Everything posted by Landlubber Mike
Looking great! You've already passed me on my build. How are you finding the deck planking going? I am at about that stage on my build. Was thinking about putting a sub floor piece in to make the planking a little more even and possibly with better support. Either way, it looks like one needs to consider building in some underlying framing to support the hatches, etc.
- 294 replies
- charles w morgan
- model shipways
B-25 Mitchell "Meet Miss Runyon" by Javlin-HK-1/32
Landlubber Mike replied to Javlin's topic in Non-ship/categorised builds
At 1/32, that's going to be a good sized model. Looking forward to following along! Mrs. Runyon is quite perky -
Looks great! The bulwarks are not easy when you have to individually set up all the stanchions.
- 294 replies
- charles w morgan
- model shipways
Gift for 50th B Day
Landlubber Mike replied to ChrisLBren's topic in Modeling tools and Workshop Equipment
What did you end up getting? 🤔 -
I have the Ancre monograph and was thinking of building this ship sometime down the road. Your work is so perfect though, I don’t think I’ll be able to. You have set the bar to an unreachable level for us mere modeling mortals.
- 589 replies
- le gros ventre
- cargo
Very nicely done Joe. I had to do those on the Morgan, and they weren't as complicated as what you had to deal with but still took a lot of time. Coming along really nicely!
- 140 replies
- benjamin w latham
- model shipways
Hi Chris, I’ve only put together masts and yards for my Badger build, and haven’t yet for the Pegasus, etc. For the Badger, the instruction manual had you prepare things in pieces. For example, the yards were in three sections, with the round tapered ends pinned to the octagonal middle section. That generally worked fine, but I distinctly recall having issues with a couple of them flexing at the joint particularly when rigging was applied. That was frustrating. For my next builds, to avoid that flexing issue, I’m going to try building them in a single piece on the lathe using square stock. Turn the rounded ends then part off. Just have to take careful measurements.
That framing is incredible. Really nice job with this. I'd venture to say that this must be the most researched model on this site (or in the top five at least). You should release your own kit!
- 2,699 replies
- heller
- soleil royal
(and 9 more)
I’d echo what Jhearl said and say if you are going to go with Sherline, think about the higher column and wider table for more flexibility. When I was looking a while back, it was recommended that I didn’t need the top of the line 3-axis model for ship model purposes. Also check prices on Sherline’s monthly sales and discount campus. Sherline is great with all the accessories that are available, many of which can be used with their lathe. Honestly I haven’t used the mill yet much for model work, but in part it’s because I was less clear about it’s functionality aside from drill press operations. I’ve used the lathe a ton for pen turning this past year and am a lot more proficient with it, which I think can carry forward to the mill. For those looking at the lathe, I would think about moving up to the 17” bed if you have space. The 8” bed quickly gets used up if you are going to start adding drill chucks, etc. For model work 8” is probably sufficient, but if you are planning on other turning projects, for $100 more I would jump to the larger size. I had a very hard time turning pen blanks on my 8”, so ended up selling it and buying a 17”. Now that I’m somewhat proficient with the lathe, I am planning to do masts and spars on it. Sherline recently introduced a live center for ship model work that has a cup at the end, rather than the typical 60 degree point. I haven’t tried it yet but it looks promising.
Magnifying headset advice....
Landlubber Mike replied to CPDDET's topic in Modeling tools and Workshop Equipment
I purchased the optivisor and got the LED light set for it. Makes working with tiny parts much easier. I ended up actually getting two sets with different magnification levels rather than have to switch out lenses. -
Nice work Elijah! Beautiful work indeed. If you don’t mind me asking, what line are you using? It looks very nice even in the macro photos.
- 228 replies
- gunboat
- model shipways
Just echoing what David said, I would sand it flat and then add the plankshear extension to the hull as a separate piece. Otherwise I think it will be next to impossible to maintain a consistent extension along the hull.
- 294 replies
- charles w morgan
- model shipways
This was the first model I built (you can see my log linked below). I highly recommend it - very well done, great instruction manual, great Caldercraft quality, etc. The only quibble I had is that some of the thin walnut sheets were kinda crumbly in places, maybe that's been fixed, but nothing that filler and paint can't fix. When I was looking at possible first models, I wanted to build something interesting that was more complicated than a weekend-type model, yet not too complicated. The Badger and the Armed Virginia Sloop were great candidates at the time. There are a lot of new kits on the market with improved instructions, building methods, etc., so hopefully folks with knowledge of them can send you additional recommendations. Other than that, if you buy the kit, I would consider building in a different order. For me, I think adding the cannons so early on ended up causing me a lot of grief because I kept busting them off when trying to add the rails and other external hull details. That could just be my building style as I typically build in my lap more than I should.
