clearway
Everything posted by clearway
  1. Wow the evenings are really closing in now- pitch black outside by 7pm today. Nice weather today but decided to have a rest from D.I.Y. work. I dug some brass strip out of my bits n pieces pile and made the rudder gudgeons- needed these done before more detail work was done to outside of hull. According to plans i bought from N.M.M. they should be 12mm apart (these are completely missing from occre plans/ fittings). Also made a start on the foremast with the masthead squared off and the bibs/ trestletrees added- again according to the plans the mast doubling should be around 30mm. Take care all Keith
  2. Thanks for looking in, bad weather again today so had some ship time- as a break from HMS Terror did a little work on Endurance with the lower masts /bowsprit cut to length and the access ladders for the bridge above "the ritz" built which will be painted before being fastened in place. I have also lowered the hatch cover on the ritz roof as it had too much wood tween the window and top. take care all Keith
  3. don't forget humbrol clearfix Kev which was originally designed to make the windows in model airliners. Keith
  4. looks good Hake- once painted will not be as in your face (if gluing/painting aluminium polish it and add paint and glue as soon as possible as it forms an oxidising layer very quickly which can affect the finish/ adherence). Keith
  5. well done Geo- i was wondering how you were getting along with her. Keith
  6. lets face it everyone on here is also unhinged when you see what we put ourselves through, Vincent would probably go through the build logs and think "these guys are nuts"😁, Build coming along great by the way Phil! Keith
  7. Thanks for looking in, likes and comments everyone. Wow talk about a split weekend weather wise.... yesterday outside in lovely warm sunshine doing D.I.Y. , today started off dull cold and grey then high winds and torrential rain (still lashing down now), though workshop time resulted🙂. On Terror we now have the sheets on the jib sail rigged though the tack still needs rigged, the small anchor each side of the stern are now mounted and before i install the bridge and azimuth compass and post i added some barrels alongside the bulwarks. Take care all Keith
  8. Hi David, somewhere back in the Ether on this section you will find billings victory builds by shihawk and myself as well (still to finish mine)! read the instructions several times then read again, yes lay the deck planks one by one as on most builds to be honest though Vicky is a mammoth task especially if no prior experience with wooden shipbuilding. Keith
  9. excellent work and the stand is unusual and interesting , well done , it can be interesting to take an old or basic kit and use it as a baseboard for weathering/ scratchbuilding techniques. I managed to resist temptation to buy this or the U9 kit and thought good boy,,,,, then seen hellers 1/100 Pourquois pas on ebay and thought oooo can try some weathering and silkspan sail techniques on that so bought it. keith
  10. Looking good Daniel- see reply in my log as to how i do mine. Keith
  11. Hi Hake- there are various journals on rigging and belaying in general If you can find a copy and intend to continue building naval ships then James Lees Masting and Rigging The English Ship of War (3rd print version if possible) is highly recommended, and they reprinted Darcy Lever's young officers sheet anchor not so long back. Also lots of great build logs on here😉. As tregards the iron (paper) plates they will look fine once painted (don't use acrylic though as that will wrinkle the paper- use enamel- say Humbrol matt 33) .Don't forget you will need some wrapped around the stem as well. Keith Keith
  12. Hi Daniel- Doing good thanks- hows things your way? Been busy completing outdoor jobs before winter sets in so little workshop time😐, regards reefing points (telltales) i used a darning needle and a few inches of the 0.5 mm rigging thread, passed the thread through the sail with an overlong tail on one side, then used normal sewing thread just below where the reefpoint went through and passed half dozen stitches around it. Also when trimmed to length used some diluted P.V.A. to stiffen them and stop unravelling. Not very prototypical but we are talking 1/75 scale here. Keith
  13. Progressing nicely Hake- don't worry too much if slight discrepency in ice bumpers port and starboard as the bow area gets very busy later on. The panels are actually for sheaves to guide rigging through the bulwarks (its what i used for my sheets on the fore/main sails and the main yard braces. Keith
  14. I managed to get hold of the Heller Plastic 1/100 kit off a well known auction site, which should come this week hopefully- you are correct it looks like the constructo kit is now discontinued by look of things, along with the heller , billings 1/75 and zvezda (think this was just the heller one though). Plan on replacing the plastic masts and sails though on mine. Keith
  15. Well done Daniel- books you in for some remedial therapy😁 Keith
  16. looks o.k. to me- i think as these wern't very old at wars end less is more regards the weathering- on my armour kits i dry brush humbrol gun metal on to all sharp edges / handrails/ areas with regular footfall. Keith
  17. Nearly there Hake- to me it was like some sort of punishment given to victorian prisoners! I use various grades of sandpaper wrapped around a 4" offcut of 2" x 1" timber for sanding down things like hulls and those accursed bumpers😁. Does the occre kit now include the deckhouses at the stern - Keith S and myself along with others had to scratchbuild them? I used Humbrol "clear fix" to make my 'glass' in the illuminators- it was originally designed to make the windows in model airliners and glue clear canopies in place. I used the mantua kit for the larger boat then resin models from quaycraft model boats for the launches (i try to mention sources manufacturers for any extras i have bought in the log). Keep up the good work Keith
  18. i use Ronseal acrylic matt varnish for mine- though i never actually apply varnish till all the fittings are pinned/ glued in place as otherwise you are relying on the varnish coat to act as a bond rather than any wood/metal. Keith
  19. can't be sure but i think someone else might have released a model of one these a few years back (italeria/ revell)? was going to buy it but changed my mind- might change it again as RGL is swinging me into getting the U9 kit which i nearly bought! Oh god i can't buy any more kits i have loads....... Keith
  20. I sometimes wonder what is wrong with us all on here😁 Excellent idea regards turning the kit into Britannic Kevin- i think we drive each other into further acts of crazy on here- long may it continue (goes back to my HMS Terror and considers my next bit of insanity🤪) Keith
  21. they should give that gun an over 18 certificate- it is sooooooo sexy😜. Keith
  22. It is a learning curve with ship kits- each problem you come across prepares you for next time, though different manufacturers have different "bugs" in their kits. The colour scheme is looking good Joe, and i would leave her natural wood between the rubbing strake and waterline. Keith
  23. started my victory in 2013 and keep going back to her after breaks of a couple of years, i have loads of builds done but 1st rate men o war are not for the faint hearted or beginners really (and mine is the less complicated billings kit)! Keith
