Posts posted by James H
35 minutes ago, Blue Ensign said:
Nice Job Kevin, but the sight of that flying jib boom makes me very nervous, you've just doubled your workspace requirement.🫤
It's for that precise reason why Im masting, shrouding and rattling mine BEFORE the bowsprit is fitted 😆
- Old Collingwood, Oboship and mtaylor
- 3
29 minutes ago, DB789 said:
I’ve donated too. This is a fantastic resource and much appreciated. Thank you. Dan
Much appreciated. One thing MSW will never do is monetise by way of restricting areas that are currently public, nor will we inundate anyone with spurious popups or nonsensical content in order to monetise, as you see on many sites....with Amazon links and video popups advertising breakfast cereals!. Donation drives are the best way of doing this.
The only areas that have to be paid to access are the downloads to projects such as Winchelsea, Triton etc.
- mtaylor, DB789, chris watton and 6 others
- 9
Beautiful! Those chainplates easy enough?
- mtaylor, Old Collingwood and Kevin
- 3
Ok folks, this is now up to Volume 50.
That's some heavy work. Go grab yourself an article and have something to read with that beer tonight!
https://thenrgstore.org/collections/articles
- Ryland Craze, trippwj, chris watton and 3 others
- 6
7 hours ago, allanyed said:
Thanks Alan, but I am still not getting it. This is on me, not you, for sure. The long bolt passes through top, middle and bottom block as well as what looks like a metal bracket. What part is anchored and where is it anchored so the carriage can pivot on this pin? If anyone has a top view that would really help. Looking at several modern photos, they look nothing like the contemporary drawings, but surely there are some that are accurate reproductions if complete drawings are not available.
Thanks again Alan, MUCH appreciated.
Allan
Let's not turn a build log into a debate, like the diminishing wales thing.
Feel free to open a topic on carronades that can be used for reference. That's the best way to expend this thirst for knowledge. Please use this topic to enjoy Glenn's ongoing work on Indy.
- glbarlow, mtaylor, chris watton and 2 others
- 5
When I painted the internal walls, I didn't use the VM paint as the sets weren't ordered.
What I used was an equivalent colour from Gunze, and airbrushed it on. In hindsight, I should've prepped those areas with Tamiya aerosol white primer as that covers the engraved colours far better.
Check them out directly, here:
We are in the process of bringing all of the digital journal articles up to date, and this has been a long task. Articles up to year 2000 are now available individually for only $2 each, with 20% discount for NRG members. Delivery of article is immediate as soon as you purchase.
I'll be bringing more Journal articles to the NRG site over the next weeks, so keep an eye out.
- hollowneck, Ryland Craze, mtaylor and 2 others
- 5
1:64 HM Britannic Majesty's Cutter Trial 1790 - Vanguard Models
This is the latest kit from Vanguard Models. I don't feel I can review this as I would with any other product, per se, as I already have a well known connection to the company. I don't want to be accused of having an agenda or bias. This will be an overview/in-box look at this release which is VM's 14th kit since the company began. It's also, for me, the first release in around 3½yrs that I haven't had any involvement with. The aim of this kit is to bring a relatively low cost naval vessel to market which is at a level where novices can try their hand. It's set at a skill level 2. We do go to great pains to make sure that these levels reflect the build as much as possible, and that they are benchmarks that can be trusted when you shop at VM. For more info on these skill levels, check out this page:
https://vanguardmodels.co.uk/understanding-our-skill-levels-ratings/
The box for this kit is quite compact and there's very little room left inside it, so I had to be careful in repacking this afterwards. A lining of bubblewrap lied within the box and inside that, all timber and acrylic parts are also wrapped in the same. There's no chance of stuff getting bashed about during transit. As with the rest of the range, the model is built around a laser-grade MDF skeleton and then lime planking is set for the first layer. Above water, the inner core bulwarks are from laser engraved and cut ply, which is then later doubled with an exterior pear later, complementing the second layer of plank that are also from pear.
Although I have included some images from the manual, you will be able to look at the entire manual online on the kit's product page too, for more clarity. You can see from those images that the MDF frame is another slot and lock affair, which is designed so the modeller may actually do a reasonable amount of construction before any glue is applied. This will ensure that the model is properly assembled and aligned to the modeller's satisfaction, before any of the more traditional work is undertaken.
There are seven sheets of pear, in varying thicknesses. Nigh on everything is pre-cut for the modeller, such as the inner and outer bulwarks (no planking needed), wales, gunwales, keel facings, rudder, etc. The keel facings fit the central keel core before second planking. This allows a rebate to be naturally created, that then lets the modeller neatly plank within and up to it for the second pear layer. You will also see the gun carriages, stairways, and various deck structures on these sheets. I am perhaps at a point where I automatically recognise everything that's visible here. The details supplied are, in my experience, higher than those in contemporary kits, with parts that aren't generic, but created specifically for the release. The quality of the pear is also high. Great pains have been made with this over the last years, believe me!
Here you can see the ply sheet which contains the initial deck. Also seen are the inner bulwark cores. These are engraved so the lowest, horizontal engraved lines sit along the lines of the ply deck. This ensures that the bulwark elevation and position are correct. On the ply sheet is also the innermost lower counter part. As standard, laser-engraved lime decks are supplied, complete with treenail details. These are very easy to fit and have no tendency to curl when installing.
Three bundles of timber are supplied for inner and outer planking, plus materials for the mast, yards and bowsprit etc.
This kit contains two frets of photo-etch parts in two thicknesses of material. You will see easily identifiable parts in these sheets, such as the depth markings, fishtail/horseshoe keel parts, eyelets, pump handles belaying pins, and chainplates. The latter are made from single pieces so there's no awkward assembly to be had.
The kit supplies an MDF cradle for construction, but the display stand itself is made from a lower section of mirror acrylic, with two clear and parts that clip into it. The reason for the mirror is to emphasise the vessel's drop keel much better and make it a feature.
There are two boxes of fittings. The first one contains rigging rope of various sizes, whilst the second has a wealth of other things, such as brass pins, cannon and carronade barrels, winch, rigging blocks, anchors, carronade wheels, glass parral beads, black card, and also a nicely made name plate for the mirrored display base.
For those unfamiliar with VM kits, the manuals are typically printed in an A4 format, as here, with some of the larger vessels having A3 manuals. All manuals are full colour and spiral bound. This kit also has eleven plan sheets which detail everything from parts maps, through construction and then onto rigging.
So, that is a look under the hood of VM's latest kit.
I'm not here to pass my own comments as I am too close to VM to do so. The quality of this release is commensurate with the whole range and nothing has had any corners cut to bring it to market. I also feel the price is fairly pitched for such a kit, especially with pear being included.
If you fancy trying your hand at this unusual little kit, then head over to the VM page and grab yourself a copy!
https://vanguardmodels.co.uk/product/trialcutter/
Topic pruned to bring back on track.
I adjusted our donations received figure yesterday too. We are now at about 40% running costs. Thank you all for your continued support.
- mtaylor, Ryland Craze and ferretmary1
- 3
The varnish is just to seal the timber before paint. I generally do this for any area that receives colour.
You can also use sanding sealer etc. but if you're not used to doing any of that.....just do as you normally would.
- mtaylor, chris watton, Mr Whippy and 1 other
- 4
At this point it really feels like the ship has soul.
Beautiful work!
- hollowneck, chris watton, mugje and 4 others
- 6
- 1
Massive thanks to everyone who has donated to our running costs.
Every donation, both large and small, are all appreciated
- chris watton, mtaylor, ferretmary1 and 1 other
- 4
32 minutes ago, aliluke said:
@NRG Office Manager Can you check this?
I've updated the % total on sidebar.
Many thanks to everyone so far
- Ryland Craze, mtaylor, VitusBering and 1 other
- 4
11 minutes ago, kurtvd19 said:
cotrecerf:
It is working now. A slight error was made when the offer was initially posted - it was corrected early this AM.
Thanks for being understanding and considering it as a donation.
If the donation does not work in the future, drop an email to the office and Mary will do her best to get it working and will send you an email when it is working - all our members are entitled to the discount.
Take care,
Kurt
Yup, that discount should now be working just fine.
- Ryland Craze, mtaylor and hollowneck
- 3
12 minutes ago, allanyed said:
You are right. There should be a way of typing in a unique amount like a lot of restaurant machines now have.
Allan
Ok, done.
- allanyed, mtaylor and Ryland Craze
- 3
7 minutes ago, TBlack said:
My only comment is that the site won’t let you give more than $100.
Ok, for anyone that generous, I've fixed that!
- mtaylor and Ryland Craze
- 2
- mtaylor, ferretmary1 and Chuck Seiler
- 3
2 hours ago, Dave Wood said:
Current ship
P&O Cruise ship Arvia 1:250
I'm on that ship next year!
Welcome to MSW.
- AJohnson, allanyed, Keith Black and 2 others
- 5
How to clean unsightly copper tarnish
in Building, Framing, Planking and plating a ships hull and deck
For my Indy, I wiped down the hull with ethanol to remove any grease and then used 0000 steel wool to polish to a shine.
Then I applied a matt varnish with turns it slightly pinky orange in colour.
