Everything posted by hof00
Hi Chap, Contact adhesive: apply to one piece, apply to the other, wait until the glue dries off, bring the pieces together and they will hopefully bond.... 😀 I think the reason that A/L suggested this method is to ensure that the Mahogany Decking material and the False Deck didn't warp which might be the case with White Glue. In hindsight, I should have listened to myself and used White Glue and used pressure/weights on the components until they dried off, it worked out o.k. in the end but I found more trouble than it was worth for this operation. So, the Decking worked out in the end. Frames/Bulkheads faired. My next issue were the Gunwales.... A/L called for this to be attached before the Planking Strakes were put on. The problem is that the Gunwales only have an adhesive surface of 2.0mm to attach to around the perimeter of the Deck. I soaked the Gunwales and gave them a bit of "Heat Treatment" to give them some shape. Thinking about things this morning, I decided to install the first Planking Strake level with the underside of the Deck. The theory is that I will have a bit more adhesive area/attachment points for the Gunwales.... (I'll let you know when the Strakes are dry.... 😀) A couple of photos.... Cheers....HOF.
- 29 replies
- maltese fishing boat
- fulgaro
Small update, Assembled Keel/Frames, Planked Internal Decking and affixed in place. Frame/Keel structure fixed in place utilizing False Deck cutouts to square everything up. Mast Step stuff installed now rather than fiddling once the Deck is installed. The Ramin strip-wood has deteriorated and the rest is very fragile, I guess the kit is rather old.... One saving grace, Ply/Wooden parts are Die-Cut, really nice, no char to sand off. False Deck is to have a 0.5mm Mahogany covering, I'll do this tomorrow morning after the construction/glue, thus far, hardens. A/L recommends Contact adhesive for this, I guess I'll give it a go.... 😀 Anyway, a couple of photos....
- 29 replies
- fulgaro
Hi Paul, I have seen some communications on this site, seems A/L are back!! (In Spain, none the less....) https://artesanialatina.net/en/198-model-aircraft Cheers....HOF.
- 29 replies
- fulgaro
Dear All, A new House and a new project, Artesania Latina Fulgaro. This was something that I got off "Trademe" Auction Site, (New Zealand's Ebay), a couple of years ago. (I looked for this under the A/L catalogue but appears to have been discontinued.) I am unsure if I have posted in the correct place but the Moderators can correct if not right. As far as I can ascertain, these boats, "Gozo," are still used. (Sanson will have to take a back seat for the mo.) Two of the three Abyssinian "Helpers" got in the frame, but, as we all know, the Internet was made for cats.... (And Model Ships!!) 🙂 Hopefully, this will turn out o.k. as I intend to give this (When complete), to the owners of a Holiday Park in Opunake who were so accommodating giving us a Cabin to stay in before taking possession of the new House at an absolutely wonderful rate!! The Ship Room is now more or less operational so its time to get Farah-Fawcett, and the Ship Plans, on the wall and do something constructive!! Kit Contents: Usual A/L laser cut wood and something that I haven't seen before in an A/L kit, pre-shaped Hull Strakes, (X6), which go directly beneath the Gunwales. The remainder of the Planking is the usual Lime Strip Wood. Mahogany for the Decking Pre-Sewn Sails Hardware So, it will be an interesting "Smallish" Boat. (It looks like a Happy Boat!!) Cheers....HOF.
- 29 replies
- fulgaro
Hi Chap, No Brass Bands on my version.... Brass Rings on the Mainsail. The Junction of the Mainmast/Topmast, (Hounds?), had pre-formed "Caps" and a pre-formed wooden ring for the Mast Coat. A couple of photos.... Could you clarify your quandary? There are Brass Strips which are used to make the fittings to affix "Sheets?" next to the Cockpit. Cheers....HOF.
Good on you chap for the perseverance!! I mentioned to you that I had to sand my Pen Duick down to bare wood and start over after the Lacquer I used proved too "Hot" (After that, (Sanding down twice after some Lacquer residue was still present), I decided to leave well enough alone. In total, I painted the Hull three times....) I hope you have more success next Clear-Cote application!! Cheers....HOF.
Hi Chao, Yup, the Rigging Plans are not too helpful, agreed.... The "Standing" Rigging is pretty "Run on the Mill" but the Reefing lines, (Boom) need a bit of research as do the running lines for the Jib, Flying Jib and Foresail. The "Top Sail", Topmast and Jackyard on my version were "Fudged" a little, esp. when it was time to mount these items. Don't worry too much about the rigging at the mo, you haver plenty more stuff to do.... In saying so, there are items on deck that you will need to affix prior to Lines.... (No harm in planning ahead, you need to.) Be confident in your considered decisions/opinions/methods and execution. From what I have seen of your build, you'll be just fine. Ps. If your missing the Forward Hatch Porthole, use a Brass coloured rivet, (Clothing/Boot stuff. (Cheap and Easy... Don't crimp it though..... 🙂)) Remember, I am but a Novice, aren't we all? Every Ship model is so different.... 🙂 As I stated before, look's really, really NICE!! 🙂 Happy to Help if I can. Cheers....HOF.
Nice!! 🙂 If your not completely happy with the Filler, you could use automotive "Spray Putty." My experience is that it fills the Grain and sands effortlessly and gives a "Glass" smooth finish. (once you complete the Bulwarks of course.) (Have a go on some scrap stuff.) Just a suggestion. Cheers....HOF.
Hi Chap, Thanks for asking, it's been a bit of a journey and sitting around trying to keep busy isn't the greatest of pastimes…. 🙂 Settlement tomorrow and move in Wednesday.... Hopefully, there won't be any damage to the contents, (Inc. Ship Models....) It'll be nice to get back into some Modeling once the cats are settled and the house is organised. Cheers....HOF.
Hi Chap, You rendition is looking really good!! Don't worry about my build in a past life, a few years ago, I am very sure that your Pen Duick will definitely not be an ugly sister!! This is your very own piece of model Ship building/marine art.... 🙂 Take care and take your time.... Always happy to offer advice if I can do so.... (Counting down to Move in date, I just hope the ships come in, in one piece....) Cheers….HOF
Hi Chap, Regarding Glazing, I have heard of others utilizing Microscope "Slide Glass." from my perspective, I didn't worry, just painted the Below Decks Black, you cannot tell, anyway, I can't once its in a Cabinet. 🙂 Here's some photos of the Skylights, Etc. (I'm pretty sure you have these but just in case....) (The Majority of these photos are the Deck Furniture "Placed" on prior to Bulwarks/Hull Planking.) I also "Articulated" Skylights, Forward Hatch and Companionway "Booby" Hatch just because I could and I felt the scale demanded it. (They open and close but the model is in a wood/glass case Can I see me accessing these? Not really.... 🙂 Anyway, Your Pen Duick is coming along really well, looking forward to you next installment. Cheers....HOF.
Hi Chap, Yup, "Position the Bulwarks so they protrude 5.0mm above the Deck." This will give you fixings for the Bulwarks to the Bulkheads as well as the edge of the Deck. (I did forget the Bulwark Strake is wider than the rest of the Planking material.) So, my memory was both right and wrong, but, yes, I utilised the A/L instructions but didn't get too precious.... 🙂 Thanks for the "Memory Jog." Cheers....HOF.
Had a look at the photo of the instructions that you posted in Page 1 of this log. the first Full Planking Strake is 2 - 3 mm below the Deck. So put some "Tick" marks below the bottom of the False Deck, this will ensure that the Planking will be level with the Deck. (The photo "Jogged" my memory.... 🙂) The Bulwarks attach to both the Deck and Bulkheads. Sanding the Bulwark Taper is not too difficult, you just require a Sanding Block to span the Deck so you can taper Port/Starboard Bulwarks at the same time. Any help? Cheers....HOF.
Hi Chap, Just a thought with the Bulwark Strake, what do the A/L instructions indicate? Thinking about the position, from memory, I think that this Strake is also attached a coupe of mm below the Deck but level with the Deck if that makes sense. affixed to the Bulkheads also? (I don't want to put you wrong and all my "Archived" Plans, Etc are in storage.) I'll haver a look at my photos....
Hi Chap, Now your really testing the Memory.... 😀 Yup, Full Width Plank from Bow tp stern, bottom of the Plank level with the base of the False Deck. You get the enjoyment of carefully tapering the Bulwark from Stem to Stern, carefully of course, leaving the full width of the Bulwarks at the Bow. (This will become apparent fitting the Bowsprit, Etc.) (I wouldn't attempt to taper this initial plank (Bulwark), until you have a couple of strakes attached below this from a structural point of view.) The Planking, (All Planking Strakes), needs to extend beyond the False keel at the Bow, where Port and starboard Planks meet, at a juncture a few mm beyond the false Keel, you will need to cut a Taper on the inside edge of each Strake where the Planks meet. (A Knife Edge, sharp bevel.) Start with one side first, let it set, offer up the other side and the angle will become apparent, use you # 11 skills and you'll be alright!! (There is no Keel added so the Knife Edge forward of the False Keel. so the sharp Keel is your own....) Don't overthink too much, if the "Knife Edge" is not perfect, it doesn't matter too much, there's more than enough thickness in the Planking Strakes to sand and obtain the profile, (Knife Edge), necessary. 🙂 The False Deck Bulwark Level will also give you the guide for all subsequent Planking Strakes. If you choose to Plank four from the top, that's fine and thereafter from the bottom up, that's also fine.... (I Went from top to bottom filling in the gaps. 🙂) I was not too precious about it as I was aware that Filler would do the minor Plank "Gap" thing and I had already planned to smooth with Automotive Spray Putty prior to painting. (This was awesome to achieve a silky smooth finish and so easy to sand!!) Sorry I'm not closer to assist you in your endeavour and hope that you can "Visualise" my descriptions.... Cheer and Regards, Harry. (HOF.) .
