I have it in mind to build a 1:48 scale fully framed model of the french gabare Le Gros Ventre. This will be based on
the excellent plans by M. Gerard Delacroix published by ANCRE Press.
This is of particular relevance to me, as a western australian, since this vessel, under the command of
M. St. Allouarn, was part of the Kerguelen expedition of 1772. He in fact laid
claim, in the name of the french
King, to the western australian coast and left a message to this effect in a
bottle at Shark Bay 30th May 1772.
Unfortunately, M. St. Allouarn died at Ile de France 5 months later.
Le Gros Ventre ended its life as a
hulk in 1779. As a start, I present the building board.
Dick
I plan to use only western australian woods for this project.post-848-0-65079400-1361355410_thumb.jpgpost-848-0-25142800-1361355414_thumb.jpgpost-848-0-15727900-1361355418_thumb.jpgpost-848-0-54060300-1361355422_thumb.jpg
Current build:
 Le Gros Ventre 1:48 POF   http://modelshipworld.com/index.php?/topic/564-le-gros-ventre-by-woodrat-scale-1-48-pof-1767-french-exploration-vessel/
Past builds:
Mycenaean War Galley by Woodrat - 1:48 - Shell first Plank on Frame:https://modelshipworld.com/topic/33384-mycenaean-war-galley-by-woodrat-148-shell-first-plank-on-frame
Venetian round ship 14th century by Woodrat fully framed - 1:40 scalCompleted
https://modelshipworld.com/index.php?/topic/17991-venetian-round-ship-14th-century-by-woodrat-fully-framed-140-scale
Venetian Carrack or Cocha 1/64 by woodrat   https://modelshipworld.com/index.php?/topic/4915-venetian-carrack-or-cocha-164-by-woodrat        completed
United States Frigate Essex 1:64 POF   http://modelshipworld.com/index.php?/topic/4496-usf-essex-by-woodrat-scale-1-64-fully-framed-from-takakjian-plans/ - completed
Yenikapi12 by Woodrat - 1/16 scale - a small Byzantine merchant vessel of the 9th century
https://modelshipworld.com/topic/23815-yenikapi12-by-woodrat-116-scale-a-small-byzantine-merchant-vessel-of-the-9th-century-finished/
The Incredible Hulc by Woodrat - an experimental reconstruction of a mediaeval transport
https://modelshipworld.com/topic/25641-the-elusive-hulc-by-woodrat-finished-a-speculative-reconstruction-of-a-mediaeval-merchantman-132-plank-on-frame/
I will try to document each step, including the mistakes. The first step is to
make the keel from western australian jarrah hardwood. The stem and stern post
as well as keelson will also use this wood.
Cheers, Dick
post-848-0-16219000-1361356020_thumb.jpgpost-848-0-22584200-1361356035_thumb.jpgpost-848-0-61738100-1361356065_thumb.jpgpost-848-0-55496200-1361356226_thumb.jpg
Current build:
Past builds:
Here are the sternpost and stem in place on keel.
Dick
post-848-0-10442900-1361356615_thumb.jpgpost-848-0-34515900-1361356618_thumb.jpgpost-848-0-46869600-1361356621_thumb.jpg
Current build:
Past builds:
further progress on the backbone of the ship
Current build:
Past builds:
Here is more on rebating the "counter-keel" to receive the floors for each
frame. I used the cross slide on my saw to make these. Ensure that the stem and stern frame rebates are lined up on the frame marks on the baseboard.The next job is to make the rabbets.
Dick
post-848-0-22117800-1361357636_thumb.jpgpost-848-0-79998000-1361357640_thumb.jpgpost-848-0-77570800-1361357644_thumb.jpgpost-848-0-79623300-1361357648_thumb.jpg
Current build:
Past builds:
The stern timbers are made and installed. Please note the is a large entry port on the
larboard side of the stern which was originally for loading of timber and
masting.
Dick
post-848-0-67249700-1361358061_thumb.jpgpost-848-0-75324500-1361358100_thumb.jpgpost-848-0-74712700-1361358115_thumb.jpg
Current build:
Past builds:
further work on the stern timbers.
Dick
post-848-0-77045600-1361358310_thumb.jpgpost-848-0-60002800-1361358314_thumb.jpgpost-848-0-41839200-1361358318_thumb.jpgpost-848-0-99906100-1361358321_thumb.jpg
Current build:
Past builds:
Dick
As a West Australian, I am hugely interested in this build-both because of the history of the vessel and the WA hardwoods.  I have found Jarrah to be a beautiful wood but a little splintery for fine, detailed work. No problems for you, though. A terrific start.
Grant
:) Thanks, Grant. The Jarrah is difficult at times and the dust is irritating. So I always wear a mask when sawing and sanding. Some members may not like the very dark hue the wood takes on when oiled.
Cheers, Dick
Edited by woodrat
Current build:
Past builds:
This details the making of the last frame which sits against the fashion piece.
Dick
post-848-0-92098000-1361889171_thumb.jpgpost-848-0-69024100-1361889196_thumb.jpgpost-848-0-53285800-1361889230.jpgpost-848-0-32231900-1361889255.jpg
Current build:
Past builds:
This post shows the construction and fitting of the last full frame aft which also abuts the fashion piece.
Dick
post-848-0-66204600-1362388820_thumb.jpgpost-848-0-72216900-1362388860.jpgpost-848-0-35390100-1362388896.jpgpost-848-0-80161300-1362388928.jpg]
Current build:
Past builds:
Just received this book in today's mail. It's detail follows all of the great books in the Ancre line.
Woodrat
It looks like your off to a great start on this. I shall follow your build with interest as someday maybe I'll start this build also.
Good Luck and enjoy the build. You have great plans to follow. Hopefully you got an English copy. I bought a used English copy however it has two plate 32's and I'm missing plate #31. So if you have an extra plate #31 and need a #32 I'm willing to swap.
Later 42rocker
Current Build -- Finishing a 1:1 House that I've been building for a while
Current Build -- Triton Cross Section
Dick,
a very promising start. Like you, I love the red colouring of jarrah. Haven't encountered any problems using it yet.
Regards,
Grant.(the other one)
Thanks Grant, Guy and 42rocker. The jarrah is working out OK as a framing material. Here is the completed stern section. I am going off air for a while as I make some more frames. A bientot.
Dick
post-848-0-21638100-1364134481.jpgpost-848-0-75360900-1364134628_thumb.jpgpost-848-0-92846900-1364134678.jpg
Current build:
Past builds:
  • 3 months later...
The stern framing completed before fairing. A slow process!post-848-0-24929100-1374408926_thumb.jpg
Dick
Current build:
Past builds:
Nice work on the tricky part of the framing. You commented that some modelers might not like the color of Jarrah: it only has to please you! I find it quite attractive in the photos. What is the finish you have on it? Looks very shiny.
Thanks, Druxey. Some of the earlier photos are after application of orange oil, hence the shininess which is temporary. The latest photos are raw timber. The timbers around the transom show darkening from the orange oil.
Dick
Current build:
Past builds:
Dick - As others have said, beautiful work! I too will be following along!
Eddie
<p><span style="font-size:12px;"><strong>"Be yourself. Everyone else is taken." - Oscar Wilde</strong></span></p><br />
<p> </p><br />
<p><a data-ipb='nomediaparse' href='<a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/2720-elsie-by-4whelr-modelshipways/#entry73752'>http://modelshipworld.com/index.php?/topic/2720-elsie-by-4whelr-modelshipways/#entry73752</a>'><span style="font-size:12px;"><strong>Current Build - Elsie</strong></span></a>
Blackcreek,
Post your offer in the Traders and Dealers section.  Follow the guidelines and the sale should go well.
masting.
Hello!
Can you post a picture of the stern with that detail ( a plan) . I´m very interested with that port. Somehow is like you are making the stern weak. I mean not you but the shipwright at that time.
Regards.
Daniel.
Edited by harvey1847
  • 2 months later...
sorry I have been off-line for some time, but not idle. Have now made a start on the bow section. post-848-0-27510800-1385389485_thumb.jpgpost-848-0-72759300-1385389567_thumb.jpgpost-848-0-88846500-1385389587_thumb.jpgpost-848-0-42587600-1385389862_thumb.jpgpost-848-0-72553900-1385389919_thumb.jpgpost-848-0-10322500-1385389923_thumb.jpgpost-848-0-63689900-1385389926_thumb.jpgpost-848-0-80530600-1385389672_thumb.jpg This shows the shaping of the first and second hawse pieces - closest to the stem postpost-848-0-92611600-1385389653_thumb.jpgpost-848-0-71943500-1385389703_thumb.jpg
The first hawse pieces in place.
More to follow soon.
Dick
Current build:
Past builds:
Here are the outer hawse pieces in process of installation. This has got to be the most tedious part of the build! I think it will be worth it :angry:
Merry Xmas all.
Dick
Current build:
Past builds:
Just found your build, Dick. Looks to be a very interesting project with some great progress. I'll follow along for the ride too.
Cheers,
(yet another) Grant
Thanks, Grant and excellent work on the Victory, by the way.
Dick
Current build:
Past builds:
I purchased the Warrior practuim for my next build but , have put it on hold as I was drawn to this model of Gros Venture and just recently purchased this book and plans set. I think this ship will be my next build and there is a historical link to Australia with her.
Good choice. the plans are very good. Are you going to go POF or POB?
Dick
Current build:
Past builds:
Dick,
plank on frame with exposed areas Admalty style.  I looked up the meaning of Gros Venture and to my amusement, it means big belly.
Quite an appropriate name for an exploration vessel which needs to carry large amounts of supplies and spare parts for an expedition to the other end of the earth.
Current build:
Past builds:
