Posts posted by YankeeD
Promised to be back when the planking on the portside was finished, I have finished, pffffff.
The pictures are going back in time of the last stages.
Tomorrow I can sand it all and then turn her up again. Wondering what the next stage will be???? I have noi clue, when she is upside again I will see and decide.
Just been reading in from the start, what a nice build!! and some interesting methods used.
I will (however late) join in and take a seat..
- Mirabell61, Piet, mtaylor and 3 others
- 6
Not sure this is the right place (being a modellers world) but I thought I might give it a try.
I have a Burgess (labeled powerline but it is a Burgess as Burgess went up into powerline) bandsaw type BBS20 MKII for sale.
It is in working condition (video available on request) but it will need cleaning/restoration.
It misses the two plastic front blade guidance rollers. The rear blade roller guides are working ok.
No accesories. It comes as shown.
I guess this will only be interested for UK as the saw was sold there mostly.
I am asking 65euro but fair bids are welcome.
pm or email me if there are question.
Just a very short update to let know that I haven't gone...
Haven't done anything since last october. No lust, other projects, holidays, etc etc.
So the ship went up the attic untill I found it was time again. And it was! I also decided that I will close the ship and not leave anything open, hence I have to close the plancking on the portside now. Up for another tedious job, but it is no else. I want to get it done so as to turn the ship upright and again and that I can continue the build up again.
Just 1 pick of the first planck of this year :)... I will post again when this side is closed as well. Have fun building. Hans.
Well its been some time so here another update.
The STB side of the hull planking beneath the first whale has been closed. As said earlier, its a tedious work but I am very happy!!
It really starts to look like a ship :).
I put the present state into the sun to get some non-TL light pictures. It gives a whole other dimension.
During the planking I started to doubt if I should not leave the port side as it is so you could see how it was build, but I decided against it. I did not like the view. So I am up for another tedious part of weeks planking....
This shows while still hanging upside down but just finished.
I am happy with the looks of the bow. This picture is from before the first sanding.
Also the aft looks good, some points needs some work but overal its satisfying. (and for the sharp eyes, yes I am going to redo the rudder, I already stripped it partly. I did the rudder much too early as I now find out. Same with the bow. In the planking you still damage the keel and the bow. But I already have an idea how I can rework them later.....
So it will be for quite some time before you will hear from me again. as there are some holidays on its way and I doubt if I can finish port side planking before end of this year.... we will see......
regards, Hans...
- Sjors, Benjamin Raule, Duanelaker and 18 others
- 21
As it has been june since my last update I could not resist.
Work progress is steady but slow with the plancking. Specially on the bow part each piece takes a lot of time..... First setting it out on carton, transferring it to wood. First sawing it roughly then sanding it to size. 10-15 minutes in water and clamming it in place. then having it dried (mostly and best overnight) gluing it in place. Which due to some of the forces (curving and tordation) also must take overnight. As I am working on both sides simultaneously, I can do max about 3 to 4 pieces per day. But looking at the result I am satisfied. Forget the small openings, I can rework them later as also I need some overall sanding when finished.
It is not as nice and smooth as I could do with for example pearwood, but I am happy with how it looks. I guess that in those they weren't as good looking as we think they might have been.
I let the picture speak for themself. The last one is the status per yesterday.
- dvm27, FrankWouts, mmdd and 20 others
- 23
Thanks Nils.
I still think its very corse and rough and not so nice and polished as I see some other builds.
But then again in those days I guess it was more rough as we feel it should be maybe...
rgds Hans
I finished both sides 1st and 2nd whale and inbetween plank and started on the hull planking towards the keel for which I turned the ship unside down again.
I foud a nice see through....
I will equally work and continue both sides hullplanking untill ready. I stopped using nails and found a way to secure the planks without nails. I will do the nails later. I found the nails and positions were getting rather disturbed from position. So not nice and regular. By doing them later all at once I can do that nice and regular.
- mmdd, Archi, John Allen and 12 others
- 15
In the mean time I finished all the inserts for the gunports.
As to be sure, before I start working on the outside hullplanking and the wales I checked the hull and sanded it a little more to be sure the curves are right.
Next steps were the first wale which in all is the second wale. After that I added 10mm hull plank under which the first wale comes.
The running of the first wale I mounted deviates (only in the beginning) from the drawing but as it looks good on the ship I let it be. No idea how the difference came to be. I checked the line/curve several times.
I will now finish this starboard sides first and second wale and then up to the port side.
Over night I clamp wet planks in a very simple but for me effective way. The are a little oversized so I can also sand them into the curvatures.
- Mirabell61, mtaylor, tadheus and 13 others
- 16
After a nice holiday, we went to see Taiwan and Japan, I thought it time for another update.
Not much happened as we were away quite some weeks.
I finished the inside hull planking from the main gun deck and on one side I finished the inserts for the gunports for the same deck.
Its not actually correct as how they did it (according to Bloms'drawings) but its the best way that works for me.
The inside will come flush with the inside hullplanks but the outside will be recessed. I will sand them to the present frames. After that the outside hull planks (about 1.5mm thick )will be mounted leaving a recessed gunport where the gunport lid can be fitted. I do intend to leave them removeable so I can work the outside hull planking against it and leaves me the opportunity to sand the planks flush with the gunport hole in the frames. (I hope this is clearly explained??? )
Once that has been done I can fix them in place. (If anybody has a better idea its welcome).
Next steps the gunport inserts for the other side. Its a tedious work.
Rgds Hans
- coxswain, aviaamator, mmdd and 13 others
- 16
Thats true, you see a lot more and you are free to go as you like. Also know about how you feel about distances in the US. Used to work and travel there for years and have relatives living in Vancouver, but did not know you did it before. So you are used to the traffic and the way of driving. Makes it easier I guess.
Well, have a great holiday!!!!
Rgds Hans
On 28-4-2017 at 11:56 PM, flying_dutchman2 said:
Amsterdam. Rent car. Drive to Hamburg to FLensburg to Copenhagen (another viking museum).
Thats a lot of driving and only 3 weeks and in June??
Take flights on some of the budget airlines that is probably cheaper than the gasoline and the return fee for the hired car for such a trip.
Saves you a lot of time, to be spent somewhere else instead in a car on busy roads... (its June remember, summer time. unless you drive through the nights it can get very busy on the roads)
just my 5 cnts..
(And by the way, the russian border is not that bad anymore..... unless you purposefully start picturing military objects)
- FrankWouts, Archi, popash42 and 16 others
- 19
Well I had the drawings of Otte Blom (the 7P) printed on an architect paper printer.
They are in size, when printed 1 to 1, bigger than A0 (how to convert to feet???).
So yes these printers exist and the nice thing about these printers (in fact they are called plotters here) are for what we call "work drawings" the paper does not shrink or expand during printing or afterwards.They are measure and scale fixed, so no distortion.
Maybe an idea?
Rgds Hans.
- Jeronimo, michael mott, druxey and 1 other
- 4
YankeeD, tartane,
Perhaps you could verify your links before posting! Niether one of them works
It surely works only I put the phrase between brackets, if you just click it it is most surely the computer adds the last bracket automatically. Computers are not that smart that they realize they should leave out the last bracket as it does not belong to the link. And correct I could have solved that by adding a space...
A very nice frame build indeed!! Interesting way to fix the frames also.
Will follow this with interest.
Rgds and god speed!!
ps (The correct website in above post is http://www.constantwillems.nl/chebec.html)
I am looking forward to the finished product
Well, as I have no deadline, it will probably still be years to see her completion.... and I am even not sure what level that will be???
I work as I feel up to it. Sometimes I bend over different projects and nothing happens for weeks or months.
Rgds Hans.
- WackoWolf, Piet, popeye the sailor and 2 others
- 5
De Zeven Provinciën 1665 by YankeeD - Scale 1:50 - according to drawings by Mr. O. Blom - First wooden scratch ship build
in - Build logs for subjects built 1501 - 1750
Thanks all!!!
She is upright again, but I am really having a hard time on deciding how/what/where to continue???
I want to redo the rudder, so for that it might be handier to turn her upside down again... and I also want to make the bow nicer as it has some dents from doing the planking...
Fixing the stern and the frames stille missing and then continue the planking upwards before building the next deck.....
Gunports...
Hard decisions....
