Landlubber Mike
Everything posted by Landlubber Mike
  1. Looking awesome Tom. You picked a pretty sweet kit to get into airbrushing and PE I was too chicken and went with tiny WWI 1/72 kits 😐
  2. Wow fantastic build! You work quick! If and when I ever get to mine, I'm sure it will take me a a year to complete - with results likely no where close to yours!
  3. Very nicely done Mark! Can I ask on the application of the plates - how to you apply the glue so that it doesn't squeeze out from underneath when the plate is attached? Seems like a tricky exercise of putting enough glue that the ends of the plate are secured, but not too much that excess squeezes out. You've certainly mastered it!
  4. I do as well - pain to try to sand it so I wipe up as much as possible. It's taught me to be a little more careful with how much glue I add.
  5. Wow nice kit!! 1/12 scale will allow you to add lots of details!
  6. Well he only has another 249 to choose amongst? 🤔
  7. Awesome diorama!! Well done! I told myself I can't start looking at armor kits. First it was plastic ships - that led to plastic plane kits - which then led to plastic car kits on the shelf. Must look away now...
  8. I should have mentioned that I've painted Vallejo acrylics on top of the Mr. Color lacquer primer and Tamiya lacquer paints no problems. Only problem I've had is when I used that Polycarbonate paint on top of acrylics - that caused the acrylic to turn runny. One thing to note too is that there are varying opinions on how long to let something dry and especially cure before adding a different layer on top. Most seem to suggest waiting at least overnight, if not 24 hours, to be on the safer side.
  9. Yes, that's the version I have. Somehow lucked into it on eBay when a seller decided to discount it by 60%. The scale looks perfect for adding lots of cool details.
  10. OC, I have to say when I saw the email showing build log updates I follow and saw your posts from yesterday, my heart sank! Glad that you were able to recover though! It's looking like you just took a time machine a few days and are back to where you were. To replace your decals, I bet contacting Revell is a good place to start. Your build log is fantastic and is good free advertising for them. If they aren't able to help, then I bet you can pick up third party decals for the kit. Some you can find here: https://www.scalemates.com/kits/revell-04555-mosquito-b-mkiv--111441 Or, I'm sure you know this, but they sell paint masks that will allow you to paint the markings, rather than use decals. That could be an option? https://www.scalemates.com/kits/montex-mm48306-dh-98-mosquito-b-mkiv--198970 So, I'm by no means an expert on this, but I'm guessing that Egilman is correct on what happened with the hair dryer and curing. As a side hobby I sometimes turn pens, and typically add a CA finish when I use wooden blanks. Sometimes I will get a crazing like that. I've found that happens when I try using an older bottle of CA, but along with humidity, I've had issues pop up with some blanks when I used accelerator (either too much, too late after the CA was applied - i.e., there is a problem with the curing). CA is certainly different than applying a clear coat, but when I saw your pictures, I immediately thought of the same issues I had with adding CA finishes. I hate to dredge up bad memories, but can you spell out the steps you used? It sounds like you applied Tamiya rattle can lacquer primers and paints. Did you seal right after painting? Then you applied the decals with setting solution (microset?), and then tried to gloss coat with a Tamiya lacquer by hand? The reason I ask is that I'm working on two 1/72 planes at the moment. The steps I took were (1) Mr. Color primer (lacquer), (2) for paints, I used mostly Vallejo (acrylic), though I used a Tamiya lacquer spray can for some parts (I made a big mistake in buying the Polycarbonate PS line which is for RC models that use polycarbonate), (3) added a clear coat of Future to seal the paint, (4) added decals using Microset and Microsol, and (5) sealed the decals with another coat of Future so I can begin weathering (I'm going to play with washes, powders, and oil paints I think). Everything has worked pretty well for me. The only issue I had is when I accidentally got a bit of acrylic paint on the section I painted with the Polycarbonate paint. When I went to touch up that area by hand brushing the Polycarbonate paint to cover the acrylic, it ended up turning the acrylic wet and sorta mixed with it so I had to wipe it and now have some small smears (I guess an early start to the weathering process for me). Not sure if the PS paints are lacquer, but I now know that I can't use that PS paint on top of acrylic. Anyway, just thought I'd share as I've read different views on what paints can be used with other paints and when. It's all been very confusing to say the least. I very much prefer the ease of using Vallejo acrylics, but Tamiya's lacquer colors just seem a lot more lively and better for certain types of models. All that being said, hang in there man - you took a step or two back and learned something, but all is not lost. Your Mosquito looks fantastic!
  11. Bob, sorry for the setback but even boxing the base you're going to have one of the nicest models I've seen on here. Really amazing work!
  12. Fantastic Kevin!! What's next on the list
  13. I'm really excited to watch this - I have it in the stash. From what I've seen, it is an incredible kit. Good luck! The black version is really sweet - there is a work in progress on Model Cars Magazine forums by Maysula in case you're interested.
  14. Well done! Gorgeous model! That white top looks perfect - color and texture. Can I ask how you did it?
  15. And OC, I should have mentioned that your build is looking really sweet. That paint scheme is really sharp.
  16. Kevin, just to clarify, is the issue that the decals OC used were flat and not glossy, and therefore one would seal the paint with a flat clear coat before applying the decals? And once the decals are applied, even if flat, can one add a gloss coat to seal the decals and begin weathering? This is the first time I’ve come across that there are flat decals out there and am trying to learn what to look out for
  17. I've had the Dewalt scroll saw for years, and it's served me well. A friend gave me a band saw when he upgraded, and after a year or using it, would say that you probably will get more functionality from a band saw than a scroll saw. I'm not an expert by any means, but for me thus far, I've gotten a lot of band saw use that has mostly entailed cutting larger pieces of wood and other materials for other hobbies like pen turning. With a band saw, along with added power to cut thicker pieces of wood and other materials, you can add a fence to make straight cuts, add a miter gauge for angled cuts, and change the blades to a thinner blade if you are cutting curves. A scroll saw is much better for cutting curves and interior cutouts, albeit on thinner material. So I would say think about what applications you would need the saw for and choose accordingly. Of course, if you have the room and budget, get both One tip - look on places like Craigslist for lightly used scroll saws. Lots of people post scroll saws and other tools that they used once for a weekend or kid's project that are now collecting dust. I bought a very lightly used Dewalt off Craigslist for a fraction of the retail price (and it was an older model which doesn't have some of the quality control issues that people are finding with newer units).
  18. Nice work Joe. You're a master at modeling ships and now it clearly appears planes. Anything you can't do?
  19. The fenders on my Spider were cracked and I managed to get replacements from Paul. My RR body had a crack and a bit of a warp, so replaced that from Paul as well to be safe. He’s a fantastic resource! I’ll have to try those Vallejo Metal paints. I’ve been using the regular Vallejo model color and model air and really like them. The metal line seems to be even nicer. I figure I’ll give them a try when I have a larger section to paint in a metallic color. It took a little trial and error, but my airbrushing has improved. Using Mr. Color lacquer primers and Tamiya lacquer paints has been a bit of an adventure on my Iwata, but those paints lay down very nicely.
