Ryland Craze
Moderators
Posts posted by Ryland Craze
  1. Thanks everyone for the comments and the "Likes".
    Rich, thanks for the link to the Jax blackening agent.  I ordered the 4 ounce jar and received it very quickly.  This should last me a long time.
    I initially painted the cap rail and did not like the color that I chose.  I stripped the paint off by scraping and sanding and will repaint it later with a different color of red.  I decided to move on to Chapter 4 and install the floor boards and the bow and stern platforms.  I felt this would be better for me as there would be no paint on the cap rails for me to mess up.  I found it easier to make a pattern out of card stock as recommended in the instructions for the platforms and then transfer it to the laser cut platforms.  This helped to locate the notches for the frames.  Here is a picture of the paper patterns that I made:
    I used a sharp blade and small files to make the cuts on the platforms.  I also had to bevel the bottom of the platforms to sit properly on the frames.  This was a slow process for me, but I was satisfied with the fit.  Here is a picture of the bow and stern platforms with the simulated nails installed and two coats of wipe-on-poly applied:
    And here is a picture of the platforms dry fitted to the inside of the hull:
    I will be installing the risers next.  I am really enjoying this build.
  2. Thanks everyone for the "Likes".  I finally finished installing the simulated nails using 10LB black monofilament line.  I cut a short length of the line, dipped the end in some titebond glue and then inserted the glued end in the holes that I had previously drilled in the planks using a #77 bit.  Once finished and the glue dried, I trimmed the monofilament line close to the plank using a sharp blade.  I then gave the hull a light sanding and applied a light coat of Wipe On Poly.  Here is a picture of the line before I trimmed it.
    Here is the hull with the monofilament line trimmed and a light coat of Wipe On Poly applied:
    I then sanded the inside of the hull and applied Wipe On Poly.
    Next up is to paint the cap rail and then install the friezes and the molding.  That will complete Chapter 3 of the instructions.
  3. Another nice model to start with is the Colonial Schooner Sultana by Model Shipways.  It is an inexpensive kit when on sale by Model Expo and builds into a very nice model.
    Chuck Passaro has written a detailed set of instructions on how to build this model.  It can be found in the MSW Database of articles by following this link: http://modelshipworldforum.com/ship-model-build-and-practicums.php  .  It is the last article listed on the page and has eight chapters.
  4. Thanks Michael and Rich and the "Likes".  The model is very strong while being very light.
    Jim, thank you for your comment on my health.  I am doing great and it seems like a bad dream as to what happened to me a couple of months ago.  I will be looking forward to seeing you at the NRG Conference later this month.
    I have installed the cap rail and the bolsters since my last post.  The cap rails need to be thinned down quite a bit and I have started this on the starboard side of the model.  I have done a lot of sanding on the cap rails and frames and still have a lot more sanding to do.  Here is a photo of my progress to date on the Longboat:
    I worked on the bolsters for the past three days.  I was lucky to have made the starboard side on my first try.  The port side took me two tries.  I left about an 1/8'' of wood on the forward part of the bolsters after carefully fitting the rear part of the bolsters to the hull profile and glued them to the stem.  When I sanded down this excess wood, some red grain appeared from the middle of the port bolster.  The more I sanded, the more grain appeared.  I am not happy with this as I feel it will look like a bit of red paint got on the bolster when I paint the cap rails red.  I will have to live with it as there is no way to replace this bolster.  You never know what is hidden inside a piece of wood.
  5. Thanks Michael and Rusty for your comments.  I am doing great now and should make a full recovery.
    I completed the planking and it was time to remove my Longboat from the build board.  I removed the supports at the stern and the masking tape that I had used to tape the bulkheads to the build board.  I removed the fore section first and then the aft section.  A few slight twists of the build board and the Longboat was free from the build board.
    Next came the removal of the bulkhead centers.  I used a razor saw to cut the bulkheads free.  Chuck's design made this an easy process.  I used my razor saw to cut the bulkhead at the top down to the laser cut line on both the port and starboard sides, gave the bulkhead a slight wiggle and the centers popped free.  This was an easy process and I had no issues removing the centers.
    The model is now starting to look like a boat:
  6. Michael, I appreciate your comments.  The emergency room personnel were great and I have the utmost admiration for their skills.  They diagnosed my problem quickly and got me comfortable very quickly.  This was a Friday night and I got to the emergency room about an hour before four shooting victims came in.  It was quite a scene, but they continued to check on me while there was chaos in other areas of the emergency room.  They handled everything in a truly professional manner.  I just wished that I had come in sooner and ignored those that said my difficulties were normal.
    I have registered for the NRG Conference and fully expect to be at full strength by Conference date.  I had a milestone today as I have had my driving privileges restored by my Doctor.  I was getting tired of being a back seat driver as my wife has been chauffeuring me around. This to me is a step to returning to a normal life.
  7. Thanks Bob for your comments.  Several members of my Club (HRSMS) have had bypass surgery over twenty years ago and they are doing just fine.  I was doing well with my recovery until the blood clots came into the picture. I called about my breathing issues and even saw a nurse and was told that my issues were normal for bypass surgery.  It got so bad that I finally went to the emergency room.  My oxygen level was so low that the it did not register on their meter.  I could finally breath when they gave me high doses of oxygen.  I should have gone back to the hospital when I first started having breathing issues.  Lesson learned, If you feel that something is not right with your body, it probably is not right.  Listen to your body.
  8. It has been awhile since I have posted on my Medway Longboat Build Log.  I thought that I would give an update on my progress.
    In early July, I was having some chest discomfort and pains in my left arm.  After numerous tests and procedures by my cardiologist, it was determined that I needed quadruple heart bypass surgery.  This was performed on July 26th and I came home on July 31st.  Recovery was going along as planned until I started having breathing problems and light headiness.  I went back in the hospital on August 9th and they found that I had massive blood clots in my legs, groin and lungs.  I was put on blood thinner and they placed a filter just before my heart to catch any blood clots that should make their way toward my heart.  I was released on August 14th and have been getting better with each day.  I feel that I should make a complete recovery and am very lucky to be writing this post on MSW.
    I have completed the planking and installation of the wales on my Longboat.  I still have some sanding to do.  I did drill the holes for the simulated nails after the installation of each plank.  I felt this was easier to do than doing it after the hull planking was completed.  I have attached some pictures of where I am on my build.
