Posts posted by jwvolz
Just caught up on the log. That finished up very nicely. Excellent work!
- GrandpaPhil, Paul Le Wol, catopower and 1 other
4
Great work so far, especially all the metal work. I like what you did with the siene boat and the dory as well.
Mine is long finished but I never did complete my log, including finished pictures. maybe you've inspired me to do so...
That's fantastic Richard.
- Retired guy and FriedClams
1
1
On 1/29/2022 at 1:14 PM, BobG said:
I just read over your build log again, Joe. Gorgeous, meticulous work! Any further progress on this wonderful model?
Thanks Bob. She's actually finished, and has been for a couple of months. I just need to get this log caught up.
- BobG and Landlubber Mike
2
On 1/29/2022 at 2:42 AM, Retired guy said:
Brilliant rigging Joe do like your baggywrinkle do have a few to make for the Bluenose, do you have a drawing how you made them.
Did you use the rope from the kit or did you buy or did you make your own.
Regards
Richard
Richard,
Thanks.
The rope is Syren. For the baggywrinkle I simply placed the appropriate length of rope in my serving machine, and then attached the piece of the peacock hearl with fine thread. I then wrapped it around the rope for the distance necessary and seized it off on that end again with fine thread. Final step was to paint with diluted tan acrylic paint. It's actually incredibly simple.
- BobG, Landlubber Mike and Elia
3
Welcome Doug from a fellow Pennsylvanian!
- mtaylor, Keith Black, Robp1025 and 1 other
4
11 hours ago, jlefever said:
Looking really sharp. Nice paint work and the blocks and baggywrinkle work very well.
You're on your way to a real beauty.
Jim
Thank you Jim.
Thanks Mike! Wish those pics were better...
- Landlubber Mike and Yorky
2
Well, bit of a long overdue update.
I've been super busy at work, spending time outside over the summer, then I had Covid. So even though I've worked on the model a fair amount I haven't posted anything in quite awhile. Here we go.
I've completed nearly all of the rigging on the Latham. One thing I wanted to touch on first was the baggywrinkle. I puzzled long and hard over how to make this neatly and in scale. I am a fly fisherman/fly tier and it eventually hit me to use peacock herl, which is used for certain fly bodies. I used my serving machine to wrap it around the rigging line, and then subsequently painted with tan paint. Really happy with the way it came out. I'll have more updates over the coming days.
Thanks Richard. Getting close...
Just spent some time pursuing your log, what a fantastic build Mike. I love the final presentation. Fantastic!
Good to hear Mike. It does look good.
The difference could lie in that I used copper tape vs. the plates. Mine therefore had a bit of stretch/flexibility that the plates don't have.
Good start Mike.
When I did Cruizer (same hull) I did one belt and then a one row belt at the waterline. It worked out well with no issues, looks good and would certainly be easier. That drawing is a two-decker so deeper hull, which would likely have a different run than a brig.
There are some pictures in my build log.
6 hours ago, Wintergreen said:
Crisp and clean, so nice!
But how did you persuade the anchor cable to lay so naturally? It really looks, uhm, real.
Good question actually as it did take some effort. Each loop is individually glued down with white glue and then a weight was put on until dry. I repeated with each subsequent layer. Wouldn't stay put otherwise and gave much better control of the lay.
Thanks to everyone else as well, and the "likes".
- Wintergreen and Yorky
2
I have completed the ratlines on both masts, which really wasn't too bad with the limited number of shrouds. Lantern boards were built and painted and secured with thin brass brackets seized to the shrouds per the plans. I also soldered up the topmast spreaders from brass wire and seized those to the shrouds as well, to keep the stay clear of the lantern boards.
I didn't really document the booms being fabricated and assembled/painted, but their installation has begun. The hardware was made from various brass strips and wire. Their rigging has also begun with sheets and topping lifts run. I am using Bluejacket blocks, as Latham had internally stropped blocks, and Syren line for the running rigging.
3D Naval Guns 1850s ~ 1870s
in CAD and 3D Modelling/Drafting Plans with Software
Great thread and excellent research and work Jerry!
I sent you a message about the Harriet Lane guns.
