Everything posted by usedtosail
Thanks Popeye and all the likes. I am really enjoying the rigging of this ship. There is a lot to do but I think I have a good plan to get it all done in a reasonable time, like maybe this calendar year? I am taking my time though because I don't want to look at something and wish i had done it better. You all know what that is like. I finished adding the mizzen sheer poles and tied off the deadeye lanyards. You can also see in those pictures the breast backstays, which I added to all the masts, but are just hanging loose for now. These were supposed to be added to the mast tops before the fore and main stays, but on the main and fore masts I was able to slide these under those stays. On the mizzen I added them before the mizzen stays. These are just hanging for now because if I rig them now they will interfere with the ratline rigging. I did make the wire brackets that fit over the lower deadeyes that the bottom tackle blocks for these will be hooked to. It took be some trial and a few errors to get something that both looked good and stayed hooked. The plans are not much help with these. These and the triple blocks with hooks that go into them will be put aside until after the ratlines are rigged. Before the ratlines, I am going to add the snakes between the fore stays and main stays. I have done some experimentation and I think I can tie these like ratlines with clove hitches. We will see how that works. Xken has a different method he used on his Connie, which will be my fall back.
- 1,350 replies
- constitution
- model shipways
Its on my possible future builds list, but right now I am dealing with another American icon ship. Yours looks great, Mike.
- 504 replies
- washington
- galley
Thanks Rob and Popeye, and the likes. I finished the mizzen stay and preventer stay. These were a little tricky because with the bullseyes they had to go through on the main mast, the serving of the bullseye at the bottom end had to be done in place. I did these, then did the loop at the top for the mouse on the main stay, but the top loop first on the preventer stay. At the bottom, I already had the eyebolts in the deck for the bottom bullseye for these, so I stropped them with hooks that I just hooked into the eyebolts after threading the lanyards through the bullseyes, tightened them up, and tied off the lanyards to themselves. Now to add the sheer poles to the mizzen shrouds.
- 1,350 replies
- constitution
- model shipways
Happy Birthday! Do you believe another year has gone by. Stay well and have fun my friend.
Just found your build log Michael. Great work so far. I look forward to following along.
- 372 replies
Well I am back from a week's vacation in St. Lucia. What a beautiful island. The trip was a Christmas present to our two kids, as one last vacation together before they start their own families. It was great! But, now it's time to get back to work. I finished up the main shrouds and have added the mizzen shrouds. Here is how the main shrouds and deadeyes came out: And the mizzen so far. I still have to add the sheer poles and tie everything off. And here is some overall shots so far. The masts are in good alignment so far. As always, thanks for the interest, comments and the likes.
- 1,350 replies
- constitution
- model shipways
Not at all Rob. i went into this project feeling like I have not done enough research, so any information from more knowledgeable folks like yourself really is appreciated.
- 1,350 replies
- constitution
- model shipways
Thanks Rob. I really appreciate your help and suggestions.
- 1,350 replies
- constitution
- model shipways
I am not sure how the vinyl works, but if you want to stay with wood I have found that a coat of primer on the wood helps the copper tape stick much better than bare wood.
- 742 replies
- constitution
- frigate
Your welcome Captain. I think we all benefit by those who have come before us.
- 1,350 replies
- constitution
- model shipways
OK guys, you convinced me. I tried a couple of different stains last night and did not like the look of the lighter ones, so I went all in and used Dark Walnut. They are a nice rich dark brown now, and as a bonus the deadeyes are darker too which look more like the real ones. Here is how it looked right after I stained the lines. And here is how they looked after they dried overnight. I was a little worried that the lines would get stiff, but if they did it was not very much. I am very happy with the result. Thank you for getting me to change this. Keep those suggestions coming....
- 1,350 replies
- constitution
- model shipways
Thanks guys. This is useful information. I remember reading or hearing that when the Connie went to all nylon ropes as it is now the colors changed to a darker color for the running rigging. I don't remember where I read/heard that, but that is why I am a little skeptical to use the existing rigging colors as gospel. But if it only a matter to stain them a bit darker, I will give that a try.
- 1,350 replies
- constitution
- model shipways
Thanks Dan. The lanyards are actually tan, not grey. I have always done these as running rigging. I have been following the discussion in Ed Tosci's Young America build on this subject and can maybe be convinced to use darker line for these. How dark would they be do you think? Not black but maybe a dark brown? At this point I am not sure i want to go back and replace them all though. Yes, you are right about shear/sheer. I was not sure and picked the wrong one to use.
- 1,350 replies
- constitution
- model shipways
Thanks for all the likes. I really appreciate them. In spite of some gorgeous weather this weekend, which the admiral and I did enjoy, I managed to get a lot done. It started with making and adding the shear poles to the fore mast shrouds. To make them, I used the thinnest brass rod that came with the kit, which I measured to be about .013" diameter. It took me a while to find a good setup in the serving machine that would hold up for the length of the serving, but I finally came up with this arrangement of clamps which worked well. The trick was to bend the rod at the ends so the clamps could grab them while being clipped around the nails on the serving machine, which prevented them from floundering around when the crank was turned. Of course this only works with full size rods. I did manage to serve a few short pieces by hand, but I wouldn't want to do a long piece that way. I found serving over brass to be a lot harder than serving over line. The serving line wanted to slip so I kept having to stop and bunch it back up with some tweezers. There were still a few shiny spots when I finished but I will touch up any of those that show with some black paint, as well as the trimmed ends of the rods. I tied these shear poles to the shrouds by starting with a loop with a slip knot which I tightened to hold the shroud to the shear pole, then two more half hitches in the same diagonal as the loop, then three more half hitched in the opposite diagonal, finished off with a tiny drop of glue. When all the shrouds were tied, I found I needed to also add some glue to the ends of the pole at the outside knots to keep the poles from slipping in the last knots. The last thing I wanted to happen was the pole slip out of those knots. You can see I also used xken's technique to place a strip of wood between the lanyards to lessen the twist on the dead eyes. There is also a short pole that goes just above the block in the swifter to the first shroud, which I did the same way. After I trimmed the loose ends of all the ties, I retied the deadeye lanyards to the shrouds above the poles. I used a combination of half hitches and loops to tie them. Further along in the build I will finish off the lanyards by seizing the ends to the shrouds. I finished adding all the lanyards to the main mast shrouds, and made one of the main stays. After I was satisfied with it I made the other main stay, but it was late last night so I don't have a picture yet. Here is the first one in place. Next up is to add the shear poles to the main mast, then start on the mizzen shrouds.
- 1,350 replies
- constitution
- model shipways
Here's some status for the week. I was away last weekend cleaning out the stuff from my father's basement, so all of this work was done after work during the week. He lived in the house over 50 years, so you can imagine what he accumulated. Found some good stuff to save though, and some good memories. My son and nephews chipped in big time to help me out so we filled up a 20 yard dumpster in about 5 hours. I finished up the fore mast shrouds and stays last week, and here is how they came out. This week I was focused on the main shrouds. I have all of the dead eyes seized and the lanyards in place. I will finish them off after the main stays are added, so I can adjust any tension that needs it. Starboard side: Port side: I am now noticing that the last dead eye is a little higher than the others, so I need to correct it. I also see from Ed Tochi's log that I should probably have put the shear poles in before tying off the fore shroud lanyards. Good thing they are not glued in place yet, so I can loosen them up to put the poles in without too much trouble. My goal this weekend, after those fixes, is to get the main stays made and installed and maybe finish off the main shrouds. We will see...
- 1,350 replies
- constitution
- model shipways
Very nice Dave. Those a bit tricky to get right.
- 742 replies
- constitution
- frigate
Excellent advise Frankie. I use that technique for all my seizings and it works great. Once I learned to do it properly rigging became a whole lot easier. One tip for you Mike, pull everything tight with the end marked a before you pull b. Otherwise you might get loops that form in the middle.
