The finished product, one picture shows Allen screws and a wrench, that is for assembling the rack halves. I tried to operate it but forgot how so now I'll have to get that figured out, next time I'll write down how I work this thing. Anyway this is the end of the road as far as building goes but maintenance and sea trials will be next. Thanks to all that commented and gave input, next on the burner will be Charon the boat man of the river Styx!
I looks great, Ben.   I hope you'll post the sea trials.
Congratulations, well done on a fine project.
Bob
Current build:  SS_ Mariefred
It looks gorgeous in the photos and probably even better in person.  I hope the sea trials go well.
  • 3 months later...
First sailing after completion, a major amount of adjustments needs to be made to the radio such as channel assignment and servo travel. I also need to change the rudder system, so Charon will be put on hold until I get this one perfected. It is at least water tight and the only water that came in was from oar splashing. WARNING: Video is very painful to watch!
I liked it.  Very maneuverable...  What did I miss that makes it painful?
Trying to operate it!
:D  :D  :D   I daresay you're right... rudder, left side, right side, forward, reverse.. I wouldn't want to try it but I like watching it.
Hi Willie
Love it!  Apart from the minor technical issues, (of which only you would know about, because you're the operator), the only way that your video could be any better would be to sail her in a more natural setting.  Perhaps a lake, or the river, where the colour of the water isn't so clear. That'd be far more realistic.
But, that's nitpicking, of course.  Damn marvellous job you've done!
All the best
Patrick
You have a speed boat of a bireme.  I doubt the rowers ever moved that fast.  Slowing your motor to scale speed will probably give you better control.
Bob
Thanks for the input Guys! Bob you are right about the speed that can be part of the tweaking I'm going to have to do some rewiring and change the rudders to be more effective so not just radio work to be done. Patrick I bought a fishing rod to retrieve the boat in a more natural setting once I get it stuck on my maiden sea voyage! It's been fun but will be much more fun once I get the bugs worked out. Walter thanks for the compliment this thing has been about a year and a half of dedication so it is almost at the place I want it.
This is much better, I had to change the model configuration from airplane mode to helicopter mode H3 which means three servos work in unison on the swash plate. Two of the swash plate channels are being used for the two speed controls on the pitch cycle which inputs each speed control equally on the pitch function. They are influenced to work opposite to each other when you use the elevator/aileron stick which raises one side and lowers the other or speeds one side up over the other. This function will allow the oars to move or go faster on one side or the other
Super, Ben.  I agree with Greg on the engineering feat.   She will be a sure fire hit on any lake or pond you take her to.
