Hi Denis
It's great to see that you're able to work on Syborn, after all, it's been a while inbetween posts.
The mast with the fittings that you're adding is going to look great.  That, together with all the other details that you'll add will make Syborn a really character-filled beauty.
I'm definitely looking forward to more updates!
Cheers
Patrick
thanks Patrick  :)   and to all who hit the like button.   Friday didn't turn out as I would have liked.......I wanted to add more framework and the pads for the lights.   now I am in my work week....two more days to go.   the catalyst for this flurry of activity,  is upside down on my main table, awaiting the hull sides and bottom panels  {they call it planking,  but I think they have rocks in their heads}.   if anyone remembers the Maine Lobster boat........I really stunk at doing this type of assembly.....and ended up actually planking the hull.   more will come soon  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
thanks Lawrence......it just the beginnings of the mast....I have more to add.    I have been disheveled of late.......the mind has been too cluttered to spend time at the table.   I do feel better,  now that the tree boat looks more in line to what it should look like.   I wanted to spend some time here with the trawler,  but the process to get me where I wanted to be was a bit longer than anticipated.   I have one more day of work.......
thanks for the good word...I appreciate it  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Just found your build log Denis. Very nice craftsmanship! It's looking great!
Jesse
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Wow!!!...... this is a great!! build Denis.... just found this one.....  love what you  are doing with this build,
this one is going to be hard to top :P
Frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Nice to see you back at the table Denis; very nice work!  It can be a real problem finding time when there are sooooo many things to do :)
cheers
Pat
Edited by BANYAN
thanks Jesse and Frank......it's been a while since I last posted on this build.   there's still much more to go on her....so there's still more to see  ;)
    welcome and hope you follow 'till the end  :)
thanks Pat.......I'm just glad {and fortunate} that it isn't 'cuz of sickness.......way too much of that going around.   spending more time on the Tree Boat as I did,  ........the thought process flows better doing timely things,  rather than to make time for the transition of events.   I should have started the mast when I was thinking of it.   we'll see how much of what I was thinking about.......I can remember  ;)  :D
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I made a bit more progress with the mast.   there more to go,  bu I gave it some frame work.
then....if you remember,  I made a mention about a ladder,  if I went this route in adding the top.   rather than try making one out of wood.........I'm going to try and solder something together.   the welding wire is very stiff.....took like forever to get straight.   I made up a jig to do this on...............making eyelets on the ends of both wires,  they are fastened to the board with push pins.   there is another piece of wood that has pins in it,  to insure the width of the wire and to hold it steady while I solder the rungs on.   the rungs will be held in place by other longer pins.   this will be a long ladder,  so it might take a while.
I'll try and show you what it will look like.........I have a few done already.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
looks like you are very busy on the Syborn trawler,
there is nice progress the last days.... :)
Nils
Current builds
-Lightship Elbe 1
Completed
hello Nils  :)     yepper!   try'in to spark some life back into one of my other builds  :D   more to come.......and something you might be interested in.....perhaps even a suggestion or two,  given your metal prowess  ;)  thanks for the good word  :)
hey there Patrick........yea,  cat's out of the bag........got a small project going on.   trying to get multiple things moving,  and stop look'in like a one armed paper hanger.   I still have a little more to go on the mast.......and then,  there's the ladder...a very long ladder  ;)   thanks for the good word!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
OK........I did say I'd try and show you what I'm doing for this ladder.   the welding wire is stretched out on the board,  the spreader is set up with pins,  to keep the width of the wire even all the way down.   I need the ladder to be around 8 inches long.....the longest ladder I've ever done.   I liked some of the results from my experiments.....but there is one method I haven't tried yet....solder.   I take that back.........I did try it and I failed........I will attempt it again.  so I've soldered around five or six rungs at this time...........seems every time I start,  something comes up......GRRRRRR?!?!?!?!
looks kind of gaudy to me....which is what I encountered the last time I tried this.   here is the spreader......set up and doing the job.......I may have to adjust it from time to time.
I have both means to solder.....this one allows me to do this in the house.   the other one will no doubt set off the fire alarms....he..he  {second floor does it all the time.....she's a bad cook!}.  I've had this soldering iron for quite some time.....I should try out the new one I found.......yepper.....found
I'm using light electronics solder to do this.........I'm wondering if a flame would lessen the amount of solder.   I'm trying to use as little as I can.  should I also sort of paint the wire with the flux before soldering,  instead of just dipping the tip of the iron in it?   there is a rosen core in the soldering wire,  but probably not enough for the application i'm using it for.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Looking good Denis.  Better not let the boss read this - you may go hungry for awihle ;)
cheers
Pat
I'm not sure how it works with this type of soldering but when I was a bench jeweler I always applied flux to the joint before soldering. That was a whole different kind of soldering so I don't know if it works the same here.
Jesse
I put flux on the parts even though I'm using flux core solder.  It seem to help.  But like everything else soldering takes practice to make it look good.  By the time you finish the eight inches the solder should look pretty good.  Then you'll want to go back and redo the start.
Bob
Current build:  SS_ Mariefred
thanks Pat.......I know it took a few days to reply......I was still wrestling with the work week.   I've taken two days off.......so I got a couple more days to finish this.   I didn't mean my admiral........second floor  :D  :D   we go out on our porch sometimes and the smell from up there makes us wonder what the heck they're burning up there...........besides weed  ;)  :D  :D
thanks Jesse.......I'm sure it's the same principle.   I did think of that though......this welding wire might have some kind of coating on it.    might be good to rough it up some  ;)
Don't tell me that Bob...........that means I'd better do 16 inches!  I used to do my own plumbing back when we owned our home.....that was a lifetime ago though.   I will try the new solder iron and see if there is a difference.   thanks for the good word.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
as mentioned earlier........good suggestion about the flux,  in the event that the welding wire has some sort of coating on it.
I used a Q-tip to swab the wire with flux.   I believe the wire changed hue a little bit there.   it may have been the case,  because it went a bit better after that.   I still had some trouble with the heat transfer loosening up the closest rung....I had to keep going back over them.  it turned out to be a good thing though,  since it picked some of the excess solder along the way.
at this point,  I measured it with the ruler... 6 3/4........getting close to the 8 inch mark.  I counted the rungs......I was curious.
     it felt like more than that.   is this one of those thankless repetitive tasks I hear tell about?
the solderings are getting better..........with a little filing,  it should look OK.
finally.........I made it!   I even gave it a little more....just in case  ;)
might be hard to see.........8 1/2!   not for the sizing and clean up!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
does anyone have a Z scale train I can borrow?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Nice going Denis!
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Looks good and solid Denis, should work a treat.  next time you have to do this try using an alligator clip between the previous (soldered) and new joint as a heat sink - it can be kept out of the way and should wick excess heat before it destroys the previous joint.  may be worth a try at least :)
cheers
Pat
That will bring you to the top without much hassle ... nicely done. Maybe for a next time: juwelers use either a cooliong paste/gel or what they call Brusselse Aarde  to keep already soldered parts from loosening when they need to solder close to a previous joint
Carl
Jack
Current buildUS Constellation
thanks for the kind comments and the likes........I'm very glad to get back to this build.   a couple of the builds,  I still need to get stuff for,  so I'm kinda hung up.   I just got a fresh supply of dowels.......so that renegade fishing boat can continue,  as soon as it gets it's color.........paint.   perhaps even a name.......;)
hi John........I couldn't agree more,  a metal ladder would fit the bill here.   I'm glad to say it's done!  :)
thanks Pat and Carl.........those are two very good ideas.   I will remember them in the future.   even though the rungs coming loose was a problem,  it really didn't slow me down too much.   I just needed to take the time to sit down and do it.........and that's what I did........I sat at my desk and did it.   it feels good though to get all that stuff offa here though....it made my desk look as cluttered as my table  :)  ;)
thanks Jack,  Patrick and Lawrence for the birthday wishes.   to get to have a day like this,  with no problems or mishaps,  is all I would ever want  :)    it's been a great day thus far.
I can't wait to show you what I have done this morning.........I think it came out fairly well  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
and so....the ladder is complete.   it's not quite as good as I would like.......but now that I see it on the model,  it's good enough.   this morning,  I removed it from the board and straightened the eyelets that I had bent into the top end of the uprights.   knowing that the cutter would send the trimmings flying,  I perched the waste basket between my legs and pointed them into it.   quite a few of them went through the bag!   when I was making these small pieces for the rungs,  I would capture the length of wire between my fingers and snip the wire.   doing this for a time,  my grip became limp,  and with a snip,  sent one of them into my finger like an arrow!   talk about bleed.......
       that was my only incident though.......so that was a good thing  ;)     anyway.......once all that was done,   I did some sanding and filing to knock down all the nubs
while this was going on,  some would come loose.   in soldering them back on,  I robbed the excess solder from some of the gobs,  and made them look a bit better.   filing should take care of the rest.
again,  I went into that little container of all the punch outs that can be had from kits.  I save them and use them for a variety of things.   I took a couple small circle.....cut and sanded them to {or about} the same thickness......I needed three of them.
     these are to be the mounting plates for the mast lights.   they were cemented to the light brackets on the mast.
curving the uprights at the top......I was able to locate and drill the holes in the backside of the top,  to locate the ladder in place.   I drilled four holes down the mast and fitted pins that will secure the ladder to the mast.
somehow.......I wasn't pleased with it.   OK to be secure,  but what about side to side movement.   I then got the idea about the strapping.........wrapping it around the mast,  and attaching it to each side of the ladder.   so,  I cut some thin strips of brass and did just that.   I have two on there now,  and it seems pretty solid........I may add a third one further up the ladder  {I'll need a longer strip I think}.
I want to put a few more brackets under the top.   then add the railing around it.....should be ready for paint by then.  it will make the ladder look better.......I did a lot of filing between the rungs.......the shiny solder hides it at the moment  ;)
back to work!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Denis
Now, that's impressive!  I like the ladder and the extra realism that it adds to the mast.  I can just imagine some happy-go-lucky crewman jumping off the top into the water just for kicks!
But, without a doubt, it most certainly looks the part.
Ouch, also for the bleeding thumb!
Hope all's well.
Cheers
Patrick
Edited by Omega1234
all is perfectly well Patrick   :)   had some pizza and beer......followed with some cake and ice cream.......I'm feel'in like Hoss cartright right now   ;)  I didn't get much further,  I'm afraid.........I added another strap to the ladder and was in the process of installing the railing,  when company came over.
I hope to resume tomorrow   ;)
thanks for the kind comment and the likes all.   :)
oh.........I almost forgot the cake!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Real nice job on that ladder......that really sets it off...
Frank
                         USRC "ALERT"
Hi Denis
If I remember correctly, your birthday cake today rivals last year's cake!
Glad to see you've had a great day.
Cheers
Patrick
