Michael,
I'm so glad you are a perfectionist and like to re-make up your mind. Now I haven't missed too much luckily, and still get a wealth of information on brass work and ship fittings e.a. Keep it up!
Carl
Alex, Carlos and Carl, thanks for your kind remarks. I have been away for a few days in the rocky mountains accompanying my good lady at the Library Conference. I had a great time no phone no computer, tons of good food spectacular environment, great accomodations.
So I will be back in the shop tomorrow, back at the workbench doing a little more fiddling.
Michael
Not a lot to report, other than I am redoing the method of attaching the lower dead eyes.
instead of a bent wire loop I am cutting out a sheet metal loop, I think it will be cleaner overall.
Michael
john thanks I noticed that the edge of the rail there needs a little refining too.
Michael
I like it.
Bob
Current build:  SS_ Mariefred
John, Bob, thanks.
I finshed the other three deadeye clamps.
I used a couple of pins to set the level, this also ensured that both sides were even to the holes.
This afternoon I worked on making some thimbles for the ropes. The fiest task wqas to cut some strips ofr brass 1/8 x 3/4 x 1/64 thick.
These were annealed.
Next I made a special benting jig out of some 1/4 x 1/4 square steel, this had a groove cut with a1/8th ball end mill. and then the end was shaped with some files.
The brass was placed evenly so that a short area was laying over the grooves either side of the flat.
the brass was shaped with apiece of .073 steel rod.
the flat area allowed the ends to bend easily over the steel form ready for the final shaping.
end part one.
Michael
After folding the brass over the steel it was ready for the curve at the end I used a loop of the same hard rod, this had to be heated red hot to bend.
the loop was hammered down to create thecompound curve in the rounded portion.
the ends were filed even before folding the thimble closed
a rope wrapped around the finished thimble with a shackle.
now to make a few more.
Michael
Russ, If I could find a way to make these relatively easily I would be happy to oblige.
John, not really a blacksmith more like a brassbasher.
Druxey thanks.
Andy, bottle screws and turnbuckles are out because I do not have the left handed taps and dies otherwise they are not too dificult. Senhouse slips, now that one I had to look up, clever device that. Those would be easy enough but I don't think I will need one.
Thanks all for your kind remarks.
Of course the proof will be making a few more without taking all day. All these different items are all about sorting out how to make things that will be needed for completing this model and then will be useful knowledge for the next build, when this one is finished. Every time I turn around it seems there is something new to figure out.
Michael
Michael,
Your abilities shine brightly.  Not just your ability to make all these small parts that a real boat has, but also the ability to figure out how to make them.
My Cap is off to you.  In which case I’m just Bob
Michael and Andy,
I always thought that 'turnbuckle' was the North American word for 'bottlescrew', but you've both used both terms - Is there a difference?
Michael, you could always put a Senhouse slip on the lashing for the dinghy! :)
John
Bob, thanks for your kind words.
John, what Dinghy?
Andy yes when I looked up the term bottlescrew up came Turnbuckles.
Ron thanks for your kind thoughts.
So today I think I might have screwed up the first batch of thimbles
Started out well enough these after the initial bendings following the earlier sequence.
I closed up the thimbles by wrapping the rope and then squeezing the open end between my thumb and index finger.
thimble closed
a mottly crew of thimbles lined up
but then I shortened them because I thought they were too long.
Now I am not so sure, and think they are too short.
I will need to do some reading now and find some real thimbles to get the proportions correct.  Oh well!
Michael
Hi John the link want me to download adobe Flash player and I already have flash player so I am not getting the info but I did find this page which seems pretty good. the download is a line drawing with all the sizes for different thimbles.
I just swiched over to firefox because IE kept getting hung up.
Michael
Edited by michael mott
A little break from the brass work, I have made the four shrouds,and served and seized the tops, the bottoms need to be done next. I made some mods to the serving machine which I posted over in tools. the shrouds are made from 4 three strand ropes of 6 yarns per strand and they are .093" diameter and the forestay is from 4 three strand ropes of 10 yarns per strand and is .120" diameter.
Michael
If you want your thimbles to close better, try filing the inside edges so when they meet, they will close flat. It may take away some of the channel at the end, but this is proper for a full sized thimble. Otherwise, job well done :)
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
Michael,
Thanks for showing us how you make the thimbles.  It’s a lot easier than the other methods I’ve seen.  But as Andy said, you need to file the insides.
Bob
Michael,
I've been away from MSW for a few weels and trying to catch up with everyones progress.  Needless to say your work is awsome!  Keep posting your progress.
Cheers,
Tim
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
Michael,
I was thinking, to build so many details is one thing, to spend time on top and record the progress by taking pictures, is something else.
We all know how time consuming it can be when we want to take  pictures, especially when the pictures  are of such quality and detail like yours.
A job well done!
Stelios
Current build: not decided yet.
Previous builds:
Traditional Greek vessel "Symiaki Skafi" (scratch)
Traditional Greek vessel "Perama" (scratch)
HMS Bounty (kit)
Andy, Bob, Timothy, Thanks for the great feedback, Yes regarding the thimbles now that I know how to bend them and my practice seems to have worked out well enough the next step will be figuring out the filing of the ends to make them close the way they do in full size practice.
Michael
Stelios we must have been posting at the same time, thank you for your kind remarks.
This evening I made one of those critical errors that one wishes they could take back but alas I will have to make one more of these.
Yes I cut the shroud instead of the tail when trimming to length....... Arrrrrrrrgh!!! when preparing to serve the dead eye end.
Michael
