Hi Johann, it is nothing difficult. Thimbles are made from brass tube 1,0x0,1 mm (resp. 1,5x0,1 mm). The tubes are cut to lenght cca 0,8 mm (resp. 1,2 mm) (see first picture) and then they are slightly compressed on both sides by a punch and hammer.
So blocks for masts are prepared and partly installed on the relevant masts, now I will continue with the blocks on the yards.
Greetings marsalv, while doing some research on another project I discovered your Pandora build log.
Your work is truly inspirational. Taking the time to read the whole log will be a good investment of time and energy.
I'm sure I will learn a lot. Thanks for sharing your expertise with us mere mortals.
Regards, Harley
Cheers, Harley<p
Under Construction:    USS Yorktown CV-5 1/200 by Trumpeter
Completed:              USS Curtis Wilbur DDG-54 1/200 by ILoveKit
                                USS Atlanta CL-51 1/350 by Very Fire
                                Liberty Ship John W. Brown 1/350 by Trumpeter
                                HMS Spiraea K-08 1/350
                                 USS Arizona BB-39 1/200 by Trumpeter/Mk1 Design
                                 HMS Sir Gareth 1/350 by Starling Models
                                 USS Missouri BB-63 1945 1/350 by Joy-Yard, 9/11/21
                                 USS Indianapolis CA-35 1945 1/350 by Trumpeter
                                 USS Kidd DD-661, 1945, 1/350, on The Sullivans kit by Trumpeter
                                 USS Alaska CB-1, 1/350, Hobby Boss, Circa 2/1945
                                 US Brig Syren 1/64 Model Shipways, Wood
Started, On Hold:  Frigate Confederacy 1/64 Model Shipways, Wood
Thank you Albert.
So finally is here a moment when I started the installation of masts and related standing rigging. As first I installed bowsprit and the following ropes: gammoning, inner and outer bobstay, bowsprit shrouds. At the same time, I have prepared footropes with a netting, the picture shows only temporary attachment, the final attachment will occur after the installation of the stays.
Stunning! I particularly like your rigging.
Cheers, Derek
Current build:   Duchess of Kingston
On hold:              HMS Winchelsea
Previous builds:  HMS SpeedyEnglish Pinnace, Royal Yacht Caroline (gallery),
                            Victory Cross-section (gallery), US Clipper Albatros, Red Dragon (years ago!)
On the stocks:    18th Century Longboat
