims and a wider transome, it turned out OK.
At my age, one tends to reflect on the state of ship modelling.  With the advance of technology, we may soon buy our models in some form of thumb drive or DVD disc, take it to the color 3D printer and presto, a finished model.  But, good luck with the rigging.  It doesn't sound like much fun to me.
Cheers, Gil
Continuing with the 25' cutter.  Bulkheads have been trimmed and ribs added.
Gunwale and rising plank added.
Final fairing, sanding and painting, sanding and painting, sanding and painting, painting, painting, painting, etc., etc
post-68-0-50975600-1420413352_thumb.jpg.
Weathered thwarts and floor boards (a bit too much), and comparison with the launch
post-68-0-56348900-1420413491_thumb.jpgpost-68-0-43596500-1420413554_thumb.jpgpost-68-0-98060700-1420413575_thumb.jpg
Still a number of details to be added, aft seating, rudder, lifting rings, thole pins, etc.
very nice work Gil.......takes a bit of doing to modify 'em,  but in the end,  what you came up with looks superb!   they look great together!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Fashioning pintles and rudder.  At small scale, it is easy to lose track of size.  The rudder looks fine except that the tiller at 1:72 would be in reality 5" to 6" (12 1/2 to 15 cm.) in diameter, and totally out of scale.  The tiller handle was replaced with painted wire, equivalent to approximately 1 1/2" (4 cm.) diameter at full scale.  Gudgeons added to the transome and thole pins at the gunwale for rowing.
post-68-0-42518400-1420586353_thumb.jpgpost-68-0-22525600-1420586380_thumb.jpgpost-68-0-76707500-1420586408_thumb.jpg
The cutter alongside the launch.
Painting scheme for the cutter.
Marlinspike seamanship has been practiced for hundreds of years, including knots, hitches, splices and decorative knots.  Decorative ropework was typically seen on tiller handles, bell ropes, hand rails and stanchions, etc. although only one "turkshead" was seen in my photos of the "Victory".
Here is a crude example to simulate a decorative ropework covering on the tiller.
post-68-0-18819700-1420586738_thumb.jpgpost-68-0-04215300-1420586753_thumb.jpgpost-68-0-27596600-1420586783_thumb.jpg
Next:  Attaching the cutter to the falls from the davits.
Sweeeeet..  I love that cutter.
So do I
lovely work
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Me too !  Love the "fancy rope" on the tiller. I have a [uS] Coast Guard friend who does fancy rope as a hobby. It's really beautiful workmanship- yours and his.
Jack
Current buildUS Constellation
Mark, Always a treat to have your comments. But how do you keep track of all of us as an administrator and get any work done on your lovely Licorne?
A SPECIAL THANKS TO ALL OUR ADMINISTRATORS FOR MAINTAINING THIS GREAT SITE !
As always Kevin, many thanks.
Jack, It's fun to try something different.  The next detail could be scrimshaw, if one is adept at engraving the image of a ship on the head of a pin. Perhaps I'll pass.
Cheers, Gil
Outstanding ! Beautiful !
Jack
You're getting close, Gil.  That little cutter looks right at home on the davits.    BTW, i'm not a moderator anymore after stepping down for personal reasons. So, I get more shop time.  :)
Mark, I'm glad to hear you'll have more shop time. However, your 8000+ posts have encouraged a great number of ship modellers. A special thanks from one of them.
Jack, If I had only known. I would have checked out your lovely longboat before starting on my own.
Thanks Jerry, I'm finally catching up with you.
Remco, Your comments are greatly appreciated.
A few more small details, clean up, touch up, etc.
Cheers, Gil
Finally getting around to the flags, attaching the White Ensign, Union Jack and Vice Admiral's flag.
The White Ensign on the driver yard flag halyard.
Nelson's Vice Admiral flag at the foremast peak. The flag is flown on a "Pig Stick" so that the flag is not fouled by the stay or back stay. A pig stick was and is a common way to fly a flag above the mast head.
I'll replace the flag.  This one degraded by paint bleed
For those unfamiliar with the term pig stick, a simple sketch should clarify it's use.
The Union Jack at the jack staff (anchored or moored;  at the main mast when underway)
Name plate.
Now to attaching supports and a base plate.  Drilling through the keel and internal reinforcements placed at the beginning of the build. With any luck, I won't drop the ship in the process.
Cheers, Gil
Hi  Gil
The finishing touches only prove that excellence prevails throughout your endeavor.  Lovely as usual
Best,
Jerry
such a great finish Gil...........I hope I can say that.   such a superb build........the finishes.....the rigging.....a very high quality museum build!
.....and lets not forget the ship's boats..........awesome!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Many thanks Jerry. Wouldn't it be fun to host a gathering of the "Victory" models. Daniel, Grant, David, Kevin, Lawrence, Derek, Patrick, Glenn, and Rosemarie to name just a few. However, I think we've all discovered that the only thing more challenging than building a large model is transporting it. I guess we'll have to be satisfied with MSW.
Popeye, I've looked back over your many many posts and sincerely thank you for your six years of support. If I ever get to Manchester, NH, you'll certainly get a call.
Cheers, Gil
Greetings Gil
Like SJORS I simply sat back and watched your build develop over the past few years, and simply enjoyed every minute of it. When I first joined MSW and decided to build the Victory i was immediately directed to ....The Anatomy of Nelson's Ships by Longbridge and Gil Middletons log. I don't know how many times I have asked a member a question for advice , and been asked " have you had a look on Gil's log ?" or " Has Gil got a jig for it ? ".. The answer was often there. There were quite a few times we would read the words next to a photo saying....The real ship.. Which you probably had to tell us, or you were playing spot the difference. Yep your build was a joy to follow , thanks a lot and good luck with whatever you decide to build next. I shall wait in anticipation. Regards DAVID
