Everything posted by Landlubber Mike
Looks really nice from here Gary, don’t be too hard on yourself! It’s very nicely done! Are you planning to paint or stain the hull below the wales? At first I thought you painted it white to simulate the white stuff, but I’m guessing it’s the natural basswood? Whatever it is, it’s a nice contrast to the other colors of the hull.
Thanks very much Hubac and Russ. Glad to get confirmation from others! Chris, I think that might be on the cards. I need to start practicing though. It’s actually a more complicated figurehead in that the Zeus figure is fronted by an eagle with an outstretched wing, that I think Zeus is holding onto. Might be a little tricky but possibly not too bad with the cast figurehead as a model.
Looks great Russ. White paint can be tricky, if not unforgiving when it comes to showing mistakes. Your build and paint job look fantastic!
- 420 replies
- captain roy
- lugger
Love the blue and the carvings. Very nice job!
- 961 replies
Joe I’m down in FL at Disney with the family. Nice break from the cold we’ve been having in our area!
- 682 replies
- halifax
- lumberyard
Aren’t there parts that are 1.5 and 2mm ply? My Caldercraft Badger kit had similar ply that chipped if you looked at it.
- 110 replies
Bob, happy New year to you. Just caught up on your log and wasn’t surprised to see your usual high level of craftsmanship. Nice job!
- 682 replies
- halifax
- lumberyard
The ply was really crumbly for me too. At least the deck ply will be covered - I believe that some of the thin laser cut sheets are made of similar crap 👎. Not a big deal as I’m scratching those parts, but just forewarning that these are delicate and you might need paint and filler.
- 110 replies
I didn’t want to find out. I suppose if you’re very careful everything out be fine but I preferred having more stability. It was pretty easy to do, so why not.
- 110 replies
Very nice Don! They are going to be a really nice touch.
- 223 replies
Take a look at my Pegasus log. I added additional support for the deck along the centerline to be on the safe side. The bulkheads don't adequately support the deck.
- 110 replies
The veneer saw is a great tool. I bought one to saw the bulkhead extensions after BE’s recommendation. Not a necessity, but makes things very easy!
- 223 replies
Don, let me add my admiration to the others. Really nice job! I’m not aware of other kits that take this temporary approach, but makes a lot of sense to me. Another creative feature of these MarisStella kits.
- 223 replies
I believe I did get smaller cannons for the swivel guns. Don’t remember if they were RB of not. I believe they were. I also have some Caldercraft ones that could work. For hull planking, the planking runs were certainly made up of multiple planks. TFFM (I believe volume 2) has a sample hull planking diagram. Shorter planks, especially if you spile them, will be less prone to clinking.
- 110 replies
Figurehead In my hull prep work, I cut out a portion of the first bulkhead and a bit of the false keel and filler blocks on either side to help seat the bowsprit. I figure that rather than having the bowsprit sit on the gun deck, it would be a little more secure if it went through the gun deck and then the gun deck and planking could serve as a sort of anchor just like mast slot blocking on for the masts. In doing so, I decided to test fit the figurehead and discovered a few problems. As you can see, the figurehead doesn't sit squarely on the stem. Even if I squared the figurehead's, uh, bottom, a bit (or filed down the stem) so that it would sit flush, the problem is that the figurehead still will sit too high on the stem for the bowsprit. In the second picture, you can see the problem, even with the figurehead sitting at the front edge of the bowsprit. I went back to the plans to see if perhaps the rake of the bowsprit as set by the false keel and stem (two parts of which matched perfectly) was off, but the rake was in the range of both the plans (oddly, plan 7 specifically says 29 degrees from the waterline when plan 17 shows 32 degrees) and Chapman's Architectura (which was about 31 degrees). The false keel is around 31 degrees, so the problem is not with the false keel. So given that the rake of the bowsprit as set by the false keel is correct, the figurehead needs to sit much lower, as the bowsprit should clear the top of the figurehead by around 6mm. As you can see in Chapman's Architectura, the figurehead pretty much sits way back on the stem against the curly piece of the stem, and the line of the curly piece to the top of the figurehead is roughly parallel to the line of the bowsprit. Interestingly, in the few pictures I've found of others working on the kit, it seems as if the builders chose to increase the rake of the bowsprit to accommodate the figurehead. I think I'm going to stick with the current rake, and instead figure out what to do with the figurehead itself and the stem. For this stage of the build, I just needed to ensure that the rake of the bowsprit and seating was set up correctly, so I don't have to make any decisions at this point. My guess is that I will at some point have to lower the seat on the stem. It might come down to carving a new figurehead too if I can't modify the kit figurehead to sit squarely on the stem.
I made some good progress over the last week or so. Nothing particularly interesting, but I've installed all bulkheads except for the last, added blocking for the masts, and added some filler blocks at the stem. I also epoxied in some nuts into the keel to take the screws for the pedestals when I finish this build in 10 years I forgot how long all this prep work takes! So far so good. I did have to open up the slots in the deck pieces a bit to accommodate the bulkhead tops. When I had dry fitted the bulkheads and decks as a test early on, everything seemed to fit ok. I think after squaring up the bulkheads, adding the stem and keel, etc., that things shifted a bit and so the deck slots needed slight adjustments. Things probably fit on the dry fitting because there was a little flex with the parts. When glued however, particularly with the bracers in between the bulkheads, things were locked in. Some people have seen issues with the slots not lining up with the plans, and in some cases, being misaligned between the starboard and port sides. Others have thought that some of the bulkheads were not properly shaped. I also had a very slight wave in the keel around bulkheads 8-10 which probably didn't help (part of the reason I wanted to install the stem and keel at this stage). The upper part of the false keel around affected bulkheads leans about 1mm over to the port side. I think this should be fine because at the stem and stern, and along the bottom of the keel, the keel is perfectly straight. I'll just need to be mindful when fairing and planking the hull in that section.
For the TFFM books, depending on how much you want to kit bash the hull, volume 2 will help a lot. Volume 1 has good tips and some information, but I think you could get by without it. Volume 4 is really, really great for rigging and sails - I used it for my Badger build. It consolidates a lot of information from Lees and other primary sources on rigging and masting. Volume 3 is nice too if you'd like to see the steps of a scratch built Pegasus hull come together. For the NMM plans, I have to say that at least with respect to the Pegasus, the kit plans and decorative elements are pretty much dead on. There is a very slight modification when it comes to the some of the aft-most bitts and hatches. On the NMM plans, one or two hatches are in a slightly different location, with one of the bitts going through one of the hatches. Also, the cross bar on one of the bitts is facing aft on the NMM plans, while the kit has all cross bars facing the stem. The NMM plans also show a more decorative figurehead than the kit one (which is still nice), though I understand that sometimes the plans were more aspirational than what ultimately went on the ship. These are very minor deviations from the NMM plans, and my sense is that in cases like the hatches/bitts, these differences were made to simplify things a little for the builder. If you look at my Pegasus log you can see how I handled the hatches/bitts. It's been a while since I looked at the Fly plans, but from what I remember, they were really nice, and very detailed when it comes to the decorative elements on the stern, quarter galleries, and maybe even include the decorative friezes. I think they were spot on with the kit, whereas the Pegasus differed slightly with respect to some elements of the stern decorations. One other thing I should mention - the cannons seem to be a bit oversized, at least that is what Pegasus and Fly builders have found in the kits we got (maybe newer kits addressed the issue). I ended up buying RB Model cannons, and others have bought Syren model's cannons. To sum it up, the Pegasus kit was really well done and pretty much spot on when it came to matching up with the NMM plans. I think the Fly is the same way, and I would say that you can build a very accurate model of the ships straight from the box and don't need TFFM or the NMM plans. I bought them as for me, I really enjoy the learning that goes along with building.
- 110 replies
Miniature Russian carving tools
Landlubber Mike replied to druxey's topic in Modeling tools and Workshop Equipment
Thank you Joe! -
Nice kit - I’m working on the Pegasus and think Amati did a really nice job with them. Cant help you with the Fly drawings. Maybe Martin or some other Fly builders can be a more help? The TFFM books (and maybe Admiraltymodels.com) have s list of the plan identifiers for each Swan Class ship. Maybe try there? Good luck with the build!
- 110 replies
Can someone PM me his email address? I’d love to get a set as I’d like to start carving. Just out of curiousity, any recommendations on which kind of handles to get? I assume the palm handle ones are better if you don’t have enough hand strength? I would think I would have an easier time with the ones that are more pencil like in shape, but I’ve never worked with the other type except in the case of a ball handle pin vise. Thanks! -
Marc, just spent time going through your log. Wow, so much work and research! Very informative and your attention to detail is really impressive. You should consider writing a book given all that you have compiled. 👍
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Really nice work Ferit, glad to see you back. Sorry about the shrouds - at least they can be re-done!
They look really nice - I like the weathered look too. Kit seems to have very nice materials 👍
- 223 replies
Jet or Dewalt scroll saw
Landlubber Mike replied to Anguirel's topic in Modeling tools and Workshop Equipment
I have the Dewalt and love it. One tip is to look at Craigslist (how I found mine). Many barely used scroll saws on there because dad’s and others use it once or twice for school projects for kids, then never use them again.
