Blue Ensign
  1. What a nuisance Bradley, hope you fix it ok, it is in an awkward position. I suppose you could get a replacement from Chuck to restore your options. B.E.
  2. Post Five Fairing. I approach this job with a degree of trepidation, being aware of the damage that can be done by a simple lapse of concentration in holding or manoeuvring, or a degree too much pressure put on the frames. Chuck re-iterates this point more than once. Using the fret from the Futtock sheets, I practised sanding the edges with a variety of different grade papers to gauge the removal effect and effort required to achieve it. 0929 I am using a finger sander with P150 and P240 papers, and Sheet P240 papers were also used. Using a fine touch was uppermost in my mind but even so a couple of frames dislodged from the keel at the stern, but it was easy work to re glue them. The process mainly seems to consist of cleaning off the char with actual bevelling only being applicable to the forward four and aft five Futtocks/frames plus the Transom board. 0935 I use a 0.7 x 6mm Boxwood strip to check the lie of the strake across the Frames. I am taking this very slowly, a lot of the fairing I do is along the vertical line to clean the char to avoid putting lateral pressure on the frames. This also has the effect of easing the friction when applying the necessary lateral strokes to fair the forward and aft frames. I didn’t do too much fairing at one time lest my natural inclination to complete the job got too much and the speed of working picked up. 0930 With the test strake fully sitting across all frames at various points I decided it was time to move on. A coat of wipe-on-poly is applied. 0942 0943(2) 0939 0953(2) The planking phase beckons. B.E. 09/03/21
  3. Thanks for that Chuck, what a beautiful model, is that one made of Cherry? I will be well pleased if mine turns out any where near looking like that. B.E.
  4. Hi Tim, The kit plan lengths tend to represent the full length taking into consideration the below decks element. The Bowsprit does have a taper, in my case I followed Steel - Taking a 20” heel (8mm ø ) 1st Qtr = 19¼” (7.86mm) 2nd Qtr 18¼ (7.33mm) 3rd Qtr 16” (6.4mm) End 11½”(4.5mm) The kit arrangement does have some simplifications, the jib boom inner end should be octagonal, I used 4mm square stock, and there should be sheaves set into the boom at the inner and outer ends and a hole at the inner end to facilitate the heel lashing. In practise Bowsprit caps were slightly wider on the starboard side of the mortise for the bowsprit and hole for the Jib boom, to allow for the Jack staff. Having said all this the proportions of your arrangement look good to my eye. B.E.
  5. Nice progress Jean-Paul, if Cheerful turns out as did your Royal Barge build, she will be a beauty. I too dabbled with a ‘below decks’ element on Cheerful, but perhaps not to the degree you are doing. I am a serial ‘basher’ but in the case of Cheerful that was the only modification I made. I do like a view below decks and with the likes of Skylights and companions I think it gives a more realistic impression of space that should be there. I also open up beneath gratings which I usually have as removeable items. In practice all that can be seen thro’ the Skylight is the painted sailcloth flooring and a little section of panelling, but I know it’s there. Regards, B.E.
  6. Thank you Terry I didn’t record the dimensions, but they are not difficult to work out. The width of the stove is governed by the space between the standards of the Riding Bitts, the height by the beam of the Fore deck which on my model I recessed to take the chimney. The length of the stove can be gauged near enough from the photos. I think others have also included a stove in their builds and those logs may contain dimensions if you’re lucky. Good luck with your build. Regards, B.E.
  7. Thanks for your input Guys. Thanks for the advice Chuck. @ Glenn – you’ve got to be working on the kit to appreciate the problem, but I doubt you will have any issues once you get around to it. @ Bradley – useful insight, and yours turned out beautifully. @ Derek - It’s always worth having one of Chuck’s kits on hand, in fact I’ve also got the Longboat kit beneath the bench. There are so many exiting new projects coming along now from Syren and Vanguard, - too many models not enough time – surely does resonate. Post Four Completion of Keel/frames assembly I did a little more work on the slots and tabs to give the lateral movement necessary to align the frames. I concentrated on the underside and didn’t touch the upper edge. I also took Chuck’s advice and made a pass of the sanding stick across the tabs. 0862(2) The keel then fitted much better and I felt confident enough to apply the glue. 0924(2) The forward section went somewhat easier, but I still managed to break the tab on the single frame H, temporarily secured with Tamiya tape. 0918(2) 0923(2) 0915(2) 9012(2) 0914(2) 0913(2) Moving on to fairing. B.E. 06/03/21
  8. Post Three Bringing together keel and frames. The futtocks are sufficiently firm in the base board, and the frames sit cleanly in the keel slots, so I can move onto the next stage. 0838 Support blocks added to the board underside. The prime concern now is to ensure that the frames are properly centred in the build board, the keel is vertical and centred along the frames, and the final fixing and tweaking is achieved before the glue starts to set. Chuck mentions in the blurb that there is a little wriggle room in the slots of the build board so the frames can be shifted left or right. 0839 This does not seem to be the case with my kit, there is no leeway to tweak the Futtocks in aligning the keel along the top. With the Futtocks fixed I am limited to ensuring that the keel is vertical across the top. 0843(2) Sighting along the set up the keel does not sit naturally centred across all Frames. Warp in the keel is not the issue. 0850 The mismatch in aftermost frame 10 is clear to see here. 0851 If Frame 10 is centred it throws several of the others out. 0854 I am reluctant to introduce ‘wriggle room’ into the building board slots but I do need to resolve this issue before I can move on. B.E Postscript Having disassembled everything again I think I have found the issue. The tabs in the board feel ok for removal but from beneath there is no ‘wriggle’ gap apparent. From the top laying the Futtocks on the board there is a gap of around 1mm. The board slot cut must have a slight inward angle to it top to bottom which prevents the futtock tabs from moving. I will take a shave off with a micro chisel and try again. B.E.
  9. Thank you Jean-Paul, your own build is one of my go to reference works. Chuck surely does produce fine kits, my Cheerful model remains one of my favourites, and the one that has given me the most satisfaction. Regards, B.E.
  10. Thank you, Jason, I found your insights and tribulations regarding the frames of great assistance, and also a little worrying, good that you are returning to the build. Post Two Prepping the frames. With the keel section completed a simple jig/building board is made to hold the keel straight and prevent warping whilst I attend to the Futtocks and frames. 0759 A slow process but valuable in the sense that it lowers the natural build pace. This is not a project to rush, deliberate movements and soft hands are I suspect essential to avoiding mishaps on this build. 0765 I started with the fore half and found that futtocks J – F required tape over the tabs to give a good fit, and Futtocks E -B required the building board slots easing for a good push fit. The final two Futtocks ‘A’ fitted without attention. One slight hitch, I mistakenly glued a Frame O to Futtock A because the incised reference letter was closer to the O than the A frames on the fret. There are two Frames A and O. My error was quickly rectified but I note it as something to watch out for. 0767 The aft half of the Futtock/ frames generally fitted without attention, only a couple required slot sanding and the application of tape. 0819 Before going further I test checked each of the frame bottoms into the keel slots, most needed a pass with the sanding stick to fit in the slots. I hesitated about what to do with the keel slot for Futtock 7. This was narrower because the long central keel slot section was slightly reduced to fit on the keel. I settled on a combination of shaving a fraction off the forward edge of the slot and reducing the frame bottom. I didn’t want to thin the frame bottom too much lest it weakened the structure. 0832(2) 0825 Having checked both slots and tabs the parts will now be taken apart and the building board support blocks added to the underside. B.E. 04/03/21
  11. Wow Glenn a lot of progress since I last looked in, very nice iron work, and Cheerful is looking splendid. Your post on making the boom crutches brought back memories of much fiddling time getting those angles right, happy days. 🙄 B.E.
  12. Post One This involves the keel assembly and I was happy to follow the leads of JpR62 (Jean-Paul) and Chuck Seiler, by using scrap 1/32” sheet to assist the alignment of the inner keel pieces. 0681(2) 0697(2) I utilised the fret cut out to hold the bow section during keel gluing and the inner keel sections. 0690(2) The stern section is likewise fitted in a jig for gluing. I also agree with Chuck Seiler’s approach of assembling the keel pieces as two separate sections and bringing them together only after tapering and the addition of the inner bow and stern keel pieces. 0703(2) This is a long keel secured initially only by the central scarph and I share his concerns about the risk of breakage. 0709 Gluing the bow inner keel piece. 0713 …and the inner stern keel piece. The stem, keel, and Sternpost require tapering. The pieces are 4mm thick and will initially be reduced to 2.5mm. Final finish 2.38mm or thereabouts. The taper runs down the stem, starting 18mm down from the head, and from inboard to outboard. The taper continues along the keel from top to bottom and is also applied to the lower sternpost. To this end I have pva’d a styrene strip 0.25mm x 2.5mm along the parts to be tapered to give me a guide to the thin end point. With the two sections joined the centre inner keel piece can be fitted which adds security to the structure. 0721 Initially I used pieces of scrap 1/32” sheet to centre the piece along the keel, but this didn’t give a good result; something must have been off, probably me, so I resorted to placement by eye which worked better. Chuck mentions that the piece was made long on purpose and that sanding the after end may be required. In my case it did, reducing the keel slot size, the implications of which I have yet to find out. The final tweaking of the tapering is now done making sure the inboard edges of the keel remain untouched so as not to affect the rabbet. The final task of this part is to attach the transom piece. Chuck makes the point about ensuring the transom is perpendicular to the keel. 0735 There are etched lines to assist centring the transom, but I then used my eye and diverse methods to try and check that the piece was vertical to the sternpost. 0746 One of the diverse methods I used to check the transom was level. 0741 Not quite as simple as may seem given the inbuilt flexibility due to the length and relative thinness of the structure. 0756 A coat of w-o-p and I can move onto the next part. B.E. 01/03/21
  13. Neat work on the yokes, the swivels look good. I'm a big fan of RB guns, nicely proportioned and economically priced. Well done Tim. B.E.
  14. Satin was what was available but any spirit based polyurethane would probably do, matt or satin. The pot is my diluted wipe-on, it drips readily off the stirrer but does tend to thicken over time requiring addition of further white spirit. If there is plenty of space I wipe it on, but for small areas I use a brush but well layed off. I would use any white spirit available in local stores, in fact I’ve used the make you show, but don’t use turpentine. B.E.
  15. Minwax is seriously overpriced in the UK at least. I simply make my own using Blackfriar clear polyurethane varnish (not the nasty water-based versions) diluted with White Spirit to around 50% Used it on my Cheerful Boxwood build and recent Vanguard Fifie and Zulu builds, suits me Sir. 👍 B.E.
  16. Cheers Guys, @ Michael - you're so right, open the box and everything exudes quality, as did Cheerful. @ Chuck - this is such an impressive looking subject, thank you for making it possible. if my Cheerful experience is anything to go by my cup will runneth over. 🙂 @ Glenn - as I will following on from those who have gone before, I've already picked up some useful pointers. This log will probably turn into a 'like he did' build. 😄 B.E.
  17. Hi Dave, I suspect that Amati have provided 1mm ø line for the Fore and Main shrouds which is not that far out at 1:60 scale. Bounty had 7” circ shrouds (4½” for the Mizen) 7” circumference equates to 0.94mm ø at scale. Kits mostly have a too limited number of line sizes which reduces your options, but my best guess would be to use the smallest of your lines for serving. At model scale the idea is to get the effect without too much bulk. Here’s a photo of the Fore shrouds of Victory I took some years ago. These lines are probably synthetic and slightly smaller than the equivalent hemp versions of the day, but give you the idea. Note the relative sizes of the foremost served shroud and the others. Note also how the serving goes all the way around the deadeye, another point to consider in relation to the model scale line. B.E.
  18. Hi Mario, you can't do better than the Edgar March book when it comes to Sailing Drifters. As far as the sails arrangement is concerned, if the sails are down so are the yards, there are some old photos in the March book. This is the Reaper with the Fore lug yet to be raised. This is an old shot of a Fifie and a Zulu leaving port. Cheers, B.E.
  19. Queen Anne Royal Barge circa 1700 –1:24 scale. This build has been waiting in the wings for three years, long overdue to get stuck into Chuck’s wonderful creation of this early18thc Royal Barge. I can only hope that I do justice to this high-end kit as indicated above. I am fortunate that there are around a dozen recorded builds on MSW at various stages. Half of them are completed, so I will have the benefit of a wealth of experience from those who have gone before. My first step will be to read through Chuck’s comprehensive build manual and the logs of my fellow members to get a feel for the build. B.E. 24/02/2021
  20. I was hoping you would post a photo of your new assistant, he looks a fine little chap - hi Winkie. has he met the neighbours yet - those large furry brown ones. I think you would find the Proxxon mill ideal for model making, I don't use mine a lot but it comes in for slotting and profiling, and when you need it you need it. B.E.
  21. The Crowsfeet look good at this stage Derek, they really are tricky beasts to get the tension right without distorting the stays. Thinking back to my Pegasus build I think I resorted to stiffening them with diluted pva to stop them running off line. I still like them as a feature on models tho'. B.E.
  22. Yes Dave, just a simple knot to secure the ends, pulled tight, sealed with a spot of glue, and trimmed close. B.E.
  23. That looks a fine little model Bruce and makes my recent subjects look positively chunky by comparison. The fineness of those ribs is something to behold but will add authenticity that simply adding internal strips to represent them can’t truly replicate, but at 1:64 scale real ribs would be the ultimate nightmare. I look forward to your return to this build once you have garnered the necessary resolve. Regards, B.E.
