Ronald-V
Members-
Everything posted by Ronald-V
Yes to all questions...durations of soaking is usually 15 min. or so in warm water...just experiment yourself When you clamp the plank to the deck it's sometimes nessecary to use a little piece of scrapwood between the clamp and soaked plank. Because of the wood is soft with all the water in it, you won't damage it with clamps. That said...walnut is pretty hard, but personally I would better be safe then sorry.
That's going to be a monster! Will be nice to see this Dutch ship come alive
- 7 replies
- card
- De Zeven Provincien
Good to see a build log from you Yes a pencil will be good for caulking lines. I use the more softer ones, because that is easier in my experience (below HB)...for the Sphinx and Pickle I used a 1B. PVA is just fine to glue the deck planks. Not sure what deck layout the Bluenose had, so you could investigate that. And yes I would round off that false deck first before placing the walnut sheets. You want them flat against the hull, so fairing the hull first
Great work GrandpaPhil! Another nice addition to your fleet
- 43 replies
- card
- Speeljacht
HMS Victory by ECK - OcCre - 1/87
Ronald-V replied to ECK's topic in - Kit build logs for subjects built from 1751 - 1800
You've come a long way! Nice work! -
I do like the overall yellow color with the depth in it. I'm with the Sphinx also at this point, painting the stern decoration and such (not started yet) so i'm learning a lot from this
- 144 replies
- Christiania
- Vanguard Models
San Francisco cable car by kgstakes - FINISHED - OcCre
Ronald-V replied to kgstakes's topic in Non-ship/categorised builds
You're a woodartist! -
That looks really good, what kind of wood did you use for the moulding? (maybe I missed it while reading)
- 233 replies
- Model Shipways
- constitution
(and 5 more)
That hull looks beautiful with the oil! 👏
- 233 replies
- Model Shipways
- constitution
(and 5 more)
A big welcome!
The latest to begin the Model Shipways 3 kit set
Ronald-V replied to Taken Aback's topic in New member Introductions
You won't be disappointed with your purchase of a Vanguard Models kit🙏 -
Welcome! -
Getting Started: From Dollhouses to the USS Constitution
Ronald-V replied to Jasennord's topic in New member Introductions
I mainly use the pin pusher for the first layer of planking on the hull. It's simply for holding the plank to the bulkheads. I then push the nails in halfway so they're easy to remove after the glue has dried. Some planks require a bit more force, so I push the nail all the way in, and then pop it out later with a sharpened screwdriver. Once the head protrudes slightly, you can, of course, use pliers to remove it completely. Pre-drilling isn't necessary. A pin pusher is certainly not essential, but it's an inexpensive tool to try out and see if you like it/find it useful.
