I carefully reduced the thickness of the complete grating to just over 1mm using a mini sanding disc in my Proxxon IB/e.The grating was then wetted and clamped to a plywood former with slightly more than the required radius.The Ebony frame was then assembled around the grating using 30min epoxy.
After leaving overnight to dry,everything was sanded back to the required shape and size.The final two pics show the grating slotted in place on the deck.Final gluing will not happened until all 'treenailing' and sanding has been carried out.
A change of direction now as work is going to concentrate on Royal Caroline's guns.
Kind Regards
Nigel
Currently working on Royal Caroline
Thank you very much indeed John :blush: It did test my patience to the max and cost three broken drills :rolleyes: However,now the learning curve is complete,hopefully things will be a little more straightforward as I have another seven or eight to make for the whole model :o
Kind Regards
Nigel
Gorgeous looking grating Nigel - that is particularly well done. Very impressive!
Beautiful grate and coamings.   I like the ebony look for the coamings as it makes the grates jump out.
Thank you very much Mark :) The contemporary model of her has black combings and waterways on the maindeck,I have chosen to follow this,but extend it to the gundeck combings.I am also considering making the bitts and capstans from ebony.
Merry Christmas(actually xmas day here now :D )
Nigel
I felt the need to post some pics to celebrate the completion of the gundeck 'treenailing'.The aft section still needs sanding smooth and I will then apply a coat of thinned poly to protect the deck during future work.A rough count up shows well in excess of 3000 fixings :o Some sanity has been retained thanks to the music of Vangelis and Hans Zimmer ;)
Kind Regards
Nigel
Sanity and our craft do not go together. Amazing work by you and we are all mad as maggots :D!
Cheers
Alistair
Current Build -
Thank you Alistair :) You're post made me chuckle,I am wrestling tiny eyebolts into gun carriages little bigger than my thumbnail as I write this :D  :D I think that is case in point :huh:
Kind Regards
Nigel
Well ok,maybe not literally at the same time John :D  :D  :D but I am ambidextrous :P
Kind Regards
Nigel
The amount of work you have put into this is awe inspiring! What material did you use for treenailing the deck? Was it a contrasting wood, or did you use brass?
Regards, Keith
Nigel, great work! I have to say though, don't we all have to be sane to start with if our sanity would be retained? LOL If you ask my admiral, she would tell you that we're all insane for this hobby.  :P
Gosh,many thanks everyone :blush:  :blush: I will post some pics when sanded and a coat of varnish has been applied.It will give a better indication of the finished process.
The 'treenails' are from soft copper wire Keith.The product I use is designed for electronics and armature winding.I have used brass in the past,but it is a VERY hard slog sanding it flush.I know Alex Banarov uses brass,but he snips the brass off proud and then dresses it flush using a hammer.His models are typically twice the size of mine,I don't fancy hammer wielding on a model of this size.Not only that,but I feel the copper provides a very subtle contrast to the pear,it only really stands out when the light catches it at a certain angle.It will provide a stark contrast against the Ebony sections,but that is the appearance I am after.
Kind Regards
Nigel
I have fully sanded the deck smooth.After this,the deck was wiped with an extremely diluted mix of Liver of sulpur gel,http://www.metalclay.co.uk/patinas/,thiswas to take the shine off the copper,rather than turn it black,which a stronger mix would have done.It has removed the shine and darkened the copper ever so slightly.So far two coats of poly have been applied and the deck has been rubbed down ready for the third.
Happy New Year everyone :)
Nigel
Nigel !!
Yet again ... stunning !!
I would never have contemplated washing the planking with LoS ... I would've thought that stuff would eat the wood.
Most definitely one for the memory bank.
Edited by CaptainSteve
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
