Landlubber Mike
Everything posted by Landlubber Mike
  1. Hope everyone is enjoying 2020. With the holidays, work, and a diversion into plastic models, I haven't been devoting as much time recently to the LAR. I did manage to line out the gunports on the gun deck level. All I can say is this took forever! The gunport patterns on other European kits like Caldercraft and Amati are a godsend. Given that there are 14 gunports per side, I thought it was important that there be smooth line to the ports, that they be square, and that they be even with each other. Hopefully the pictures below show clearly my particular method. Essentially, I spent many hours marking out the 10mmx10mm gunports by transferring measurements from the plans, drilled a 2mm hole in the center, and ran a brass rod through to make sure that the gunports on either side were square to each other and level with one another. Then after cutting out the 10mmx10mm gunports, I ran a square 10mmx10mm through to make sure that everything was still lined up. Since I'm lining the ports, i went ahead with adding 2mmx2mm sills, opening the gunports to 14mmx14mm. This was fairly easy using a micromotor with a small cut off wheel. The cut off wheel made for quick, straight work. The sills ultimately will be about 1mm, so I have an extra 1mm to overlap them with the second outer hull planking. I'm using padouk that I picked up from Woodcraft. It's an interesting wood - nice color (though will dull to an orange-brown over time, interesting smell when worked, and machines fairly easily. It does have pits in it like mahogany, but these fill up pretty nicely when sanded. Hopefully when I apply a finish there will be no visible pits. You have to be careful with the dust as it can be an irritant, so I worked using a respirator and a shop vac going at all times. It also can stain very light wood, so you have to be a little careful with that as well. To get ready for the inner bulwark planking, I decided to remove most of the gunport-level bulkhead frames. That was not at all easy but took lots of micromotor work. I was a bit nervous doing so, but I had rubbed PVA all over the first planking which kept the planking very stable. Next up will either be the inner bulwark planking or the exterior planking. Given that the interior bulwark planking will largely be invisible, I might start with it, so that when I do the outer hull planking, clamping and pinning issues might be easier to deal with.
  2. Hmm, I have the Borodino in my stash. After seeing your build, I'll either be inspired to do it, or dissuaded from starting it and will end up selling it
  3. Hey Martin, happy new year to you! Nice job on the figurehead! Looks great 👍. I’m thinking of carving the Pegasus on my Swan class eventually - hopefully a lot easier than carving a person.
  4. I use the disc sander all the time. Probably my most used tool. Super easy and quick way to get straight edges. I was on the fence about the thickness sander but when you need it, it’s incredibly helpful. I’ve used it a lot more recently.
  5. I keep losing my 6” rule. Bought three and just lost my flexible one again 👎
  6. Lighting, dust collection, and space for accumulation of tools, kits, etc. are important, especially if you’re going to be making your own parts. First I started on my kitchen table and ottoman. With all the tools, etc. I’ve gotten, I nowhave a more dedicated space with better lighting, dust collection, a work table, etc. One tip - if you’re going to buy power tools, make sure you know the feed/exit run space you will need. Some tools like the table saw and thickness sander can’t be put against a wall.
  7. Nice Kevin! Really came out well. I'm working on a couple of 1/72 biplanes myself, very hard at this scale so I appreciate the efforts!
  8. Very nice job! I love these Chris Crafts - saw a complete one at a show recently and they make beautiful models. The mahogany planking with a glossy finish with chrome accents is a really nice look.
  9. Looking great! You've already passed me on my build. How are you finding the deck planking going? I am at about that stage on my build. Was thinking about putting a sub floor piece in to make the planking a little more even and possibly with better support. Either way, it looks like one needs to consider building in some underlying framing to support the hatches, etc.
  10. At 1/32, that's going to be a good sized model. Looking forward to following along! Mrs. Runyon is quite perky
  11. Looks great! The bulwarks are not easy when you have to individually set up all the stanchions.
  12. What did you end up getting? 🤔
  13. I have the Ancre monograph and was thinking of building this ship sometime down the road. Your work is so perfect though, I don’t think I’ll be able to. You have set the bar to an unreachable level for us mere modeling mortals.
  14. That’s a really good deal. These books are an amazing resource on how-to’s even if you aren’t building a Swan class. I’d jump all over this if I didn’t already have the set.
  15. Mark, awesome work. Amazing how perfect you were able to get those gunport strips to line up!
  16. Very nicely done Joe. I had to do those on the Morgan, and they weren't as complicated as what you had to deal with but still took a lot of time. Coming along really nicely!
  17. Have you tried using a steady or follower rest? I think those items help with some of the flexing issues. Given that folks are building billiard cue sticks using the Sherline lathe, I would think that flex can be minimized.
