That looks fantastic Marsalv !!I assume you are using a hypodermic needle to 'drill' the treenails.Excellent work B)
Kind Regards
Nigel
Currently working on Royal Caroline
Thank you all for nice comments :) .
I used usual hypodermic needle with diameter 0,8 mm (21G). Needle is carefully ground to the tip - see pictures. As wood is used pear, a necessary condition is that the wood fibers would be parallel to the needle. Is it possible to make treenails with diameter 0,45 mm (needle 0,7 mm 22G). You can see the comparison between 0,55 and 0,45 treenails in the last picture.
Marsalv I have not seen this done before. I am very impressed with the cleanliness of the treenails and of the resulting holes in the sacrifice block.
given the shape of your cutting edge and that there is no clearance for the cutting waste, I am also surprised that there is no discolouration or burning of the wood.
First question, are you cutting at high low or medium speed?
Second question, do you have to make short cuts and retrieve the drill a few times for each treenail? (raise and lower the cutting edge)
Third question, how do you extract the treenail from the needle? or is it still attached to the sacrifice block?
regards Michael
Hi Michael,
I will try to answer your qustions (sorry for my bad english).
Proxxon drilling maschine has 3 spindle speeds and I use the medium speed. Each treenail is made only with one down/up movement of cutting needle. Sequence is following - down with needle, up with needle, movement wit XY table and again. It´s pretty fast. You must only watch, if you can see treenail in the wood block after drilling. If you see no treenail (black hole), needle is propably blocked with wood and you must clean it. It is also the answer to your third question - treenails MUST stay in wood block. After drilling cover the face side with holes with adhesive tape, carefully cut off the opposite side and then push and remove the treenails from the block. It is easy :) .
Thank you that makes sense.
Michael
Hello Marsalv,
yust found you Pandora build log and I'm amazed of very fine work! Excellent! Will follow with interest.
Alex
Current build: HMS Sphynx, 20 gun ship launched in 1775 at Portsmouth, Hampshire.
On the drawing board: HMS Anson, 64 gun third rate ship of the line, launched in 1781 at Plymouth
Marsalv,
NMBROOK just referred me to your build to see your treenailing technique. Wow, what an excellent idea! Repeatable and time saving with a perfect treenail, it doesn't get any better than that. You are a true artisan :).
I would like to see how you ground the hypodermic needle down, if your so incline :)
Sincere Regards,
Bill
Passion is Patience...and I am a carpenter in any scale.
Current build;  Endurance - 1:70 scale, Occre
Current build;    H.M.S. Surprise - 1796, 1:48 A L
  • 7 months later...
Thanks to all :) .
To amateur: I wanted to build a model in scale 1:48. But due to space limitation I chose  a compromise scale 1:52.
Now is the time to show the figurehead which made for me Doris (for those who do not know her work http://modelshipworld.com/index.php/topic/854-royal-caroline-by-doris-card-1749-140/?hl=doris).I appreciate very much this assistance because my attempt would probably ended very pathetic.
Neat planking! Really good work. And great figurehead too.
Alex
Nicely done,.........one to follow for sure!!
JP
Built & De-Commissioned: HMS Endeavour (Corel), HMS Unicorn (Corel),
Abandoned: HMS Bounty (AL)
Completed : Wappen Von Hamburg (Corel), Le Renommee (Euromodel)... on hold
Current WIP: Berlin by Corel
On Shelf:  HMS Bounty (Billings),
