Posts posted by GuntherMT
The coils look really good. How about showing us your jigs for making them?
That would require that I was taking pictures as I went through them.
I was mostly just using toothpicks (round) stuck in Balsa along with another flat toothpick for the tail end that hangs out. Now that I think I've got the spacing about right, I'll find something that the glue won't stick to as easily, probably brass tubing, as I don't have any appropriately sized nails to use. Pretty much the same thing as Dan Vadas used here - http://modelshipworld.com/index.php/topic/230-hms-vulture-by-dan-vadas-1776-148-scale-16-gun-swan-class-sloop-from-tffm-plans-completed/page-101?hl=%2Brope+%2Bcoil#entry339219
I tried using the tiny brass nails, but they ended up too narrow, without any gap in the center of the coils to work with to hang them (before I started leaving the tail hanging out as part of the coil building process) and I kept messing up the coils trying to widen them after. I then used multiple brass nails at either end, and it works 'ok', but the round toothpicks ended up being just about the right size I think.
- Dimitris71, Mahuna, Cabbie and 4 others
7
So I haven't made much progress since my last update, and I've discovered that I don't really like rope coils very much. Seems like a great thing to dislike given my subject choices, hahaha..
In any case, I'm working on getting a jig that makes coils I like, and I think I'm getting somewhat close, but still not there.
I started working at the stern, and I'm done with the stern, quarter-deck, boom, and shrouds now.
The coils are taking much longer than I expected them to, but oh well. Getting a bit better as I go along.
Thanks all, will get back to working on the final details tomorrow. I've been pretty busy this week since finishing the anchors and haven't done anything since. Today was day one of sailing lessons, and I'm completely exhausted, so probably not a great time to work on the ship!
Great looking rigging Brian - maybe you mentioned it elsewhere here - but did you replace the kit supplied rope? Whatever you're using it looks really nice
hamilton
Thank you hamilton,
All of the rigging, ropes, blocks, hearts, dead-eyes, and hooks - everything except for the bullseyes, are from Chuck at Syren Ship Model Company, as are the gun barrels (both swivels and main guns) and the main gun carriages. The deck is holly planking from Hobby Mill, and the masting is all Boxwood from Crown Timberyard.
Holly friggin rigging! So glad I found and added this build log. I have been drooling at the chance of cutting my teeth on my own AVS. I also really like how the sections are labeled and separated. I hope this log stays up for while to use it as a supplement when I start construction. Very impressive build. (we're not worthy, we're not worthy) lol.
I certainly have no plan to take the log down Philthy, and I'm very happy if it helps anyone with their own build of this kit (or even something else!).
- Omega1234, zoly99sask, qwerty2008 and 2 others
5
- Captain Slog, qwerty2008, dgbot and 21 others
24
Awesome, looks like a great time!
- CharlieZardoz and mtaylor
2
I just use Syren line, so I can't really help you with materials, but I think that kit line is generally oversized, so I've chosen to go 'down' in size when given a choice between slightly smaller or slightly larger.
Note that there is exactly zero science behind this system, it's just my opinion based on what kit line normally looks like in my (fairly brief) experience.
- src, CaptainSteve, Canute and 1 other
4
So a big milestone was just reached. All the rigging is now in place!The last big item was the top yard. First thing was to make the parrel that holds it to the top mast. It has one end closed in an eye-splice, and the other end has a pair of eye-splices so that it can be lashed in place after wrapping it around the top mast, and the double rope between is served.
Here is the top yard all rigged up and ready to hang. In addition to the parrel, there are a pair of blocks, the foot-ropes, a brace and lift on each end, and the halyard in the center.
This shows how the parrel holds the yard to the top mast, and the halyard supports the yard vertically. Also a wider shot prior to rigging everything, with just the halyard holding it up.
Jump to the end, I rigged all the lifts (top yard and spreader yard which actually hangs from the two blocks on the top yard), braces, and the flying jib halyard and inhaul.
And what it looks like now. All the rigging is still long at the bottom belaying points so that I can adjust things.
All the blocks and sheaves work. All the parts are actually held in place by the rigging, and it's all functional, in that I can adjust the rigging however I want. I can raise or lower the yards, and adjust the angle of the yards and boom (the Gaff is pinned in place due to the angle for mounting it, but if I cut the pin, it would also be adjustable). If I had sails, the clew lines, in-hauls, and out-hauls would all function to raise and lower the sails.All that's left now is to make the anchors and bouys and rig them to the catheads, clean up all the ropes on the deck after final adjustments, and then make rope coils for all the ropes at their belaying points.Oh, I also need to re-do a few of the swivel cannons before I mount them, and then do overall touch-ups as needed, and make the base for it to sit on. Still a lot of work left to do, but damn it's great to see it looking pretty much done.
- jwvolz, Captain Slog, thomaslambo and 32 others
35
If there are better materials you can recommend let me know where to buy it. I will not make my own rope.
Thanks!
I highly recommend Chuck's rope (Syren Ship Model Company - http://www.syrenshipmodelcompany.com/miniature-rope.php)
It's really great to work with, and I have no interest in making my own.
Crown has masting sets? Wow....ya learn something new every day.
Sure, I sent Jason an email saying that I wanted the following stock (24" long):
2 - 1/2" square.
2 - 3/8" square.
3 - 1/4" square.
2 - 3/16" square.
He sent me a reply with the price, I paid him, and got a masting set!
I over-ordered so I would have plenty of extra if (when) I screwed something up on my first try!
Some of the scratch build logs will take away your productivity for days at a time, they are simply amazing.
A couple that totally captured all of my time for days (and I'm sure I've missed many):
Dan Vadas "Vulture" build (recently finished) - http://modelshipworld.com/index.php/topic/230-hms-vulture-by-dan-vadas-1776-148-scale-16-gun-swan-class-sloop-from-tffm-plans-completed/
rekon54's Le Fleuron build in 1:24 scale! - http://modelshipworld.com/index.php/topic/178-le-fleuron-by-rekon54-1729-124/
- thibaultron, mtaylor, Canute and 2 others
5
Boyd,
I gave up on dowels, and I'm only on my 2nd build!
A few problems with dowels - they have large grain, making them look poor unless you are planning to paint them, even if they are straight. As you've observed, it's very difficult to get dowels that are straight. On masts/yards that need a square or octagon shape, it's difficult to make that evenly out of a round stick.
For my AVS I ordered a 'masting set' from Crown Timberyard out of boxwood, and couldn't be happier with the result. Making the masts/yards out of boxwood eliminated all of the above problems, and there are multiple ways to get your square-stock round for the masts/yards, from my system (a lathe) to Frank's system (check his Paragon build log here - http://modelshipworld.com/index.php/topic/10788-paragon-a-modified-mayflower-by-mahuna/). He has a nice jig he used to help him turn square stock into his masting. Look at post 70 on page 4 of his log.
- thomaslambo, qwerty2008 and Canute
3
Cannon tackle II
in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
You could try making your own out of blackened wire. You should be able to get blackened wire from jewelry supply store, but if you use the easy to use copper, you'll probably have to do touch-up paint after, as it's fairly easy to scratch the blackened color off while working with it.
