Blue Ensign
  1. Post Sixteen First internal fixings While I continue to fettle the frames, at this point I felt it time to install the floorboarding and Platforms. The main floor went in without issue. 1457 The Amati planking clamps proved useful once again. 1490(2) I made up the aft and Fore platforms, pre-formed strips that went together without issue. These are simply edge glued together. Fitting the aft platform involves using Chuck’s simple height gauge to mark the correct level on the frames, which may be subject to some tweaking. I found that Frame 9 did need further reducing to allow the height to be marked. The gluing area is pretty small so weights are used to obtain good contact. 1510 Aft Platform completed. The Fore platform proved the trickiest to fit and by the end I was wondering whether Chuck was having a little joke at my expense. It is in two parts fitted either side of Frame (I) The larger section effectively balances on only one frame (H) and butts up against Solid Bulkhead (I) without any batten like support. The smaller section is butted against the forward side of Bulkhead (I) and rests on the ‘V’ the Foremost Frame ( J) I so wanted to add a support rail beneath this platform, and certainly would have done had I been solid planking the hull. 1492 I noted that Jean-Paul (JpR62) used a temporary batten taped to the Bulkhead to give support while the glue took, and I happily followed his example. 1495 Frame H took a lot of fairing to get the platform to sit in the right position with the aft end sitting on the forward section of Frame G and the forward end of the platform at the right level on the Bulkhead. Again, there is little gluing area and I used weights to ensure a good contact. 1497 The final piece of this testy little exercise is to fix the fore end of the platform where the intention is to make it appear to have mortised thro’ the Bulkhead. 1500 I must admit the gaps between floor and platforms I find untidy looking and unfinished. Surely a shaped beam, attached to the frames would have been used to support and secure the inboard ends of the platform planking. On a practical level whilst holding the model I did inadvertently put pressure on the forward platform which gave way along the seam. I am still toying with the idea of attaching a beam to the frames to give support. 1516 1502(2) 1512(2) I will spend the rest of the day cleaning and fettlin’ before I apply a coat of wipe-on-poly to dry overnight. B.E. 05/04/21
  2. There are no rules about building a model in any way you wish, but I think perhaps you are approaching the subject with the wrong mindset. By its very nature ship modelling is generally not a quick fix activity, and in order to get a half decent result the planking and hull construction at least needs, and indeed takes, time and effort. There is no real way around the need to fair bulkheads so that the planks lay correctly. or to shape the planks to some degree. Shortcuts generally involve leaving off detail or displaying a model without masting or rigging, for which there is a fine tradition in the form of Navy board style models. Having said that, you are of course welcome to start a log, who knows, once you start your enthusiasm may develop. B.E.
  3. As Alan says diluted pva is good for adding 'weightiness' to line. With cat tackles I suspend a small lead weight from the cat block hook and paint diluted pva on the tackle lines. B.E.
  4. Post Fifteen Completing the fairing of frame and rail. The method I trialled on the first few frames worked out well. Use of the scalpel speeded up the process, and I also used the scalpel to carefully reduce the width of the rails which saved a lot of sanding. 1414 Having sanded the outboard of the rail flush with the planking I used dividers to lightly score the near finish line which was sufficient to prevent the scalpel point running off-line. 1421(2) I used a template from the plan to guide the shape at the bow where it meets the stem post. 1428 Not there yet but getting closer. 1433 Using the width gauge to check a uniform width of 2mm Once satisfied with the rail I turned my attention to fine tuning the frames. 1434(2) The simple width gauge can be seen lying on the frame centres. 1438(2) 1435(2) 1442(2) 1444(2) 1445 The prominent sheer is apparent in these shots. 1439(2) It can be difficult to know when to stop, but I think I’m there with the rails and frames. Test fitting of the floors may prove me wrong in relation to the frames. I think some tidying up is required before I proceed to the next stage. B.E. 01/04/21
  5. Phew that’s a relief, but whichever way you choose she will look great.👍 B.E.
  6. Hi Glenn, Beautiful work on those guns, a joy to behold. 👏🏻 Just a point to check, should the cut-outs for the anchor cables be in the Main hatch gratings rather than the Fore hatch, if not I’ve made a major error on my build🤔 B.E.
  7. Thank you Rusty.👍 Post Fourteen Fairing and thinning. I felt myself getting a touch of the modelling yips trying to decide on the best approach to this task. At first glance the fining down of the frames and thinning of the rails seems a task fraught with danger given that there are some 46 delicate frame sides to reduce to a uniform and elegant shape. I decided to start at the stern area taking in the aftermost five frames. 1410 I am using a No11 scalpel blade to pare away in an upward motion to achieve a narrowing curve up to the rail. This reduces sanding time, creates a nice clean line, but has its risks in that I am working with the blade coming towards my steadying fingers at the rail. For this reason, a fresh blade is used every two or three frames, keep it sharp, keep it clean. 1411 Once I have pared down the frame to rail level, I sand the rail horizontally and repeat the exercise. I use a pair of dividers set a tad over 2mm to score the width of the rail which I then line with pencil as a guide. I picked up on Rusty’s log where he describes his use of a simple width gauge to check the rail width as he progresses. 1412 The difference to the yet unworked frames is clear. At this point I decided to move forward to the following frames and reduce them to the same degree before returning to fine tune the whole set. 1413 In my next post I hope I will show the successfully completed frame reduction task, but this may take some time. Cheers, B.E. 29/03/21
  8. You and David are surely a ship modelling dream team, beautiful work Greg. Is that a seat of ease, or a pisdale located in the bow bulwark? B.E.
  9. Ha, Ha, Bruce, testimony to Chuck's design, I think she'd stand more than a 2lb weight, but I'm not about to push it. 😉 B.E.
  10. Post Thirteen Cap Rails and frames I can’t say I’m looking forward to the slow and delicate process of adding the cap rails and fining down the frames. The Cap rails are first fitted and then the frames and rails thinned down to achieve a consistent 5/64” width along the entire length of the rail. I scratched my head a little over this. As we in the UK have used the metric system for many years, (Napoleon did at least win this campaign, eventually) for ease of working I need to convert. 5/64” as a decimal = 0.0781 x 25.4 = 1.984mm The finished rail is indicated as a hair less than 3/32” 3/32” as decimal = 0.09375 x 25.4 = 2.38mm I was a little puzzled as the working width seemed less that the finished width, but by less than 0.5mm. I decided to aim for a working width of 2mm. First things first, the frame tops are to be levelled flush with the sheer strake. Chuck is right these took more work than first envisaged. I started with the Starboard Bow rail. This needed a deeper recess at the stem point to allow it to sit at least flush at all points with the planking at the bow on the outboard side. (Probably something to do with my fairing of the bow area.) 1308 Once set, I fitted the Port side rail which was no trouble at all. 1310 The long centre rails were trimmed and fitted next without issues. The final stern strips involve a little more work, bevelling to meet the Flying Transom and notching of the Transom to take the rail. This begs the question how much of a notch? Given that the finished rail should be 5/64” or 2mm in my world. I opted to make the notch 2mm including the thickness of the Sheer strake. I pre-cut the stern rail from the Flying Transom forward to Frame 10 to a 2mm profile. 1311(2) The rails needed one further tweak, a slight edge bend to follow the inward curve as the rail meets the Transom. Here the lower Starboard rail has been subjected to the treatment. 1314 The ‘tweaked’ stern rails. 1321 Stern Rails in place, the pre thinned area aft of Frame 10 will eventually be continued along allowing for a flare at the bow. 1319(2) 1326(2) 1320(2) Sanding down of the rails to be flush with the exterior planking is mostly done, a little tweaking here and there. I now need to work out my approach to the internal fairing of the frames. B.E. 28/03/21
  11. Thank you, Bruce, and Rusty. @ Rusty – I only hope I can match your standard of rail/frame completion. Useful tips on your log, I like your use of a width gauge for the rails. Did you first start by thinning the inboard rails, or the frames? It seems to me that the rails would be sanded horizontally along the grain, and the frames vertically. Regards, B.E.
  12. Post Twelve A Barge emerges. A point in the build that I suspect many builders are pleased to reach. The hull is removed from its building board. I took this slowly and carefully as advised by Chuck, and it didn’t prove too onerous. I now have my first sight of the model the right way up unencumbered by the board. 1235 Front part of the board removed, so far, so good. At this point I was tempted to add the Garboard strake as shown in Chuck Seiler’s build, which would also no doubt help to counter any tendency for the hull to hog, given the length and fineness of the keel. I rather liked to look of it, but I also liked the view of the deadwood at the stern which would be obscured by the Garboard strake. Decisions, decisions, but in the end I opted for the original Chuck presentation. 1238(2) I modified the building board for the second stage of the build as suggested in the instructions. Stem and stern post supports are necessary to hold the hull secure. 1242(2) I am a big fan of Balsa blocks to support models whilst working. They are endlessly re-worked to suit each new project. 1244(2) The barge is now held firmly in place for me to begin the business of frame centre removal. 1246(2) For this delicate operation I am using an etched fine-toothed scalpel saw. 1286(2) The whole process went very well, a few of the frames broke away from the planking but were easily re-glued, and there were no breaks in the frames themselves. 1281(2) Once cut, the centres came away easily using a gentle rocking motion. The discarded centres will no doubt come in for other projects. My covid hairstyle continues to develop, and still several weeks away from a barber, but who needs a barber when you’re busy building a Barge. 1278 With all the centres removed I can now sight along the hull and clearly see whether my fitting of the Transoms looks right. 1287(2) It looks ok to my eye, but stare at something too long and………. 1290(2) A chance to compare this 36’ Royal Barge to my 21’ Pinnace, both at 1:24 scale. 1292(2) 1295 1298(2) Four weeks fairly steady work to reach this point and I have what looks like a Barge in Frame. Back under its cover for the Pinnace, and onto what Chuck describes as the most delicate stage of the build. I suspect progress is about to slow down. B.E. 24/03/21
  13. Thank you, Chuck, Glenn, Michael, and Kirill, and for the ‘likes’. @ Glenn – Clamping is such an important part of ship modelling, I don’t think you can have too many clamps, and getting inventive with methods is part of the skill set. @ Kirill – I do use ca gel but usually only in those areas where clamping is difficult or instant grab is necessary. I use pva in preference as it is kinder to the wood (and me) and it doesn’t mark the surface of timber or make it brittle, as does ca. The pva I use is a high quality non waterproof glue that grabs in around 5 minutes, unwanted spread is easily cleaned up with a paintbrush dipped in water, and water is used to de-bond the glue if necessary. The main thing I would use ca for is applying copper plates to hulls. Bonding other metal items, where I would have previously used ca I now silver solder where possible. Regards, B.E.
  14. All turned out very well Richard, this is the point in a build where the fun part starts for me. B.E.
  15. Thanks Peter, an oldie but a goodie as they say, but still a model that can be made a lot of. I think the plastic lion is ok and if treated today with artist oils could look really good. I'm glad they have replaced those plastic blocks and deadeyes, and there is so much stuff out there now to enhance models. I was forty years too early with my attempt. Cheers, B.E.
  16. There are scant details on MSW of builds of this iconic Billing Boat kit, and periodically questions arise, often concerning inherited or partially built models requiring completion or restoration in the absence of plans or instructions, which in the case of Billing Boats were somewhat thin. So, in the spirit of giving some images that may help, I post here my Norske Løve story. I must have posted it somewhere before but can’t for the life of me remember where or when, but I do have my original log and photos. A cautionary note, this is a model I made over forty years ago, so the standard of fittings, and the ravages of dust have taken its toll on the condition. If I knew then what I know now I could certainly have made a better job of her but she remains a model for which I still have great affection, and I have resisted the temptation to upgrade her. Those not familiar with the finer points of our art tend to be seriously impressed by the sight of her. ( Norske) Løve Story More years ago, than I care to remember, before my office was a den of computer stuff, and before the digital age, I had a yen to build a large scale wooden 18th century warship. In those days it was either Billing Boats or Billing Boats, and as I browsed through their catalogue my eyes alighted on Norske Løve. It was the image of the modeller putting the final touches to the model that grabbed my attention, I wanted to be that guy. BB Cat cover Yes, I still have that original catalogue, in those days I actually went to a model shop, can you believe it! Pity I didn’t have the internet resource back then, but I did have the Longridge book and perhaps more importantly the Masting and rigging book by James Lees. Given that the Norske Løve was launched in 1765 it immediately struck me that the round tops provided in the kit, were oddly out of period, more 17th century than 18th The masts and tops were therefore scratch built to proportions given in the Lees book for ships of the correct period. The other main area that gave me concern was the head. In common with many wooden kit models this is a weak area with a less than realistic rails set up. Catalogue shot of the bows These were therefore also scratch built. I made other ‘modifications’ not necessarily in accordance with the plans, such as a skylight on the Poop and removeable skids to house boats which were not provided with the kit. Billing at the time (and probably still are) were in the habit of providing some plastic fittings for their kits such as blocks and Deadeyes, decorations etc. I seem to recall that the fittings kit was a separate purchase to the main build kit. This is Billings catalogue shot of the completed model. The build took me a couple of years, and my office resembled more of a joiners shop than an office. Drill stand and vice screwed to the desk top, wood turning model lathe and dremel permanently plugged in where now the printer and computer stuff reside. Everything was covered in a fine film of dust, but boy how I enjoyed that build. When completed the model sat in a lighted cabinet that filled one wall of the office and that’s how it stayed for some years. With the arrival of computers and the need to use my office for its proper purpose, everything was changed. Away went the cabinet and all the modelling stuff. 1153 Norske Løve then proudly sat uncovered on a long chest of drawers, where it resides to this day. Strangely things have come full circle and in retirement my office once again resembles more of a workshop, but I don’t think the resident equipment would appreciate a return to the heavy sawdust days. So here is the photo collection of my interpretation of Norske Løve, 1120 1127 1134 1138 1139 The head rails were scratch built using yellow pine, but there were several breakages before I got a satisfactory set. The Lower and Middle rails are mortised thro’ the head timbers, and the Main rail rebated into the head timbers. 04 02 I recall the exercise being long, slow, and frustrating. 1151 I particularly like the stern and Quarter galleries with their glazed lights, one of my pet dislikes with wooden kits are false windows or even worse stuck on windows, such as with the Mantua Le Superbe that lies forlornly in the loft. This is one area where Billing have done a good job, there was very little tweaking to this area of the build. 1140 1170 The modified tops, scratch built to proportions given by James Lees. The plastic rigging blocks supplied by Billings were replaced by boxwood versions. 004(2) 1133 1152 The main difficulty with single planked hulls such as this is that there is little scope for cocking it up if you don’t want to hide it with paint. I also have an aversion to stub guns so the lower ports are closed. 008(2) 010 The Poop was modified by the addition of a skylight, and the Ensign hand painted on cotton. The simplicity of the Danish flag lends itself to this method. 007(2) I think the anchors were aftermarket purchases. The Boats 002 005 Boats were not supplied so I had to create my own. 1132 1173 The deck fittings are mostly removeable to assist cleaning which is evidently overdue when this photo was taken. 1145 Dust build up is clearly apparent here. 1135 I really prefer models out of cases, they have so much more impact, and 1:75 scale allows for reasonable cleaning access which in this case takes about three hours every few months or so. I hope those who cross paths with this kit get some benefit from this vintage build. Regards, B.E. 22/03/21
  17. Thank you Thunder and Mike. @ Mike, - rather than clutter your log with photos of my build, I will put a separate log on here for folks to use as they will. My build long pre-dated MSW but I do have a short log that I must have put on some other site, but where I simply can't remember. I hope you will find it of use. Regards, B.E.
  18. Post Eleven Flying Transom. This is another tricky piece to hold in the correct position whilst the glue bites. 1192 I used pva and bamboo poles to secure the angle and to support the Flying Transom whilst the glue bites. It allows me time to sight and check the Flying Transom set-up from various angles. 1201 1208(3) 1214 With the Flying transom in place I use a template taken from the plan to mark the curve down from the underside to the Transom base. 1224 The stern area is then taped up to provide stability for the next stage. 1226 I then carefully pare down to this line using a No 11 scalpel. 1228 The plank ends are then sanded back to the Transom face. 1234 1232 1231(2) The next stage sees her released from the base and the removal of the frame centres. B.E. 21/03/21
  19. Hi Mike, I built Norske Love many years ago, and still have it on display, it is an impressive model, altho’ not up to modern standards in terms of fittings. I too found it odd that the tops are shown as round on a ship of 1765, (more appropriate to the 17th c) and I replaced mine with the more standard versions of the time. I also replaced all the deadeyes and rigging blocks with Boxwood versions. These photo’s that I put up in answer to a question somewhere long ago give you an idea of the use of proper deadeyes and blocks and the modified Tops. Regards, B.E.
  20. Thank you Michael and Kirill. Post Ten Completing the planking. Three planks per side to complete what is the Sheer strake. For this work I have the hull the right way up as I find it easier to see and check the fit. 1126 I work with the model atop of the kit box which gives me a comfortable working position. 1128 The first bow plank (5) requires a bend to follow the bow curve into the rabbet and also a little twist so it lays square to the rabbet. A little tricky this one, on my build anyway; getting the plank to sit tight down on lower plank between the first Futtock and the rabbet was the main concern but a hairline gap should be covered by a moulding. The middle section (6) simply requires cutting to length and ensuring a close butt joint to the previous plank. The aft section (7) required a little shallow bending to round Futtocks 9 and 10 without tension, but I found it the most tricky to attach to the Transom and the extended plank run. 1135 I devised a bamboo pole support system to hold the plank tight against the Transom. Balsa wood support blocks prove useful in this situation. 1138 The final plank is put into place. It may all look a bit dramatic but the pressures are light and hopefully sufficient to produce a good bond. 1142 I left the hull to cure overnight. 1148 I have started to feather the clinker towards the stern, more to do but I think I will wait until I have fitted the Flying Transom which will stop any flex in the planking. 1145(2) 1146(2) 1155 The next stage is to fit the Flying Transom. B.E. 20/03/21
  21. Excellent work on the masthead ropework Michael, it looks splendid. You should take up Macramé 🙂 B.E.
  22. Hi Michael, I hadn’t realised that you are safemaster until Hubac made a link reference to my Le Praetorian build. Your work on these Heller kits is second to none, and your current project is no exception. I still fondly remember your 1765 Victory build, and the Figurehead, a magnificent bash if ever there was one. Glad to see you are still creating your wonderful models. B.E. (Maurice)
  23. Post Nine Fitting planks 3 and 4 This is where the clinker comes into play. Port and Starboard can get a little confusing when it comes to these pre spiled planks. What initially looks like the outboard face of Plank 3 on the fret is in fact the inboard face. When working with the hull inverted I have to remind my addled old brain that Port is on the right and Starboard on the left. Having bevelled the inward face of plank 3, the corresponding bevel of plank 1 is carefully pared down at the bow to allow plank 3 to fit into the stem rabbet with a feather edge. I find the 2mm Swann-Morton chisel blade perfect for this. 1071 The plank is water/heat treated to form the bend around the bow, and a small amount of lateral twist is imparted to the end of the plank to allow it to sit flush against the stem rabbet. 1069 With the plank temporarily in place the aft end can be marked for trimming on Futtock 2. As with the first planks I prepare both sides before any glue is applied. The Portside plank went on without trouble using ca, but I keep a small pot of acetone at hand to clean off any overspill on the face of the plank. The main concern now is to ensure that the opposite side plank has a uniform meet at the bow rabbet. 1073 For this reason and to give me a little tweak time I used pva for the rabbet join and the first two Futtocks. This allowed me to sight along the bow and make any minor adjustment before clamping in position. Use of ca would have precluded this. 1078(2) Light pressure is used and the model is set aside for the pva to cure. 1083 Plank three successfully (I hope) attached. I continued to use pva which worked out ok. 1084(2) It will stand a little more feathering into the bow but that can wait awhile. Onto Plank 4 Very little fiddling needs to be done, I did impart a little twist towards the end to allow the plank to lie flat without tension across Futtocks 9 and 10 and the Transom. 1100 At the sternpost I added a balsa support piece to brace the planking for gluing the extensions beyond the transom. 1106 The final plank 4 goes on without incident. 1113 1108 1111 At this point the clinker has yet to be feathered out at the stern. Onward and upwards to the sheer strake. B.E. 17/03/21
